This is a sticky topic.
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
I agree with this. If a PSU has Japanese caps, I don't really care how hot the PSU runs. Lower efficiency doesn't make a huge difference unless you have a folding farm, insane amount of servers, etc. That's when you want to have some PFC to lower your billComment
Except, I prefer higher effeciency, because even with japanese caps, it WILL shorten their lifespan. So in the end, after a while the performance of the PSU will drop because of the increased thermal stress on the components.
Plus, that extra energy really adds up on the electric bill!Muh-soggy-kneeComment
Well
125/0,7 = 178,5W, 53W Heat wasted in the PSU
125/0,85= 147W, 22W Heat wasted in the PSU
125/0,92= 135W, about 11W wasted
And with 250W it's double that amount. So it's worth looking for a more efficient PSU
Totally true.
And, for some people, it can increase the temp of their room significantly... like mine... either that or I have too much hot air xD
Yeah, computers are getting very efficient nowadays though, and even high end 80 Plus units can go under 80% with low loads. Even the average decently made half bridge unit gets at least 75% efficiencyComment
Well, with no load the PSU has negative efficiency - minus infinity actually
No load and some 10 W power draw
Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Let me tell you, I never get tired of these Macron PSU's. I've been seeing a lot of them lately, probably because all the caps are failing in them. As you can see they didn't quite cut that last zip tie
Caps on 5VSB were out of spec and high ESR. Other caps were good on ESR, high on capacitance, except the caps on the 12V, strangely.
Attached Filesif you find these attachements useful please consider making a small donation to the site
Was it wet or where did that corrosion/rust come from?Comment
If you're talking about the stuff all over the PCB, I'm pretty sure it's just flux. If the corrosion were really that bad on the bottom of the PCB, then the casing would be falling to pieces.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Naa, it looks like corrosion. Flux should look different.
And take a look at the cable outlet. It's almost through...
How near to the sea does this computer stand?Comment
Power Systems Inc (from a Tektronix TFP2A FiberMaster)
820uF 200V Nichicon 105C primary unit pair.
2200uF 35V Nichicon PF on all rails; +5V rail has 2200uF 35V Nichicon PF before and after output inductor.
820uF 16V Nichicon PF on primay side control B+ rail.
MJW16010A primary switcher with BUK454-800B synchronous clamping.
KBU6J primary bridge rectifier.
Mascot 9260 24V-12V Converter
47uF 63V Chemi-Con bipolar unit before the fuse and first input inductor with 470uF 63V Elna RSG after the second input inductor with 470uF 63V Elna RSG after the third.
3300uF 16V Philips LD before and after 12V 12A output inductor.
470uF 16V Chemi-Con SME on regulated control B+ supply.
IRF540 switching regulator pair.
BYV72EW-200 output rectifier.
My unit had a leaky Zener diode on the 12V output (between the +ve and -ve output terminals) causing an overcurrent condition.Attached Filesif you find these attachements useful please consider making a small donation to the site
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
P4, that Macron looks like a credible design dragged down by crappy caps (and maybe a cheap fan). Am I missing something? Looks like a nice power line filter, nice heatsinks (including on the I/P bridge rectifier), -52 material O/P inductors, large main transformer, active PFC. It looks like it really could do 400W or very close to it (unlike some 450W-550W P/Ss that would probably put out their rated power for a few seconds before launching).PeteS in CA
****************************Comment
Yeah, it's a great design! Very reliable with some good caps. I've already recapped it with all Japanese caps except I left the big 270uF 400V G-Luxon cap. It read 259uF 0.27Ω ESR so I assumed it was still pretty healthy. The Power Logic fan is definitely high quality. Their sleeve bearing fans have been extremely reliable in my experience, so BB is even betterP4, that Macron looks like a credible design dragged down by crappy caps (and maybe a cheap fan). Am I missing something? Looks like a nice power line filter, nice heatsinks (including on the I/P bridge rectifier), -52 material O/P inductors, large main transformer, active PFC. It looks like it really could do 400W or very close to it (unlike some 450W-550W P/Ss that would probably put out their rated power for a few seconds before launching).
If you look on the transformer it says "MPT500" so it looks like with the right parts, it could do 500W
Something to barf about:
Reason: Too little space, to many components...
That Layout should go through another round of layouting...Attached Filesif you find these attachements useful please consider making a small donation to the site
CapXon makes rubbish as it is. What makes you think their polymers would be any good? Because polymers are a better design?
Never underestimate how some Chinese manufacturers seem to have a special ability when it comes to taking something and making a bad quality version using whatever substandard materials and corner-cutting tricks they can get away with."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Hey guys, I looked inside this power supply. His name is ATX780HM and it has 780 Watts Oo
Well, i think it has 350 Watts in reality, what do you say?
Some other information of the power supply:
OEM is HKC
Primary caps: two Caps named by the company "Cheng", I´ve never heard of them.
Secondary caps: most of them are from "ChengX", a few of them are from a Company named "FCon" and three caps are from "BH"
Protection-IC: Weltrend WT7520, which has OVP and UVP at 3,3V an 5V. It also has this on 12V, but I dont think that it does work. The paper to the technical datas says that OVP stops the PSU at 5V, wtf? Oo
Oh and it has passive PFC ^^
The company that sells this PSU says, that it has four rails at 12V. In reality, the circuit board says it has only two rails Oo On the bottom, I´ve seen that they soldered all rails to only one. This is a Single-Rail PSU ^^
This is my second post in this forum, I hope the picture works ^^Attached Filesif you find these attachements useful please consider making a small donation to the site
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
