ePower EP-550P5
Speaking of ePower...this one has been sitting in my room for a long time so I finally decided to recap it. At first I thought this looked really overrated for 550W. But it almost seems like it could be 500W with 550W peak.
It uses double forward topology. The bridge rectifier is 15A. The crazy thing is that it's rated for 15A with a heatsink, and only 2.1A without a heatsink, so I added one to it. The two FETs on the primary are 18A. The two Fhy caps read ~820uF. The interesting thing about them is that they read very low ESR for primary caps. They both read 0.02Ω.
The secondary silicon consists of two 30A schottkys in parallel for the 12V, and a 40A rectifier each for 5V and 3.3V. It looks to me like there was an option to have two rails on this unit but they decided not to install the OCP shunts by the wires.
Check out the mangled 5VSB wire! Fixed that too. Gave it all new caps. Just from sitting for 4 years, the Asia'X caps were starting to fail. They all tested good ESR but their capacitance all were outside 10% tolerance, some being 15% out of tolerance already, all on the high side of course.
That white fan connector is cool because it splits to two 3 pin fan headers, and two molex connectors with just 12V and com, and sends 5.67V to all of them. I tried testing it with a very cheap chinese fan, and the thing couldn't even start with 5.67V, how sad is that? I have some quality sleeve and ball bearing fans that would start up with as low as 3.5V.
 I attached a pic in case they take it down:
 Half of the computer problems is caused by bad contacts
						 . It does look pretty well designed otherwise, though, especially for something from deer season. It might even do 400W (although I'd be reluctant to push it past about 350W, depending on the silicon)
