I recently pulled "The Best Power" MT-500P 500W power supply from my brother's computer after he recently started to complain about random restarts during his games. I finally convinced him to replace the power supply, so I put my recapped Enermax EG301P-VE 300W power supply in his computer. Here are its specifications:
Intel Pentium 4 3.2GHz Prescott Socket 478 (SL7PN, 1MB L2 cache, HT enabled, 103W TDP)
1.5GB DDR333 RAM (one 1GB and one 512MB)
PCCHIPS M955G motherboard
Sapphire ATI Radeon HD3650 512MB DDR2 AGP 8X video card
160GB WD Caviar SE PATA hard drive
AOpen 16X DVD+/-RW IDE PATA optical drive
Generic "Best Power" MT-500P 500W power supply (now Enermax EG301P-VE 300W power supply)
Microsoft Windows Vista Home Premium (OEM) SP2 x86
Razotech Transformer black mid-tower case
I have mentioned this power supply in the forums earlier, one in 2008 when my brother insisted this power supply was good and in 2007 when I replaced the Teapo and Fuhjyyu capacitors in it with whatever I had at the time.
https://www.badcaps.net/forum/showthread.php?t=4267
https://www.badcaps.net/forum/showthread.php?t=5727
Here are some new pictures I took of this power supply:
Pictures of the power supply and its labels.
The power supply running, with its 80mm red LED fan.
View of the internals of this power supply.
A few pictures of the secondary side of this power supply.
A view of the primary side of this power supply.
The RS405L 4A input bridge rectifier of this power supply.
The completely empty input filtering part of this power supply.
A view of the transformers in this power supply.
A view of the primary side transistors/MOSFETs.
A blurry view of the secondary side power rectifiers.
First of all, the input filtering of this power supply is very disappointing. No components in it at all, not even two Y caps! Just jumper wire.
The bridge rectifier of this power supply is 4A, which means it can draw a maximum of 308W from the wall (assuming 70% efficiency).
The power rectifiers on the secondary side of this power supply are:
1. STMicroelectronics STPR1620CT 16A (2x8A) 200V TO-220AB (spec sheet: https://cdn.badcaps-static.com/pdfs/...0857f446ec.pdf)
2. STMicroelectronics STPS3045CW Schottky 30A (2x15A) 45V TO-247 (spec sheet: )
3. STMicroelectronics STPS1545CT 15A (2x7.5A) 45V TO-220AB (spec sheet: https://cdn.badcaps-static.com/pdfs/...0857f446ec.pdf)
The primary side transistors/MOSFETs of this power supply are:
1. 2SC5353 high-voltage NPN transistor (spec sheet: )
2. FJP13009 high-voltage NPN transistor (spec sheet: )
3. FJP13009 high-voltage NPN transistor (spec sheet: )
This power supply overall looks gutless (no wonder it began to struggle powering a 103W Prescott P4), everyone please post your comments about this power supply on this thread.
I guess the people at Deer/L&C couldn't figure out how to design something better than their common "Y-B200ATX" design and decided to clone one of CWT's designs.
