wfco power converter 8855 in camper
  • tonytiger
    • Jan 2010
    • 163
    • canada
    hi,im trying to fix my converter unit that has no 12vdc or 120vac
    when i plug 120vac on it directly,there is no 12vdc coming out and vise vesa....
    now i check most all fuses,resistors,capacitors,ect... the thing i notice i have no voltage on my 2 big capacitors on the 120vac....there is no diagram for this board on net that i could find.all help or info would be appreciated.
    Re: wfco power converter 8855 in camper
    Is there remote on/off control to turn the unit on/off?
    • R_J
      • Jun 2012
      • 9578
      You have the bridge rectifier disconnected, that's why you don't have any DC on the main filters, I don't see it mounted to the heatsink, once you connect it, if you still don't have dc on the main caps, your fuse is open.
      From the specs, WF-8855E converter/charger, this is just a 120 volt input to 12 volt output converter, not the other way around
        Looking at the board layout, RJ is correct about the bridge rectifier is not shown not connected; the two White wires should go to the two ~ pins of the bridge, the Red wire should go to the + of the bridge and Black wire should go to the - of the bridge.
          • 31131
          resolder and check those cooking resistors too.
          and once it works, shift the fan sideways to blow across the heatsink more.
          • R_J
            • Jun 2012
            • 9578
            The bridge should be mounted to the heatsink, If I had to pick a cap to replace I would start with the one next to the 2 large ceramic resistors
              So someone else worked on this unit and removed the bridge rectifier?
              • tonytiger
                • Jan 2010
                • 163
                • canada
                hi guys sorry for delay,i received my bridge retifier today and installed it...but now i have 3.1 vdc when plug in(ac)and when i disconect my ac power i have 14.3vdc for a brift moment,any ideal what i could check next.thank you.
                • R_J
                  • Jun 2012
                  • 9578
                  What do you have for a load on the 12 volt side? I believe it should operate without a load and output around 13 volts. What happened to the original bridge rectifier?
                  How did you check the small electrolytic capacitors? did you check ther value with a cap meter or there esr with a esr meter?
                  I only see one small electrolytic on the 12 volt output side.
                  • tonytiger
                    • Jan 2010
                    • 163
                    • canada
                    i put a 12 volt car battery as a load and before i tested voltage on car battery and it was 12.80 and want i connected ac power there is still 12.80 vdc no climing up...the 2 big ceramic resistor do comme hot,fan not turning on,and the big heat sink don't even warm up,stay cold.the client brought me this unit as is,even him don't remember why these wires where loose.and i did check the cap by taking them out and tested with a meter,they where less than 5 to 10% off the normal rate.and yes only one cap on 12vdc side....but i will re-do a second check in case i missed something.and thanks r.j for the pin out help you giving me,i really did not do much of this unit so i will take all the help i can.
                    • R_J
                      • Jun 2012
                      • 9578
                      What is connected to CN2? I see that U5 is a 12C508a 8 bit microcontroller, I will guess that U6 is a 5 volt regulator ic to supply U5. Check it's voltage
                      • tonytiger
                        • Jan 2010
                        • 163
                        • canada
                        hi sorry this projet is taking me time since i don't work on it very much.but R_J i have no ideal of what was connected on cn2(client just brought it like that)i was hoping it would be a switch or something like that since i do not have voltage on u5 so i will be checking u6 tonight but don't have much hope....thanks for the help.i will take anything to finish this job.
                        • R_J
                          • Jun 2012
                          • 9578
                          It looks like the +12 output, connects to R48 which should be the input to the U6 regulator, It shoud have +5v on its output to operate the feedback circuit.
                          I am guessing CN2 goes to a a status indicator somewhere, indicating the output voltage/charge status
                          • shadetreetrader11
                            • Oct 2015
                            • 230
                            Anyone know what transistor u6 is? It's right by the 12v output lead.
                            • R_J
                              • Jun 2012
                              • 9578
                              It is a KA431AZ reference ic
                                MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                                The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                                Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                                10-23-2024, 03:23 AM
                              • gizmo1990
                                What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                                by gizmo1990
                                I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                                The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                                10-21-2024, 08:02 AM
                              • Shane711
                                WFCO Camper Converter need help understanding KA3846 SMPS Controller
                                by Shane711
                                I have this WFCO Camper converter. You plug it into 120v and it puts out 12v 55 amp. After replacing all the bad parts the unit does not work, output voltage is 0.00 volts. There is 2 white ceramic resistors that put out a lot of heat and they burn up all the parts around them. So the main parts to burn up are the capacitors. When I just change out the caps to unit works but the KA3846
                                SMPS Controller sometimes goes bad and that has to be changed. When I change out the KA3846 the unit does not work anymore.
                                I read on the datasheet that the KA3846 can go into shutdown state....
                                10-23-2017, 04:18 PM
                              • Shane711
                                by Shane711
                                10-23-2017, 04:14 PM
                              • wolf1976
                                i look for equivalent dc to dc converter
                                by wolf1976
                                hi
                                in an inverter of aircondition i have dc to dc converter mes1515mh
                                i have attachment the pdf file
                                can i take a dual converter with two dc outputs instead this ? because i cannot found the same or is not possible ?
                                the problem is instead 15 volt dc output i have only 6,45 volt
                                thanks on advancxe...
                                08-01-2024, 04:52 PM
