iMac P/S posts then shuts down
  • Toasty
    • Jul 2007
    • 4171
    #61
    Re: iMac P/S posts then shuts down
    Motherboard (midplane in Apple-speak) and power supply caps are primary suspects.
    veritas odium parit
    • trex66
      trex
      • Jan 2011
      • 76
      thanks, Toasty - I pulled the PSU and I posted another thread, 'odd voltages' I'm getting 45.7V on the 3.3V pins when it is plugged in but not switched on. When I jumper it on, it falls to 3.3V BUT, the other voltages that turn on 5/12V pins start at 5.17V and 12.19V , then climb higher and higher. Afetr a few min I the 12V pins were 12.75V so I shut it off. I'm thinking when the voltages get too high for the midplane to filter, it's making the Imac shut off?
      • Toasty
        • Jul 2007
        • 4171
        #63
        I suggest that you stay in the "odd voltages" thread. Until your PSU problem is corrected, posting here and there will just be confusing.
        https://www.badcaps.net/forum/showthread.php?t=13163
        nntr
        Toast
        veritas odium parit
        • sylphhawkins
          • Mar 2011
          • 18
          Hi guys, this is my first post (after a year or 2 of reading posts on badcaps, I finally registered because I have a problem that I haven't been able to fix from hunting down anyone else's posts, =p), and I'm aware that this may not the best thread to put it up in, so please let me know if I should start a new thread elsewhere, =)
          Basically, I have one of the aluminium intel iMac 7,1 (mid 2007) 20' 2.4ghz models, with a 614-0403 power supply.
          The imac has a problem where 90% of the time, it will power up (3 of the 4 diag LED's light up on the motherboard), with no chime, DVD and HD spins can be heard, and fan's power on, then it will shut down (usually after only 3 or 4 seconds), (diag LED's will return to just LED#1 on, others off), and then it starts up again, (same symptoms, DVD and HD spins, fans spin), and remain in that state with no change, no chime, no boot, no display.
          Having repaired iMac G5's before, I immediately checked the PSU for cap issues, and they look fine, and measure fairly close to their specs.
          Going over the board, the only thing noticeable is a yellow "burnout" looking flux residue on the underside, by Q33, D41 and D45.
          I've checked the voltages on the PSU pinouts, and the only strange one that jumps out at me, is a 2.6v reading when in "standby-power off" mode, on PIN 5.
          However, the voltages specified by a post over at ifixit.com:
          (http://www.ifixit.com/Guide/Repair/i.../2740/2#s13220)
          state that it should be reading 3.8v, and that it is acting as the PSU-enable pin?
          Does anyone have any ideas, or experience with these PS units?,
          I've replaced the caps that connect directly to PIN 5 from the 12v source, but the voltage has stayed at around 2.6v?
          Thanks everyone!, any help will be super appreciated. ^_^
          - Sylph
          • godonr
            • May 2009
            • 111
            #65
            Sylph... have not had the pleasure of messing with your model but make sure it's not a bad harddrive load causing the problem. Booting single and running fsck has cured the issue you describe on G5s I've worked.
            • sylphhawkins
              • Mar 2011
              • 18
              Hi godonr, =)
              Thanks for the idea, i thought that perhaps there was a HD issue, so I pulled the HD out, and the problem remains the same, i've also loaded the HD in an iMac G5 that i fixed, and it's working perfectly, =p, for now, the G5 has also inherited the bluetooth card from the C2D until I can get it working, ^_^
              The strange thing though, is that I have been able to get the 20' iMac to chime and boot, with perfect display and everything working great, but only after some random trials, and it only remained on for a few mins before freezing up. (Before I pulled the HD)
              I was once able to get it to boot by leaving it running in it's "no boot, no chime" mode for a few hours, =p, with the CPU fan on max (by removing the LCD temp sensor), and after that, the next power off, power on, it chimed and booted!, I was shocked!, but it was only short lived, as it lasted for a few mins, then froze, and after a few restarts and freezing at various times, it was back to the same state as before, no boot, no chime.
              I suppose that lead me to thinking that it might be an overheating problem?, and that the extra heat generated over the few hours with the power on, had helped to "reseat" something, or some component was able to operate somewhat?,
              I also notice that there is probably a problem with the CPU temp sensor, as the CPU fan comes up to full blast after 1 min of being powered on in its no-boot state, and when I was able to get it boot a week ago, istat showed the CPU temp sensor as sitting at around 21*C, even after a few reboots,
              Does anyone think that the CPU temp sensor could be stopping the iMac from even getting to Post?, disconnecting it doesn't change the problem?, but makes the fans run flat out from the word go.
              ^_^
              • Toasty
                • Jul 2007
                • 4171
                #67
                This just got confusing. This is a G5, correct? We are 65+ posts deep in this thread....
                veritas odium parit
                • sylphhawkins
                  • Mar 2011
                  • 18
                  Woops, Point taken, ^_^
                  I am talking about an Aluminium Intel iMac (mid 2007 model), but it is exhibiting exactly the same problem as godonr, so I thought that maybe it would possibly be linked the same problem. =)
                  I'll make a new post and ask the question again, =p
                  - Sylph
                  • ryogadan78
                    iMac A1418 - No LED, no power after overvoltage on Ethernet port
                    by ryogadan78
                    Hi guys, I need your help again.
                    I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                    When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                    06-10-2025, 03:49 AM
                  • Stephen
                    iMac M1 DFU restore issue
                    by Stephen
                    iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                    this is the message it gives me with the error
                    Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                    Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                    03-07-2025, 12:19 PM
                  • Stephen
                    iMac 27” 2020 Boot issue
                    by Stephen
                    Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                    08-16-2024, 09:32 AM
                  • tommy97
                    iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                    by tommy97
                    we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                    Any ideas what might've...
                    04-20-2024, 04:48 AM
                  • huzo
                    HP Omen shuts down when loading OS
                    by huzo
                    The model is 15ec-1061nm
                    Board number is DAG3EDMB8D0​
                    SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                    10-29-2024, 12:05 AM
