Integrated Power Designs SWR-45-3001-6
330uF 35V Nichicon PJ before output inductor with 47uF 50V Chemi-Con KME after it on +6V 2A and -6V 1A rails.
680uF 35V Nichicon PJ x5 before output inductor with 330uF 35V Nichicon PJ x2 on -2V 10A rail.
180uF 400V Nichicon LQ primary unit.
FES8BT rectifier for +6V rail; MBR1045 x2 (parallel pair) rectifiers for -2V rail.
IRF830 primary switcher.
Power Systems PSI-1724
Note that the defective surge protection MOV-diode assembly and mains fuse was removed for replacement when I took the photo.
3300uF 25V Nichicon PL x2 on -5.2V output; 3300uF 25V Nichicon PL on +5V, +15V and -15V outputs.
820uF 6.3V Nichicon PF for primary side rise time control.
1200uF 200V Nichicon GQ x2 primary units.
SB540 x4 (parallel) rectifiers for +5V 14A rail.
UF5402 x2 (parallel) rectifiers each for +15V 4A and -15V 4.5A rails.
80SQ035 x2 (parallel) rectifiers for -5.2V 13A rail.
KBU6J bridge rectifier.
MJW16010A primary switcher with BUK454-800B synchronous clamper.
 Half of the computer problems is caused by bad contacts
 Love the Power Logic fans in the Andyson unit. Main transformer on that FSP is plenty big. Should be insanely reliable now, especially with that fan!
 I hope your friend told the guy in no uncertain terms that Deltas must never be tossed out, especially if they are still working!
