400W would be the limit but they should be TO-247 package to do that for more than a minute.
 Half of the computer problems is caused by bad contacts
  The two minor rails have dual 40A schottkys in parallel. The first 12V rail which feeds the CPU 4+4 pin and single PCIE 6 pin connector is filtered by a 2200uF nicon KME, and a 1000uF 16V nicon KME. The rest of the 12V is filtered by a single 1000uF nicon KME. These caps have very low ripple current capabilities, so I will replace them with better parts, like KY for 2200uF and ZLH for 1000uF. HEC primary cap read 355uF, but I'm not a fan of HEC caps even on the primary. I have a brand new 270uF Elite GM that I will use to replace it. The rest of the caps are pretty unknown. The filters caps are all nicon (except for a 2200uF 16V Teapo SY on the 5VSB before the coil), but all the small ones consist of ZHN, and SDC. The soldering is somewhat sloppy, but I've seen worse. The Ever Cool fan was heavily overgreased. It filled the entire shaft all the way up to the seal! I think this thing could do 400W comfortable, maybe more. However, I think I will use this in one of my servers to lower the power bill a little.
 The two minor rails have dual 40A schottkys in parallel. The first 12V rail which feeds the CPU 4+4 pin and single PCIE 6 pin connector is filtered by a 2200uF nicon KME, and a 1000uF 16V nicon KME. The rest of the 12V is filtered by a single 1000uF nicon KME. These caps have very low ripple current capabilities, so I will replace them with better parts, like KY for 2200uF and ZLH for 1000uF. HEC primary cap read 355uF, but I'm not a fan of HEC caps even on the primary. I have a brand new 270uF Elite GM that I will use to replace it. The rest of the caps are pretty unknown. The filters caps are all nicon (except for a 2200uF 16V Teapo SY on the 5VSB before the coil), but all the small ones consist of ZHN, and SDC. The soldering is somewhat sloppy, but I've seen worse. The Ever Cool fan was heavily overgreased. It filled the entire shaft all the way up to the seal! I think this thing could do 400W comfortable, maybe more. However, I think I will use this in one of my servers to lower the power bill a little. Half of the computer problems is caused by bad contacts
