Antec advertises top quality Japanese capacitors in Signature Series PSUs
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Antec advertises top quality Japanese capacitors in Signature Series PSUs
    So in your particular PSU that particular series of YC are not sub par.
    And?
    Mann-Made Global Warming.
    - Dr Seuss
    • Oklahoma Wolf
      • Dec 2005
      • 353
      #42
      Originally posted by sLowEnd
      I dunno man
      I've had an old generic PSU with YC caps in the primary and they were still fine even when the PSU died after 4 years due to the fan
      I pulled two Viva brand primary filter caps that looked good yet out of a Deer once and tried to use them to fix a TV set. Didn't work.
      • i4004
        • Oct 2006
        • 2029
        #43
        primary caps fails rarely, even when they're from unreputable brands...
        can it happen?
        sure.
        does it happen a lot?
        surely not.
        when you have a voltage spike they'll get theirs, though...
        http://picasaweb.google.hr/i4004b3/V...ke_2008_12_30#
        same event, same house, same damage(just the primary cap and the smps ic)...
        so from the overall(small) number of primary caps damaged, those that were damaged by voltage spikes should be subtracted...
        • Scenic
          o.O
          • Sep 2007
          • 2642
          rule of thumb: if a primary cap popped, and you can definately say that it couldn't be caused by a voltage spike, there's something else seriously wrong with that psu..
          (even if it's just a dead fan in a PC PSU, but even then, the primary caps usually don't just pop open.. most of the time the primary and/or secondary switchers/diode packs fail first due to overheating..)
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            You don't get a lot of lightening storms there, do ya Scenic...
            LOL
            - Dr Seuss
            • grss1982
              • Mar 2007
              • 225
              • Philippines
              #46
              Originally posted by PCBONEZ
              CapXon are supposedly like Teapo and okay in PSU's.
              I haven't had that many CapXon is PSU's myself, that's what I've gotten reading in other places.
              About the time I'm thinking they are 'definitely' okay in PSU's I find out CapXon are a big problem in PSU's in various LCD TV's. - On the other hand those particular PSU's are usually passively cooled and run HOT.
              My best guess is CapXon are okay as long as there's a fan in the mix somewhere.
              A bit OT, but......IIRC CapXon caps feature prominently in HEC PSUs.
              CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
              GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
              Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
              • Gianni
                • Jul 2008
                • 681
                • Italy
                #47
                @ i4004: I suppose the primary caps in your pictures have burst due to a long period under overvoltage or they have been connected to a 220V plug instead of 110V or they were bad/faulty.
                What do you mean for "voltage spikes"?
                For me is an overvoltage with very short period, usually it is not able to burst primary caps like those in your picture.
                I ask because English is not my mother tongue and sometimes it is easy to misunderstood other people's post.
                Ciao
                Gianni
                "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                H. J. Brown
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #48
                  can it happen?
                  sure.
                  surely not.
                  looks more like damage from loss of the neutral.
                  several neighbors had this happen.usually just kills the filter cap and fuse.
                  will also kill control transformer for the hvac and the stby transformer in stereos.can you guess who got to fix all their stuff?
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    LOL
                    last real lightening storm we had here was AFAIR about a year ago.
                    last time it damaged electronics by the lightning hitting a power box .. uhm.,.. let's see... 2009 now.. so last time that happend *scratches head*.. over 4 years ago.. i think...
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      We actually have a lightening SEASON here that's 3 or 4 months long.
                      Lightening storm every 2 or 3 days for months.
                      We call it "Monsoon Season".
                      Might not be right overhead every time but close enough to see.
                      Trust me, lightening can blow primary caps - no problem!
                      Two years ago lightening took out the huge quart jar size cap in my 220v roof AC unit. Took out two 70 amp BUS fuses in the main AC box too.
                      Lightening didn't actually -hit- anything close to me as far as I know.
                      Was just unusually low altitude that day.
                      - Dr Seuss
                      • Hondaman
                        Japanese language -- Win7 or Linux Mint?
                        by Hondaman
                        I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                        Does anyone have experience...
                        09-12-2025, 04:32 AM
                      • AJ847.63e
                        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                        by AJ847.63e
                        Hi Folks,
                        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                        05-06-2025, 10:37 PM
                      • sirpsychol
                        Antec Earthwatts EA-380 smd element type/value
                        by sirpsychol
                        While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                        09-03-2023, 07:58 PM
                      • ajdrenter
                        Picking caps for Antec SU-380
                        by ajdrenter
                        In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                        https://www.badcaps.net/forum/showthread.php?t=14159
                        It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                        05-13-2023, 10:40 AM
                      • CWEastwood
                        Antec Smart Power SL300S capacitor replacement.
                        by CWEastwood
                        I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                        The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                        I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                        Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                        03-25-2023, 12:18 PM
