This is a sticky topic.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    they've been using taicon and ltec for a while now in budget PSUs..
    they seem to hold up fairly well..
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      well, if your cooling is good and it is efficient (low heat)... then who knows, maybe you can make crap perform well... delta is good at that...
      sigpic
      (Insert witty quote here)
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Not so much that crap can't perform, it just can't for too long.
        Stuff like fuhjyuu/asia-x, YC, JEE, Hermei, CS, etc... can provide excellent ripple suppression so long as the rest of the power supply is designed well.
        Though i've always wondered if some taicon series are just nichicons (or vice versa) such as taicon pw and nichicon pw.
        • POM_MJ
          • Aug 2009
          • 228
          #184
          I've just found bad TAICON PJ 47/25V failed without any signs in 5VSB circuit of the Delta DPS-300KB-1A.
          It made the Delta unit act as MOBO killer like Bestec ATX-250-12E. the 5VSB was output 12V.
          I replaced with ELNA RJF 100/50V, 5VSB is good for now.
          | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
          | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
          | 2xWD7500AYYS | 2xHD322GJ Raid0 |
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i doubt we all saw that coming... uh oh... better monitor the 5vsb on those taicon'd deltas...
            who would have thought that delta=bestec?
            sigpic
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              No surprise as the dps-300kb is a pretty aged unit now. It's still an awesome performing unit otherwise with super tight voltage regulation and low ripple. I don't have mine anymore and it was so crammed full I couldn't tell if it uses a 2 transistor 5vsb, but it probably does. As long as the psu doesn't use the two transistor circuit to generate the 5vsb there is no need to really monitor it.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #187
                Premier LC-B300ATX
                - missing or tiny input filter components...
                - 4 diodes in place of a bridge rectifier
                - 2x330uF input caps
                - 2xC2335 7A continuous / 15A pulsed
                - EL33 transformer
                - missing coils/caps at output filter
                - 2 diodes for 12V
                - 1x S10C40 for 3.3V
                - 1x S10C40 for 5V
                What a POS!!!!
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  2 10A's for the 5v and 3.3v and 6A for the 12v? WHA? I like the PI filter in place of the choke for the 3.3v.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    that psu is epic fail... i have seen worse, but that doesn't make it not suck... lamest i have seen since the echo star with the dummy weights...
                    sigpic
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #190
                      I have never seen such a thing in a psu before...
                        master hoarder
                        • May 2008
                        • 12175
                        #191
                        I have - in a slightly older L&C PSU (same company that makes Deer, Allied, Premier, and a few other PSUs by various names). Surprisingly though, it lasted quite a while - 7 years (still works, but I took it out for a better PSU). Had the two diode treatment for the 12v rail as well. Original caps are a mix of Jun Fu, CapXon, and JEE - all still good.
                        I also have another L&C that has the same exact PCB design as the Premier. Although it's built better, it's still crap. One day the wires started smoking on it and burned. Apparently something overloaded, though I never figured what. Plugged in the PSU the next day, and it worked. Needless to say, I didn't and never will use it in a computer again.
                        I should probably upload my entire L&C/Deer collection some day.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #192
                          They never stop working! Even if their voltages are completely off.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            they stop working when mr. sledgehammer says hi to them!
                            sigpic
                            • cheese007
                              • May 2009
                              • 85
                              #194
                              Today I pulled a RAIDMAX RX-380K out of an old, partially recapped, eMachines, which I assume was a replacement for the infamous mobo roasting Bestec.
                              Case is about what you would expect from the lowest end Raidmax. Flimsy, sharp, dull gray. It's also the lightest PSU I've ever held.
                              Label shot. Optimistic much? Love the inclusion of a -5v rail.
                              Cables. All of them short, all of them 20AWG, except for the berg connectors which are 22. Cable count:
                              1 x 20+4 pin ATX
                              4 x molex
                              2 x berg
                              1 x SATA (why?)
                              1 x P4
                              Innards. 380W isn't a lot of power, but even then I think this unit is a tad bit (read:very) wimpy looking considering the rating. TINY heatsinks, pitiful excuse for input filter, 4 diode treatment, and crapcaps galore. Speaking of cap selection, primaries are by HEC, secondaries by JEE, GL, and SC. It's almost as if they had a bag of the worst capacitors ever, randomly grabbed a handful, stuck 'em in, and called it a day.
                              The fan. Sleeve bearing, model number leads to a web page with a spec sheet for several fans, "Metallic Plastic co."
                              Overall, one of the worst PSUs I've ever had the displeasure of owning. However, a few things did surprise me. 1. It still works. 2. No bad caps. 3. It's still on sale. Yeah, they still sell this thing, and it has a 4 star rating on newegg. *sigh*
                              EDIT: Formatting.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                It's a Sun Pro by the looks. Probably only good for wires and maybe the fan. Just make sure you re-lube it first. I've seen a few of those TP/Te Bao fans fail before.
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  #196
                                  Even the filtering coil is made of simple wire. Totally cheapish.
                                  • cheese007
                                    • May 2009
                                    • 85
                                    #197
                                    I can confirm it's sun pro, as that's where the UL leads.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #198
                                      We just pulled out one at work the other day. Was the exact same crap inside. Fan had started seizing so pretty much all of the caps were bulged and/or leaking.
                                      About 2 years ago, I also pulled one from a friend's computer - in that one the fan was working fine, but the crappy caps (CS, GL, JEE) started failing even before that. Then again, the whole PCB had heat discoloration (probably due to the crappy heatsinks) - and that's with a fan that runs on 12v all the time.
                                      Overall, these Sun Pro PSUs are one of the worst I've seen. The Te Bao Metallic Plastic fans in them are actually not that bad, but they tend to seize early because they're ran at full speed.
                                      • pegdizzler
                                        • Aug 2010
                                        • 19
                                        #199
                                        Here's one:
                                        Seasonic SS-200GPX
                                        Normally a fan of Seasonic, I recently picked up 4 of these for an extremely good price to replacing some aging PSUs in P3 units. They were sold as brand new, and appear to me as new old stock. Upon plugging them in however, I observed they all have an extremely high pitched squeal. There is no dedicated on/off rocker switch on the back, so the noise is constant even when the PC is off and the PSU is only delivering 5vsb.
                                        Think this would be primary or secondary caps causing all the racket, or something else?
                                        It has two Rubycon 200v 470uf on the primary and "P CE-TUR" on the secondary, except for the one and only 16v cap, which is "Z CEHTUR".
                                        Anyone else see the PCB scrape mod? :p I'll have to check the other 3 to see if they have this as well.
                                          • 31044
                                          the blue cap is probably teapo,
                                          and as it may be built a very long time ago, the caps have probably all depolarised by now.
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
