How to easily remove silicon from board/components?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3635
    • slovakia
    Hello. I want to try to repair some laptop chargers but it have silicon on board and smd components. So , how to easily remove this silicone?
  • redwire
    • 3912
    Re: How to easily remove silicon from board/components?
    I peel it off, or use dull flat-blade tweezers to scrape and tear off pieces.
    It's very difficult because hitting an SMT part and it gets broken.
    It depends on how hard and how good the stuff is sticking to the PCB.
      • 31304
      small flat ended screwdriver works for me.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3635
        • slovakia
        but i dont want to use scraping or tearing. i dont want to damage smd components. is there any other method?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          No chemical or heating methods I know of, if that's what you're implying.
          Just scrape carefully with a small *sharp* screwdriver, and it should be fine.
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            acetone might help a little bit . or some gentle heat should soften it .
              • 31304
              silicone rubber is resistant to just about anything - that;s why it's used for washers and o-rings.
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • 944longdrift
                Help Identifying board components - iMac 2017 21.5
                by 944longdrift
                2017 iMac (Mid 2017) A1418
                I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
                Can anyone help identify them?
                I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
                Thank u
                03-14-2024, 11:53 AM
              • gusto
                How do I remove the chip from the board
                by gusto
                I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
                Fortunately, I'm testing it on old network switches to see how it works.
                What am I doing wrong?
                I've seen a lot of videos on youtube and everyone got the solder melted and the...
                10-08-2024, 10:55 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
