Silverstone ST56F with Teapo capacitors – Is there any need for replacement?
  • xsi_xsi
    • Mar 2009
    • 8
    Hi there,
    My new SilverStone power supply model ST56F is using Teapo caps in both of its filtrating stage. Just curious if the Teapo caps still are garbage or become better quality in recent years. Is there any need of Teapo replacement from my side? I have purchase this ST56F model for $ 77.
    Thanking you so much.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Silverstone ST56F with Teapo capacitors – Is there any need for replacement?
    Teapo are not the worst out there, and will probably survive in most well-designed and well-ventilated PSUs. However, if you've got the PSU out and opened, you might as well use the opportunity to replace the caps as a preventive measure.
    • i4004
      • Oct 2006
      • 2029
      no
      there are some chances he would even increase the ripple by doing that....
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Hes right, on jonnyguru he recapped a psu (can't remember what it was,) and it got even worse ripple than before. Teapos will be fine in a nicely designed and cooled psu like that silverstone.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Was a Fortron Bluestorm or something like that..
          • ss627
            Super Member
            • Mar 2008
            • 52
            Was the test repeatable on an identical psu? Age of capacitors/Burn in? Maybe bad source of capacitors?
            • i4004
              • Oct 2006
              • 2029
              i think it was actually two psus(one was fortron, yes) but can't now be bothered to find the link...because i remember how j.guru site looks rather disorganized once you start looking for that particular article...is it under articles, under reviews...
              only heavens knows...
              yeah, screw the google too for making me use my brain...give me a fuckin' rest...
              <wink>
              • ss627
                Super Member
                • Mar 2008
                • 52
                I've seen the article several months ago. IMO their experiment was flawed.
                • i4004
                  • Oct 2006
                  • 2029
                  why would that be?
                  all they did was change the caps and measure the ripple....
                  how would you do it?
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    I believe he changed the caps to UCC, so they did use good caps.
                    http://www.jonnyguru.com/modules.php...tory&ndar_id=8
                    It was an Antec Neo, yup, replaced with UCC's. From those heatsinks, that antec looks like a Deer?
                    The second one is a 600w FSP recapped with UCC's, and thats the one with worse ripple afterwards.
                    • Wizard
                      • Mar 2008
                      • 2296
                      Does this FSP have CLC filter network? Sometimes these uses specific capacitors to damp out the ripples/noise without need of a CLC filter network (pokey indeed).
                      What I refer by this is capacitor then inductor, then cap in series. Plus a inductor after the diode as well to keep diode from over heating from sharp transtitions.
                      Cheers, Wizard
                      • i4004
                        • Oct 2006
                        • 2029
                        yes, like i said there were two(both got worse ripple afterwards), and both got increased ripple after being recapped with those top caps everybody here likes so much...(except me...muahahahaha...)
                        it seems recapping should be done with the help of scope, but then it alse means you need some load, and that just makes it "bleeeaahhhh"....
                        OR, recapping should be done with new caps that have same esr as original caps when they were new....
                        wolf(if he wrote it...don't see signature) said it well
                        "What can be done about the ripple then? Well, short of a total redesign on the pi filters, nothing. And that redesign must be done at the factory I'm afraid."
                        teapos are good in psus, end of story...i have them in my fortron and i won't be touching them unless they bulge, and chances are they won't....i equaly won't be making load tester or making one...fuck it....i trust fortron...
                        • yanz
                          • Nov 2004
                          • 910
                          yes it worse then before it recapped but it was negligible/small i wont call it "worse".
                          • i4004
                            • Oct 2006
                            • 2029
                            so would you call it "better" or "the same"?
                            hehe...
                            • Oklahoma Wolf
                              • Dec 2005
                              • 353
                              <wink>
                              It's under articles because it isn't a review
                              The units in question were an FSP Epsilon variant and an Antec Neopower 480W. Caps used were limited to what I could get my hands on at the time. My first choices in caps weren't available.
                              • Wizard
                                • Mar 2008
                                • 2296
                                Wolf, now that we have choices what would should be? Just to hear and for curiosity.
                                Cheers, Wizard
                                • KeriJane
                                  Mac Enthusiast
                                  • Sep 2008
                                  • 681
                                  I noticed that too!
                                  Worse ripple after a recap that is.
                                  Right after I had finished building my PSU load tester, I obtained 2 brand new identical Enhance 300w PSUs for about $10 each.
                                  They tested the same, actually not bad at all.
                                  So I recapped one and surprise! Higher ripple.
                                  I had taken out Teapo and maybe some Ltec and put in mostly Nichicon PW, a Rubycon MBZ and a UCC KZJ. The MBZ was on 5VSB, 12, 5 and 3.3v were all PW series. I didn't have an ESR meter at the time.
                                  Testing them against each other was a lesson in humility.
                                  Similar results from pulling the OST out of an Antec Earthwatts. Put them back in, back to normal.
                                  The ripple is still well within ATX spec but this unexpected outcome was puzzling.
                                  On another note, recapping a 300w Allied PSU had no ill effects. Replacing the "YC" (or CY?) brand caps with PW series had no effect on ripple. The ESR on the YC caps was pretty close to that of the Nichicon PW ones.
                                  Have Fun,
                                  Keri
                                  PS. I just started on building PSU load tester #2 with Analog panel meters instead of Digital.
                                  The More You Learn The Less You Know!
                                  • i4004
                                    • Oct 2006
                                    • 2029
                                    articles has 4 subcategories, and it's not in the "troubleshooting" but in "diy"...
                                    and it's named "Capacitors and the Computer PSU"
                                    frankly, the last place to look..hehe...that subject looks like it's theory of operation of capacitors..
                                    anyho, it's located now...
                                    well, now he would put caps with even lower esr, for even more ripple, offcourse...
                                    <wink>
                                    can it also go higher with the load?
                                    500-600w at least?
                                    • KeriJane
                                      Mac Enthusiast
                                      • Sep 2008
                                      • 681
                                      Hi i4004!
                                      No, it won't be any higher in load because I'm using the same housing and it has a limited amount of room for the power resistors...
                                      The totals are:
                                      12v+ has 4 50w resistors at 4a each for 192w total
                                      5v+ has 3 25w resistors at 5a each for 75w total
                                      3.3v+ has 3 20w resistors at 6a each for 54w total
                                      12v- has 1 10w resistor at .4a for 3w total
                                      5vSB has 1 10w resistor at .5a for 2.5w total
                                      There is room for 2 more resistors so there is a little room for increase...
                                      Any suggestion as for which voltage?
                                      The whole point of constructing it was to provide a reasonable load to stress the PSU for testing. It was not intended to test PSUs at maximum capacity or burn them out. Well, not on purpose anyway. It did kinda smoke that old 185w Gateway PSU.... but only at 134w!
                                      Have Fun!
                                      Keri
                                      • Oklahoma Wolf
                                        • Dec 2005
                                        • 353
                                        Cheers, Wizard
                                        It's been a while, but IIRC what I asked for were Panasonic FC. Nichicon PW was also discussed if memory serves.
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • Cama
                                          Solar Inverter - SMH-II - 2 missing capacitors
                                          by Cama
                                          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                          My model is : EASUN SMH-II 7 KW
                                          Mother Board : P/N 18947-002401250250
                                          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                          Thank you...
                                          09-12-2025, 02:50 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
