This is the atrix 650t, 650w rated psu of course it isn't 650w I know their game with this one make the user think that the psu is good by its looks and put them off the quality of the internal psu board, it can do around 400w on a good day. It has a clear Polly acrylic case with two 80mm led fans that can be controlled by the potentiometer at the back, its of an ok quality I recapped it due it having sancon outputs causing bad ripple, Im sure I will find some use for it in a low end rig some day.
Specifications listed:
2* 13009 primary transistors
5vsb transistor 5h01605r with a 1000uf rubycon and a 330uf sc capacitors for the filtering
Passive pfc
Bridge rectifier kbu 804g
output rectifiers:
3.3v sbl3040pt
5v sbl3040pt
12v sf2004pt
Output capacitors:
3.3v 1*2200uf 16v ucc kze 1*3300uf 10v samxon rs
5v 1*2200uf 16v ucc kze 1*3300uf 10v samxon rs
12v 1* 3300uf 16v samxon rs
-12v 1000uf rubycon yxg
-5v 1000uf rubycon yxg
1000uf 200v sancon primary units
Let me know what you think.
Passive pfc
output rectifiers:
3.3v sbl3040pt
5v sbl3040pt
12v sf2004pt
Output capacitors:
 Half of the computer problems is caused by bad contacts
						 I hope your friend told the guy in no uncertain terms that Deltas must never be tossed out, especially if they are still working!
