Dc power supply blow up! (QW-MS3010D)
  • Oroshi
    • Mar 2015
    • 14
    • Athens
    Hello guys.
    I have this power supply one week..
    Yesterday when i short the leads to change the amps i hear a weird noise like something is going to crack.
    And today when i press the power button i see smoke and thunders from inside this power supply.
    I open it and i see a blown IRF 840 Mosfet, but it damage the board also.
    • 31163
    Re: Dc power supply blow up! (QW-MS3010D)
    why short the leads?
    • Oroshi
      • Mar 2015
      • 14
      • Athens
      Because it's not programmable power supply.
      I wanted 5v and 2 amp limit, so the way that works I short the leads with low voltage and adjust the current.
        https://cdn.badcaps-static.com/pdfs/...082f56a5ac.pdf
        What was the Output Voltage setting at when you shorted the leads together to set the CC?
        • Oroshi
          • Mar 2015
          • 14
          • Athens
          1 volt
            Well, it looks like the over current protection was not working so well.
            • Oroshi
              • Mar 2015
              • 14
              • Athens
              What can i expect from Chinese cheap psu (70$)?
              Ι already order new IRF840 mosfets to replace all of them. I know it's time wasting but i give it a shot.
              I don't have much experience in electronics to find what is the problem and fix it. I don't find any schematic for that psu.
              • R_J
                • 9582
                It looks to me like the heatsink shorted out the circuit traces? I found this for a MS-605D but I think it is close.
                • petehall347
                  • Jan 2015
                  • 4434
                  • United Kingdom
                  poor insulation technique
                  • Oroshi
                    • Mar 2015
                    • 14
                    • Athens
                    Just terrible. R_J I think the same. Also I found more like lifted pads and poor soldering work.
                    • Oroshi
                      • Mar 2015
                      • 14
                      • Athens
                      Anyways it's not worth the time. Thanks guys.
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        • USA, Unsure of Planet
                        That was my thought as well. The pitting on the bottom of the heatsink lines up with the trace that is partly missing. I don't see any insulator to prevent arcing. The other heatsink seems to have traces running under it, too. So I'd be nervous about that heatsink as well.
                        PeteS in CA
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Nice... it was using soldermask to insulate the heatsink from the trace?!!? wow!!!
                            Anything goes for them to save money.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Maybe it's a good idea to tear apart every MIC device I come across, to look for silliness like this...
                                • 31163
                                i do.
                                visual inspection before powerup every time.
                                not just china stuff btw, trust nothing - you may live longer or avoid some smoke!
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  I just hope it's not warranty-voiding whether I break something while inspecting it or not!
                                    • Jul 2011
                                    • 6059
                                    Most of the time I do not care if I void the warranty or not
                                    This is the part I worry about
