Been recapping this Topower https://www.hardwareinsights.com/top...z-350w-review/
Besides the usual I decided to put bigger input cap in but I got only large ones last week so besides drilling the holes for snap-in cap, I also cleared the space around a bit. What may actually be the problem is the small toroid coil between the input cap and the switching FET heatsinks: https://www.hardwareinsights.com/wp/.../Zevnitr-2.jpg I removed the plastic base, covered the coil with heatshrink and soldered directly into the board. Since than it has been assembled back together (hopefully correctly) yet the problem persist.
Now to the problem itself - PSU appears to be running, but the output voltages are just about 1/10 of nominal. I don't even get a fan twitch cause the O/P is too low. The SB rail works just fine.
So any idea what the problem may be? If it would be the coil it would make sense, it's part of the primary switching circuit.
And oh, also NTC replaced a wire jumper but the PFC circuit works fine, boosting to about 385 V when the PWR On is pulled down.
Half of the computer problems is caused by bad contacts
