I need to build a transient voltage spikes 28 to 30 volts @ 2 amps
    • Jul 2011
    • 6059
    How I build something like this
    I need it to start clamping the voltage at 28 volts
    The data sheet shows that max amperage is 2 amps
    This is on a coil type horn
    • 31163
    Re: I need to build a transient voltage spikes 28 to 30 volts @ 2 amps
    i'm lost.
    you want to make transient spikes, or kill transient spikes???
      • Jul 2011
      • 6059
      Originally posted by stj
      i'm lost.
      I want kill transient spikes how would I go about doing this
      I not going to hook it to a PLC but I want to follow there recommendations that they have about transient spikes because I want to use a switching power I also have to power a LED strobe unit which has the same requirements about transient spikes
      I do not want to fry the switching power supply
        • 31163
        VDR's
        operate like a zener diode and look like a disc capacitor.
          So what is required suppression limit? I will have to be higher than 24V of the source is 24V. So what is the maximum transient is allowed?
            • Jul 2011
            • 6059
            That the part of what I do not know ----> i was thinking of starting to clamp it around 28 volts or so but I do not know if this is right place to start
              So are you trying to drive the 24VDC coil type horn (https://www.galco.com/buy/Edwards-Signaling/877-G1) directly or you are trying to drive a switching power supply that requires 24VDC feeding it?
                • Jul 2011
                • 6059
                It will be going through a ( 120 or 24 ) volt timer cube on it's aux contacts
                But the horn will be powered by the 24 volt switching power supply along with the 24 volt LED strobe light which will not be on a timer
                  • Jul 2011
                  • 6059
                  The horn will controlled by ( 120 or 24 ) volt timer cube with its aux contacts
                  The strobe will be controlled by the controller main contactor aux contacts of the unit that going on
                  and both of them being powered by the 24 volt switching power supply
                  I could do it the way you hook up relays to micro controllers up where you put a diode across the coil but I am not sure if this will take care of all transit voltage or not and I do not want to fry the strobe light or the switching power supply
                  This why I am asking these questions
                    • Jul 2011
                    • 6059
                    VDR's
                    I tried to google VDR ‘s and find what you are talking about
                      • 31163
                      try MOV's
                        • Jul 2011
                        • 6059
                        try MOV's
                        Would this work
                        https://www.digikey.com/product-deta...30K-ND/2798241
                        And this
                        https://www.digikey.com/product-deta...DICT-ND/190671
                        • redwire
                          • Dec 2010
                          • 3912
                          I would use a large TVS diode, 5000W peak-rated like 5KP24A
                          They don't conduct until 26.7V and deal with the -ve voltage spikes.
                          The smaller 3000W rated parts are OK but I did not see stock at Digikey.
                          These buzzers also make a lot of EMI from their contacts arcing, so the wiring to it will radiate EMI. So I would add a 0.22uF cap across the input too.
                          That would look like a TVS+cap across the buzzer's input connections.
                          If you want to be sneaky, solder them inside.
                            • Jul 2011
                            • 6059
                            I love it when a plan comes together
                            That is how I am going to do this it has a terminal block where the wires goes
                            Thanks for the info
                              • Jul 2011
                              • 6059
                              I want to thank everyone who helped with this problem that I need to resolve
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8297
                                This get's my vote. The MOV's are a little too "crude" compared to a TVS Diode. The TVS diode will measure open in both directions when good.
                                  The 5KP24A is UNIDIRECTIONAL so polarity must be observed.
                                  The BIDIRECTIONAL will show open circuit in both direction.
                                    • Jul 2011
                                    • 6059
                                    What would the part number be for this
                                    Is this what I am looking for
                                    https://www.digikey.com/product-deta...0CT-ND/6174240
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8297
                                      That one is ending with CA, so it is bidirectional.
                                        • Jul 2011
                                        • 6059
                                        Is this cap going to work
                                        https://www.digikey.com/scripts/DkSe...87845804219290
                                        • bialag
                                          Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                          by bialag
                                          I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                          Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                          03-25-2025, 05:56 PM
                                        • Stephen
                                          A2991 Logic Board issue, 20volts 0 amps help!
                                          by Stephen
                                          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                          09-10-2025, 03:16 PM
                                        • Stephen
                                          A2991 logic board issue, 20volts 0 amps help!
                                          by Stephen
                                          09-10-2025, 03:15 PM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • Mcfeetroy
                                          Fishing bite alarm drains battery
                                          by Mcfeetroy
                                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                          08-01-2025, 03:52 AM
