Cyberpower 1200 UPS (Viper22a) dead
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    A friend gave me this ups, problem is that it charges battery but doesn't convert 12V to 220V, I tested all transistors, diodes, mosfets, relays and everything seems fine.
    UPS uses VIPER22A chip which while ups is connected to 220V source has 10V on VDD pin (4), but when disconected from the wall VIPER looses voltage and ups dies.
    Some symptons so far:
    With only 220V input UPS wont turn on.
    Without battery ups just clicks and doesn't turn on the screen.
    With battery it turns on and beeps only, no output.
    With battery and 220V input it works and produces output 220V.
    When 220V input is disconected UPS beeps and doesnt produce 220V output.
    When ups is working it shows battery voltage 0V and capacity 0%
    So, is there a way to test this chip, should it produce output all the time while there is a 10V on VDD pin and some current on FB pin, or doest it start outputing when it senses power loss?
    Does anyone has a schematic for this ups, CyberPower 1200E-B?
  • brethin
    • Dec 2008
    • 1907
    Re: Cyberpower 1200 UPS (Viper22a) dead
    Your batteries seem to be bad. Try new batteries.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Hey brethin,
      I did, all the tests i have done are with new battery... I did found and replaced Viper22a but it didn't help... might be some of the SMD components that are faulty but it's a hell to find out which.
      Thanks for interesting in this
        Can we see good clear pictures of the whole top and bottom side of the board/s?
          MSI Gaming GT73EVR 7RF-1200 Titan Pro Notebook GT Specification for Upgrade or Repair
          This specification for the MSI Gaming GT73EVR 7RF-1200 Titan Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT73EVR 7RF-1200 Titan Pro boardview and GT73EVR 7RF-1200 Titan Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
          09-06-2024, 06:30 AM
        • t4796
          Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
          by t4796
          I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
          Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
          From the FAQ I learnt that for 110v the power...
          10-25-2024, 06:59 PM
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • disorder
          ps5 edm-033 dead after hdmi/usb ports destroyed
          by disorder
          hello guys,
          i need help to repair a edm-033 ps2
          history : as always hdmi port and usb ports destroyed after unplugged
          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
          so i changed it
          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
          i don't see any projection of liquid metal on pcb.
          01-14-2025, 12:48 PM
        • Beton
          Finding a dead short component
          by Beton
          Hi guys!
          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
          I have a bench PSU and if I try to inject voltage the voltage...
          12-10-2021, 01:05 PM
