This is a sticky topic.
Hey, I got a Tacens Radix Eco II 600W:
http://www.tacens.es/fuentes-de-alim...ix-eco-ii-600/
Does anyone know the OEM of this thing?
First thing I thought was Andyson but I don't think it's them. It's some other random back alley fab...Comment
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Yup, looks fake to me as well.
But beware of that 5VSB circuit - it's a 2-transistor design. Make sure the output caps and critical cap on the 5VSB circuit get replaced with high quality ones as well. Once that is done, it should be quite reliable.Comment
Does anyone know the OEM of this thing?Comment
I wll be recapping it when my pannys come in from farnell should be here with in the week.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I figured out the OEM to these 8688F PSU's. They're made by GUANGZHOU SANYANG http://en.pangupower.net/Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Huh, you don't even have to buy this one to see it's a turd! yeah, they took pictures!!
http://www.amazon.com/Sentey%C2%AE-B...dp/B00JGUR88C/Comment
http://www.amazon.com/Sentey%C2%AE-B...dp/B00JGUR88C/Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I see at least one pi filter. Look at it this way - for $15.99 (on sale), it could have been WAY worse. But yeah, no way it would be worth $30 (regular price).Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
It actually doesn't look that bad... it's not a 450w psu obviously, but if you look at actual chart it may do what it says (12v @ 12a and everything else, looks like 250-300w psu ratings).
Other than small transformers, it has proper bridge rectifier, some common chokes on input, Y capacitors, an actual 5vsb dc-dc converter, inductors on some outputs and the fan seems to be properly placed to move air through the unit.
Looks like a decent power supply to repair or restore old computers with.Comment
It's STF topology in all likelihood. It has only one cap with no PI filters on at least some of the rails. The ripple could well be out of spec even with no load.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I've seen a PSU with those exact heatsinks and layout before. But it was rated 250 Watt. What a joke!
I hope that warning sticker over the power socket says "Caution: do not actually use this piece of junk""Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
With those wimpy heatsinks? 200W, maybe 250W if the fan is powerful enough to make it hover.PeteS in CA
****************************Comment
Maybe 200w, I had a cit like this usal 13007's all 10a output diodes but that one actually had pi coils and 2 caps per rail but was still junk.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
This ^
Never trust a Leadman, even if it looks well-built. They somehow always end up f-ing up their designs. Really ought to go back and start branding their PSUs PowMax again, because that name really stands up for itselfComment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
