This is a sticky topic.
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    #1881
    400watt max!
    BTW welcome
    • cheapie
      null
      • Jul 2010
      • 849
      Originally posted by _chiller_
      OEM is HKC
      Huntkey? I know they love FCon. I'd expect better (just not much better) from them, though.
      • _chiller_
        • May 2014
        • 6
        I don´t know. If you look on the top left of the circuit board, you can see the name of it: HKC20120510
        I´ve tested it now. The efficiency is very poor. I compared it with an Be Quiet! Pure Power L8 400W (80 Plus Bronze).
        Left: L8 400W; Right: ATX780HM
        81,3W / 91,9W
        184,1W / 203,5W
        320,6W / 352,3W
        394,7W / 473,3W
        The PSU doesn´t stop working, but I ended it here. The 12V Rail was at 11,194V at the end.
        • Stefan Payne
          • 1267
          Originally posted by cheapie
          Huntkey?
          Nope, them he meant...
          The L8-400W is btw FSP APN based...
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #1885
            ATX-500W
            As the "LY-320B" on the PCB implies, this is a 320W max psu.
            The fuse is blown and the main switching transistors (2x 2SC2625) are shorted.
            One of the primary capacitors bulged from top and the bottom and desoldered itself from PCB trying to launch!
            I checked the bleeder resistors and I was pretty sure that one of them would be open. But they were found ok! Considering this unit also lacks any active PFC, that cap should not have failed. "H.Q." caps should be called "T.Q." as Terrible Quality capacitors.
            -4x IN5408 3A diodes instead of a bridge rectifier
            -13005 4A 5vsb transistor
            -2x 2SC2625 shorted NPN switching transistors
            -SBL3040PT @ 3.3V
            -MBR3045PT @ 5V
            -STPR1620CT @ 12V
            All the output voltages have filter coils and the positive voltages have 2x 1000uF "H.Q." caps.
            The main transformer and toroid coils are good for 300W.
            Does anyone know who is the OEM? The PCB layout is very similar to Macron Power 300/350W.
            The fan is "WAM".
            Not worth repairing.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Originally posted by goodpsusearch
              ATX-500W
              -SBL3040PT @ 3.3V
              -MBR3045PT @ 5V
              -STPR1620CT @ 12V
              The fan is "WAM".
              Maybe "H.Q." means Horrible Quality
              Muh-soggy-knee
              • paulnetv
                • Mar 2014
                • 22
                #1887
                Hahaha, these pictures bring back memories of PC PSU's.
                This is quite probably too late considering it's been a few years (Like twenty years!), but if any of you guys ever get a Lite-On or certain Dell PSU's with some foul language scratched into the green underside of the PCB then I might be able to tell you who did it
                Yes, I was young & stupid at one time and I used to work at a branch of Lite-On in the repairs section.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  #1888
                  thats was you? i thought we had someone screwing around in the scrap pile. i found two!
                  Follow the white rabbit.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    We need proof! :P
                    Muh-soggy-knee
                    • paulnetv
                      • Mar 2014
                      • 22
                      #1890
                      They were the good ol' times
                      Have you still got them?
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        #1891
                        Originally posted by ben7
                        We need proof! :P
                        i will see if its still there this Saturday when i go back, but chances are its long gone.
                        • paulnetv
                          • Mar 2014
                          • 22
                          #1892
                          Being honest, I think it's a long shot, most of the PSU's I worked on were rejects from Compaq factory in Scotland, We repaired an awful lot of them that were sent over from Taiwan then failed, I fixed & personalised a fair few, in fact it was probably many thousands!
                          I wonder how many PC's were sent to the states from Compaq in Scotland? Pitney Bowes Franking machines had a nice little PSU in them, One or two of those might have been personalised too
                          • kleung
                            • Jun 2012
                            • 72
                            Thanks for the post. We run a 7 year old dell poweredge 840 server and it gives me hope that your system had very good looking caps in the power supply even after 7 years of continuous runtime.
                            Originally posted by bobcaygeon
                            Delta DPS-450DB S
                            This power supply powered a Xeon 2.6Ghz server with 5 10k RPM drives, a whopping 2GB of RAM, and various other peripherals 24x7 for nearly 7 years straight till it was finally retired about two years ago. I thought I would take a peak inside of it since its just been sitting on the shelf.
                            Remarkably little dust in the unit for running all that time, but I pretty much attribute to it being in a climate controlled environment. It looks pretty overbuilt for a 450W unit, especially compared to the power supplies I see nowadays. Its about an inch longer than a typical ATX power supply, and has a 24 pin ATX connector with the EPS connector, with plenty of Molex but unfortunately no SATA connectors. The primary is on one half of the clamshell and the secondary components appear to be on the other. It appears to have voltage adjusts for all the main rails. Its nearly an all Nippon Chemicon line up in there, but I did spot one small value Ltec in the lot.
                            The duct tape seen on some of the power connectors is my addition. The power cables were all zip tied together, but I had to cut the tie in order to open up the supply and that was all I had on hand as a replacement. :-)
                            • Wester547
                              • Nov 2011
                              • 1268
                              • USA.
                              #1894
                              Do you mean to say that Lite-on power supplies are unreliable, bad stock capacitors and poorly oiled ADDA sleeve bearing fans aside? I know that some Lite-on power supplies have problems (conductive glue, leaky transistors sometimes, etc) but I'd guess they're still better than much of the junk out there.
                              • Stefan Payne
                                • 1267
                                Do you know who did this?
                                • pc7fan
                                  • Aug 2013
                                  • 52
                                  Just by the looks of the heatsinks, it's definately a HIPRO
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #1897
                                    That common mode inductor has pretty poorly separated wiring…
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      The heatsinks look like HIPRO, but the choice of caps, SG6105D and Hang Sing transformer makes me think otherwise. LC Power?
                                      • Stefan Payne
                                        • 1267
                                        Originally posted by 370forlife
                                        LC Power?
                                        Yeah, an old LC-Power. How'd you know? ;-)
                                        Solder quality is pretty shitty, I don't have a good pic though...
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4977
                                          • New Zealand
                                          #1900
                                          I'd guess by the PCB silkscreen number 'LCxxxxxx'
                                          -David VanHorn
