	This is a sticky topic.
 JJ-400ppga
 Here a 400W PSU made by Jou Jye Electronic.
 I have recapped it because it looks well built, it has a passive PFC, a complete input filter, I forgot to take a pic of the case where another small PCB has another part of the input filter.
 I replaced all Capxon with Samxon, Rubycon and 2 Teapo, I left the 2 Jun Fu on the input.
 I checked the replaced caps: most of all were good, only 2 small caps 2,2uF 400V were completely ruined, I replaced them with Teapo... I had no other caps with such values.
 To be honest I didn't understood why there are those 2 caps: they are connected at the input bridge, between + and -, with 2 diodes and one 2 resistors and the common point is connected on one AC input pin of the bridge. It looks like a kind of "input filter".
 Here some pics.
 Ciao
 Gianni"In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
 H. J. BrownComment
 I am familiar with these power supplies. In fact I can have as many as I want for free, thanks to the 5vsb Capxon caps that always fail and make the psus not work anymore.
 The circuit you mention seems to be a voltage booster.
 Here is a schematic I made:
 https://www.badcaps.net/forum/attach...9&d=1268165068
 https://www.badcaps.net/forum/attach...0&d=1268166583
 I think that the best thing to do is remove completely those 2.2uF 400V caps. They get really hot because of the resistors and it is a matter of time to fail, regardless what brand they are.
 By removing them, you disable that circuit and the power supply gets noticeably cooler.
 Discussion, photos and more info about Jou Jye psus here:
 https://www.badcaps.net/forum/showpo...2&postcount=66
 https://www.badcaps.net/forum/showth...?t=8171&page=6Comment
 This should be same with yours:
 https://www.badcaps.net/forum/showpo...&postcount=116Comment
 goodpsusearch the circuit is identical!!!
 I thought it was a kind of filter due to the passive PFC.
 It will be very interesting to know the right reason why they put this circuit, I can't see any good reason.
 from your post I read:
 I read you have removed caps to avoid useless power dissipation, I will do the same.Originally posted by goodpsusearchThere was much heat coming from the resistors and diodes after bridge rectifier and when measuring DC voltage, I got 350-360V!!!
 This is way above normal DC voltage generated after bridge rectifier in a typical psu.
 So, the circuit among big caps and bridge in that JOU JYE psus boosts voltage when PC is off. With no fans moving, a significant amount of heat is produced, that leads to the board discoloration in just every same JJ psu I have seen...
 I decided to put out the small 2.2uF caps and disable that circuit.
 Heat produced when psu is in 5vsb only mode is now negligible, and voltage is normal.
 H. J. BrownComment
 Hey everyone,
 I was so entertained by looking at random power supplies on this thread that I decided to bust open one of my own. This sucker was a pain in the butt. Dell likes to make things complicated.
 Anyway, this is a power supply from a Dell Dimension 8100, which was released in 2001. It has as labeled peak wattage of 250W and was manufactured by Newton Power (Delta).
 It definitley looks like a solid supply. I think the same speced supply could be made in about half the space nowadays, but hey, this supply is already 10 years old. It has 2 daughter-boards. One is for the transient filter, and one is a controller board of a sort.
 Capacitors onboard:
 -Nichicon LU @ 85°C (PFC/Input)
 -Nichicon PW @ 105°C (Filtering)
 -Rubycon YXG @ 105°C (Filtering)
 -Nippon Chemi-Con XY@ 105°C (Filtering)
 -Taicon (Controller board)
 Enjoy!Last edited by TheLaw; 01-15-2011, 04:41 PM.Comment
 Casecom ATX450W
 Canicon 680uF 200V primaries.
 Sapcon 1000uF 16V at +12V and +5VSB (before inductor) rails.
 Sapcon 1000uF 10V at +5V rail.
 Sapcon 470uF 10V at +3.3V, +5VSB (after inductor) and -5V rails.
 Sapcon 470uF 16V at -12V rail.
 D13007 primary switching transistors.
 16A rectifier for +12V rail.
 20A rectifier for +5V rail . .
 40N03 MOSFET for +3.3V linear regulator.
 Four 2A diodes for primary bridge rectifier . .
 Non-approved Y-class capacitors . .
 Also has mystery "2005B" chip.
 Some serious corners have been cut...My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
 13007 Switchers always seem to go kaboom at about 300-320W on my load tester. My guess is that this would do something similarI love putting bad caps and flat batteries in fire and watching them explode!!
 Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
 Thats a sunpro safety series. AT2005B supports UVP, OVP, OPP, 3.3v and 5v correction. Comment
 Doesn't mean it isn't a sunpro. Could use a older design transformer that doesn't have the TB markings, or the transformer itself was made by somebody other than Sunpro or at a different Sunpro factory. Comment
 Thermal Master TM-420 PMSR
 Here's a Thermal Master TM-420-PMSR
 Caps are all Sapcon (not sacon), CS, Fuhjyyu and JEE
 2 X caps, 2 coils and 2 Y-caps on the input filter
 Transformer says size 40, but it looks more like a 33
 470uF input caps, 13009 knock of Switchers
 20A schottky for the 3.3v, 30A for the 5v and a pair of 16A fast recoveries for the 12v.
 OEM looks to be sun pro. It will do 350W, but it exploded after about 30 seconds at 420W
 Last picture is the frame on the video where it blew upLast edited by c_hegge; 01-28-2011, 09:02 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
 AM607B1 250W
 I got that psu without its metal cover so I don't know anything about it except that it is 250W and "AM607B1" is written on pcb.
 It has an ADDA fan that is very noisy, every cap on it is fuhjyyu and Teapo, none bulged and there are only 2 holes on metal case for the fan screws...
 It works.Comment
 Just picked this one up recently. Real Power ATX 235U
 Nothing spectacular to look at, has a weird texturized feel on the casing, might be because it hasn't exactly lived an easy life.
 Cable count is typical for a unit this old, 5 molex, one main, 1 berg.
 Fan shot. Easy because this unit exhausts into the computer. It's a 92MM U.S. Toyofan unit that puts out 43.8 CFM.
 Label shot. Nothing spectacular. It's an old unit, so low on the 12V side of things.
 Finally the guts of the unit. As you can tell by the transformer, what we're dealing with here is an old CWT unit.
 Panasonic primaries, very dusty ones at that...
 And now we get to the interesting part. As you can see, on the secondary is a forest full of Fuhjyuus and CapXon. Normally, in a unit this well used these would all have puked their guts out long ago. This is because the fan, as mentioned earlier, is an exhaust fan and not intake. This allows the unit to intake cool air and blow it down over the processor situated below it and, at the same time, keep the Fuhjyuus from becoming nothing more then little round cylinders.Comment
 I thought Dell power supplies wre made by HiProBoth PSUs are made by Lite-ON. You can tell by the UL number (E132068) written on the label and the Lite-ON marking on the transformer on one of the PSUs. Also, most Lite-ON PSUs will say "AMBIENT: 50C MAX" on the label.
 One of the PSUs (the one on the left?) looks like it has that brown glue that goes conductive - you might want to remove it as much as you can.
 I think you should keep the one on the right (the one with the OST caps). It has a slightly more powerful 12v rail. More clean, too. Just recap it.Comment
 Dell use a few OEMs. The ones I've seen have been either Hipro, Lite-on, Newton or Delta.I love putting bad caps and flat batteries in fire and watching them explode!!
 Assuming...7 Photos
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
 I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
 i know that in linear power supply the noise will be very low comparing to SMPS supply....
- Loading...
