This is a sticky topic.
Imagine how quickly a Hipro would cook JPCON caps...They already roast Teapo caps because of their slow spinning fans and poor efficiency. (Regardless, I love Hipro)
That still looks like a decent PSU.Comment
I don't really think Hipros are that inefficient. They are certainly very overbuilt for all that inefficiency, most of the time. They don't run hot enough to cause discoloration, anyway, like select cheapos do. As for slow spinning fans, I have noticed that the 200W-250W models seem to have less assertive fan controllers than the 300-400W models, but that's understandable.Comment
I opened one of my old Enermax PSUs today, an
EG365AX-VD
made in 2004.
It was working in a system that operated in a very clean environment so dust has never been an issue for this PSU.
It has been runniung for several years so I was wondering abóut the condition of the components.
Have a look at the pictures. I think this Enermax was built quite well and tidy. (Active PFC wasn´t a must in 2004.)
There´s even a Hitachi HP3 in the primary section and the filtercaps in the secondary section are all "JP CE-TUL", a brand / type often to be foung in Enermax PSUs but I never found a bulged or defective one.
I remember Enermax had a good name back in those days and this PSU seems to be a credit to the species.Last edited by Majestyk; 06-30-2014, 12:48 PM.Comment
that's a quality design!
i love the way they even sleeve that wire & run it through the sinks instead of just jamming it down the edge!!
a friend has an old "Enermax Bue", i wonder if it's that good inside?Comment
I love the classic layout with just one reasonably regulated 80mm fan, ceramic standoffs for components that get hot and proper extruded alloy fins instead of simple cut and bent plates.
Look at the tricky fixation for the little sub-pcb that has a notch fitting right between two fins.Comment
I had an ECS P4S5A motherboard with JP CE-TUR? capacitors that mostly leaked and bulged.Comment
I have the same PSU with the same capacitors, also none bulging. It also has no bleeder resistors in the high voltage section, so even if I unplug it overnight, pressing the power button makes the fan turn slightly.
I had an ECS P4S5A motherboard with JP CE-TUR? capacitors that mostly leaked and bulged.Muh-soggy-kneeComment
not sure how that could happen.
the +5stby section would drain the input caps quickly.
The Enermax EG365AX-VD only has one 400V filtercap in the high-pot section so bleeder resistors or varistors aren´t a must.
Only If there are two capacitors in series resistors / varistors are essential to keep the voltages in balance.Comment
But those are balance resistors, bleeder is for discharging after it is unplugged from the grid, isn't it.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
If there´s a resistor of let´s say 180K in parallel to each of the two capacitors (that operate in series), then these resistors can both balance the DC at each capacitor and discharge it after powering off.
Often there´s an additional varistor (VDR) parallel to each capacitor. The varistors can do the balancing much better and protect the capacitors from operating at too high voltages due to asymmetries but the varistors can´t do the discharging right since they have a high resistance at the lower voltages that occur after powering off.Comment
Speaking of build quality...
I opened a Delta Server PSU today, that is a couple of years old but still unused. It is constructed as a sandwich with one board at the top and another at the bottom. The air for cooling passes right through the middle.
As you would expect from Delta, the components are of excellent quality and only Tier1 suppliers! Strictly Nichicon and Rubycon capacitors, heavy alloy cooling blocks, loads of coils and toroids, a proper shielded filter for the mains connection... See for yourselves and imagine a world where all PSUs are built this way:Comment
As Mrs. S in CA would call it, that really is beautiful power supply "porn". Looks like late 2008 build.PeteS in CA
****************************Comment
It turns out I have a different PSU, a EG-365P-VD, and I can't find any bleeders for the big 680uF, 220V caps in it.Comment
That´s quite strange.
If you have two primary capacitors with 680uF each and they operate in series then you need some resistors and / or VDRs in parallel to each capacitor to hold the DC balance "in the middle" if the two caps get unmatched due to aging. Otherwise one of the caps could operate at 260V the other one at 180V for instance. That would be a problem since they are rated for 220V.
Maybe there are two varistors hidden somewhere?Comment
It's a suspect in the bulged Fuhjyyu cap case! (in my 2005 Antec SmartPower 2.0 500W PSU) It's a shame, Antec!
(not to get confused with that early-1990s Kris Kross song, which I got in my head now, LOL!) ("It's a shame!")Last edited by RJARRRPCGP; 07-07-2014, 06:10 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
http://diit.cz/clanek/delta-electron...b-recenze-test
Final resolution: 100,5 % (it's actually not 0-100 but the mathematical ℝ set). Lowest ripple I have seen EVER, great voltage regulation, great efficiency from 100 W up, great overload, nothing but japanese caps.Last edited by Behemot; 07-14-2014, 06:26 PM.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
