Be Quiet! Pure Power L8 300W
Manufacturer _________________ FSP
Certification__________________ ATX 2.4 // 80+ Bronze
PRIMARY__________________________________________________________________________
Topology_____________________Two-Transistor Forward
Transient Filter________________4x Y-caps (2x '472' + 2x '222'), 2x X-caps (.68 + .228), 1x ferrite ring, 2.5x CM chokes (added 1x MOV)
Bridge Rectifier________________1x GBU806 (8A, 600V)
Inrush Current Protection_________-
PFC__________________________APFC
______________________________Unidentified APFC/PWM Controller (possible CM6800)
______________________________1x unidentified APFC MOSFET
______________________________1x STTH8R06FP Boost diode
Bulk Cap______________________1x Teapo LH 150uF 420V (85C) 22mmØ
Main Switchers_________________2x JCS13N50FT N-Channel MOSFETS (13A/52A) RDS(ON)= 0.37~0.46Ω
SECONDARY________________________________________________________________________
Group Regulation
Passive Diodes Rectification
+12V_________________________2x PFR30L60CT Schottkys (30A) VF= 0.53~0.60V
+5V__________________________2x PFR30V45CT Schottkys (30A) VF= 0.41~0.47V
+3.3V________________________ 2x PFR30V45CT Schottkys (30A) VF= 0.41~0.47V
Filtering Caps
+12V_________________________3x Teapo SC 3300uF 16V (105C) 10mmØ
+5V__________________________2x Taicon 2200uF 10V (105C) 10mmØ
+3.3V________________________ 1x Teapo 2200uF 10V (105C) 10mmØ + 1x Taicon 2200uF 10V (105C) 10mmØ
-12V_________________________ 1x unidentified 8mmØ
Supervisor IC__________________ Weltrend WT7527 (OVP, UVP, OCP, OPP, OTP, SCP)
Fan__________________________ 1x 120mm Be Quiet! Silentwings BQT T12025-MS-16 (12V, 0.20A, 1600 RPM, rifle bearing, 25.1 dBA max)
+5VSB_____________________________________________________________________________
Integrated PWM Controller/Switching Transistor TNY277PN
Filtering Caps__________________ 1x Taicon unidentified + 1x Teapo 1500uF 10V (105C) 10mmØ
Decent input filtering only lacking the MOV (already corrected):
Well sized bridge rectifier attached to the PFC heatsink:
There's one single MOSFET for the PFC stuff, can't read it with that huge choke in front:
The bulk cap is a measly 150uF, that's probably why they've penny-pinched on the NTC thermistor :
The main switchers are two 13N50 in two-transistor forward I think (please correct me if I'm wrong on this):
The PFC/PWM switching controller is cloaked up, it might be a CM6800 (like in other versions of the L8):
Doubled Schottkys all around:
The filtering caps are mediocre Teapo and Taicon stuff, but at least they're generously sized, with three 3300uF on the two +12V rails :
+5VSB is handled by a TNY277PN and a BR1060 Schottky:
The supervisor protections IC is a Weltrend WT7527, which manufacturer claims offers OVP, UVP, OCP, OPP, OTP and SCP:
The fan has 'corrugated' blades, like the wings of a Ford TriMotor or a Junkers 52 :
^ The stuff works for this is the quietest PSU ever, dead silent.
The cabling:
I'll leave the craps onboard for a couple years to amortize them, then will recap with japs all around, a ~270uF bulk and a NTC thermistor.
Group Regulation
Filtering Caps
 :The main switchers are two 13N50 in two-transistor forward I think (please correct me if I'm wrong on this):
 :+5VSB is handled by a TNY277PN and a BR1060 Schottky:
 :^ The stuff works for this is the quietest PSU ever, dead silent.
The cabling:
						 . I'd edit it above but this forum doesn't allow editing after a time.
 And you recapped the Teapos with Fhys? Not exactly an improvement besides bulk capacitance but since it's in the voltage doubler you'll get away with it.
 And you recapped the Teapos with Fhys? Not exactly an improvement besides bulk capacitance but since it's in the voltage doubler you'll get away with it.  I replaced the Adda fan with a Mitachi re-oiled fan
						 Half of the computer problems is caused by bad contacts
