Help Identifying board components - iMac 2017 21.5
  • 944longdrift
    • May 2015
    • 12
    • United Kingdom
    2017 iMac (Mid 2017) A1418
    I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
    Can anyone help identify them?
    I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
    Thank u
    Click image for larger version  Name:	IMG_4324.jpg Views:	0 Size:	2.01 MB ID:	3235002
  • 944longdrift
    • May 2015
    • 12
    • United Kingdom
    After some research, I've identified it as a "common mode choke". This particular one has 6 pins (legs) ie. three lines.
    The dimensions are roughly 4.5mm x 3mm x 2mm
    I couldnt seem to get consistent results when mesuring resistance, but somewhere around 4Mohms
    I've looked every where online but cannot find an exact match so I may be forced to shell out for a spare logic board from eBay
    ​On the off chance anyone may know where I can source them from, please let me know,
    Thank u.
    • petehall347
      • Jan 2015
      • 4446
      • United Kingdom
      coils dont measure in ohms .. its inductance measured in henries or parts thereof
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • stefanbs
        Fit 820-00244-А board in Apple Macbook A1534 2017 820-00687-А
        by stefanbs
        The laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?
        05-11-2025, 01:08 AM
      • kujoswrath
        Help Identifying ASUS ROG Rapture GT-AXE16000 Board Components
        by kujoswrath
        Hi Everyone, hopefully somebody can help me.
        I have acquired an ASUS ROG Rapture GT-AXE16000 with a faulty 10GE port. It's locked at 100Mbps. A component on the board went pop but I'm not sure what it is. If anybody has a schematic or knows what the component is I'd be extremely grateful.
        I have attached pictures highlighting the thing that went pop.
        Any help is appreciated. Nothing else around it looks damaged and a quick check with my multimeter seems to confirm this. I tried taking one of its brothers off and measuring it but, when I tried to grab it with...
        04-30-2024, 02:21 PM
      • ugamazing
        Assistance with identifying resistor value on 820-02918 A2992 board?
        by ugamazing
        Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
        I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
        09-06-2024, 08:33 AM
