Hello. I want to try to repair some laptop chargers but it have silicon on board and smd components. So , how to easily remove this silicone?
How to easily remove silicon from board/components?
Tags: None
Re: How to easily remove silicon from board/components?
I peel it off, or use dull flat-blade tweezers to scrape and tear off pieces.
It's very difficult because hitting an SMT part and it gets broken.
It depends on how hard and how good the stuff is sticking to the PCB. -
but i dont want to use scraping or tearing. i dont want to damage smd components. is there any other method?Comment
No chemical or heating methods I know of, if that's what you're implying.
Just scrape carefully with a small *sharp* screwdriver, and it should be fine.Comment
acetone might help a little bit . or some gentle heat should soften it .Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Assuming...7 Photos -
by 944longdrift2017 iMac (Mid 2017) A1418
I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
Can anyone help identify them?
I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
Thank u
by gustoI am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
Fortunately, I'm testing it on old network switches to see how it works.
What am I doing wrong?
I've seen a lot of videos on youtube and everyone got the solder melted and the... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
