	This is a sticky topic.
 Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
 I have two v2s and one v1.
 I am still looking at these boards nearly every day.
 What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while. Though, if the Block Erupters don't sell, I will keep using them for a while.
 Corsair HX620W
 470uF 400V Nippon Chemi-Con KMQ primary.
 2700uF 16V Nippon Chemi-Con KZE before +5VSB regulator with 1000uF 10V Nippon Chemi-Con KY after it.
 3300uF 6.3V Nippon Chemi-Con KY before +3.3V inductor with 2200uF 6.3V KY after it.
 4700uF 10V Nippon Chemi-Con KY before +5V inductor with 2200uF 10V KY after it.
 2200uF 16V Nippon Chemi-Con KZE on +12V rail.
 1000uF 16V Nippon Chemi-Con KY before -12V inductor with 220uF 16V KY after it.
 12cm Adda fan.
 UCC28515 PFC/PWM controller.
 GBJ1506 (800V 15A) bridge rectifier.
 STPS6045CW x2 rectifier for +12V
 STPS60L45CW (? - blown) rectifier for +5V.
 STPS30L30CT rectifier for +3.3V
 STTH8S06D rectifier after PFC stage.
 24N60 x2 MOSFETs for PFC stage.
 18N50 x2 MOSFETs for mains stage.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
 WOW! all NCC caps.
 seem to be Seasonic OEM.| AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
 | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
 | 2xWD7500AYYS | 2xHD322GJ Raid0 |Comment
 They probably put it there to hold a plastic shield in place underneath the pcb to prevent shorting against the case, but that looks like the glue that gets conductive with heat and time. Comment
 HiPro HP-2507F3P 250 watt PSU - came from a Dell OptiPlex GX260 SFF
 DC Output: 5v @ 22A, 3.3v @ 18A, 12v @14A, 5vsb @ 2A, -12v @ 1A
 150W combined on 5v and 3.3v rails
 Has passive PFC (transformer not visible in the pictures) and uses single-transistor forward design. 5vsb is generated from a TOPSwitch TOP200YA.
 Internals...
 Schottky Diodes: 1x 40A for 5v rail, 1x 40A for 3.3v rail, 1x 16A for 12v rail, 3A axial diode for 5vsb
 3.3v rail is generated from a Mosfet (hence the lack of a seconds coil on the secondary side)
 Primary capacitors capacitors: 2x 200v 560uF Panasonic UP?
 Secondary capacitors...
 3.3v rail: 3x Asiacon LE 10v, 2200uF
 5v rail: 1x Asiacon LE 10v, 4700uF and 1x Asiacon LE 10v, 3300uF
 12v rail: 2x Asiacon LE 16v, 3300uF
 5vsb: 1x Asiacon LE 16v, 1000uF and 1x Asiacon HT 16v, 470uF
 -12v rail: 1x Asiacon HT 25v, 470uF and 1x Asiacon HT 16v, 220uF?
 Very nice power supply overall, with thick heatsinks and temperature controlled fan.
 Got it for free (well, $5 actually - reason in post below) because the 5vsb was not working. D203 (UF202, a 2A diode) was shorted. Replaced temporarily with FR153 (pulled from a gutless PSU long time ago), and PSU is up and running now . .Comment
 HiPro HP-2007F3 200 watt PSU - came from a Dell Dimension 2400
 DC Output: 5v @ 22A, 3.3v @ 14A, 12v @10A, 5vsb @ 2A, -12v @ 1A
 135W combined on 5v and 3.3v rails
 Uses single-transistor forward design. 5vsb is generated from an 8-pin IC (forgot the part number).
 Internals...
 Schottky Diodes: 1x 30A for 5v rail, 1x 30A for 3.3v rail, 1x 10A for 12v rail, 3A diode for 5vsb
 Primary capacitors capacitors: 2x 200v 470uF Panasonic UP?
 Secondary capacitors (couldn't see all of them so this list may not be very accurate)...
 3.3v rail: 2x Teapo SC 10v, 2200uF, 1x Teapo SC 10v, 1000uF
 5v rail: 1x Teapo SC 10v, 4700uF? and 1x Teapo SC 10v, 2200uF?
 12v rail: 2x Teapo SC 16v, 2200uF?
 5vsb: 1x Teapo SC 10v?, 1000uF? and 1x Teapo SC 10v, 470uF?
 -12v rail: 1x Teapo SC 25v?, 470uF? and 1x Teapo SC 16v?, 220uF?
 Overall, another decent PSU.
 Got it for $5 on Craigslist. Original owner claimed the PSU shut off randomly - which is possible, since the PSU had a bad 10v, 1000uF Teapo SC on the 3.3v rail before the regulating Mosfet. Recapped just that cap and it's running again.
 The OptiPlex GX260 I mentioned in my previous post needed a quick PSU replacement so I used this PSU in place of the 250W HiPro above. Thus, I got the 250W HiPro for me to keep, which is now fixed as well.Comment
 Excellent soldering!
 The parts the used are overkill for 200 and 200 Watt psus.
 Very good work  Comment
 asus s-30fp made by bestec (says so on transformer and you can tell by the design of the case. the secondar caps are jamicon.
 sandwiched among the jammies are some big resistors presumaby responsible for the discoloration of the inside of the case there. decent input filter, decent heatsinks...Comment
 The designer of this PSU obviously doesn't know ANYTHING about heat dissipation! Get rid of those resistors before they bake everything. Also a good idea to remove the tan/brown glue which goes conductive (usually with added heat).
 On the 200W HiPro I posted, there was just one 100 Ohm resistor on the -12v rail which was enough to cause minor discoloration on the PCB. Needless to say, I replaced it on sight. Used a 1000 Ohm resistor.
 Actualy, the soldering is about average on those HiPro PSUs. I like it, though, because the solder is not lead-free and there are no SMT components like Delta and Lite-ON usually do.Originally posted by goodpsusearchExcellent soldering!Last edited by momaka; 10-10-2010, 09:55 PM.Comment
 i think shovenose's PSU is a rebadged 250-12E. motherboard killer right there. same roasting resistor that the dead one i gutted had... i think it actually made a cap next door leak out the bung and light fire (there was ash everywhere radiating from the area of the cap and resistor, the cap had a bit of burnt plastic as well). fire hazard as well. either pull an everell and add a secondary board to replace the junk 5vsb circuit or gut it for spare PSU and tinkering parts (what i did).sigpic
 (Insert witty quote here)Comment
 It looks like a rebadged atx-300-12Z. Doesn't have the 2 transistor 5vsb circuit, as evidenced by the 4 optocouplers. Comment
 Turbolink LC-A350ATX RU= E164554 CSA LR110995 Level 3.
 Claims 24A on +3.3v, 35A on +5v, 12A on +12v, .5A on -5v and 2A on +5vSB
 I suspect this is total crap.
 I had this thing operating a Tualatin board, no issues, but yanked and replaced with Dynex(Huntkey) so I can sleep at night.
 Can anything be done with this PSU or just scrap it?
 @ bigbeark: yes the ratings likely are total crap. I have a "420W" version of that PSU, and if I remember correctly, the 12v rail has a 10A rectifier while the 5v and 3.3v have 15A rectifiers. Newbie2 has a similar one mentioned here:
 https://www.badcaps.net/forum/showthread.php?t=7588
 Real manufacturer is CWT - probably one of their lowest-end units you can find.
 Depends on how well the PSU is built and how far you want to go. Newbie2 rebuilt his and used it in a 2.2GHz Celeron...
 https://www.badcaps.net/forum/showthread.php?t=7672Comment
 Assuming...7 Photos
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
 I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
 i know that in linear power supply the noise will be very low comparing to SMPS supply....
- Loading...
