Channel Well power brick.
    I picked up this PSU from a computer store in town today for $15. Unfortunately when I bought it home, it didn't work at all. It was dead and I got no response out of it whatsoever.
    It has a warranty and all, but i decided to be adventurous and crack it open. Also voiding its warranty but I don't really mind. I found a Fuhjyuu (can't spell it) cap that wasn't bulging, but had something like electrolyte crusted around the vent on the top. So I decided to replace that with a temporary cap for now. I decided to use some "Saturn" brand 470uf 16V cap in place of the 16V 470uf Fuhyjuu cap that was leaking.
    Then I discovered something else. There was a burn mark on the plastic shield that shielded the circuit shorting with the metal lining in the PSU. There also seemed to be smoke marks around the area as well.
    Right where the burn mark was, was where one of the coil legs was soldered to. The solder was cracked and obviously the leg no longer touched the PCB. So I decided to resolder that and then test it. Amazingly it came to life again and the green light was on. I measured the voltage and the output is 12.233V and steady on. I bought this PSU for my LCD monitor because it was rated at 12V 5A which was plenty for my 12V 2A LCD. Anyway, the connector didn't fit the plug, so I spent a good hours worth desoldering the old plug and using another plug from my broken ADSL router.
    So now everything is up and running well, so I am happy. But my question is that do I need to replace that "Saturn" brand 470uf 16V cap? or just leave it alone?
    And there are two 1000uf 16V Fuhyjuu caps in there. They haven't bulged or anything, but if I don't reaplce these two and they bulge or whatever, am I going to lose my monitor due to overvoltages or whatever?
    What was strange was that the store refused to sell me a similar Seasonic unit, but would only sell my the Channel Well unit. I've seen Channel Well built Antec units so I just presume they are good. And the unit does weigh a fair whack.
    Thanks.
    Re: Channel Well power brick.
    Hi Steve.
    Congratulations on getting it functional.
    Fuhjyyu branded caps are generally considered to be a "REPLACE ON SIGHT" brand.
    My advice is to replace any Fuhjyyu caps you find regardless of condition, but there are a couple of considerations:
    Voltage and Capacitance ratings should be matched, but the capacitor type is important as well. Most Fuhjyyu caps found in power supplies are marked "TM" or "TMR". The TM series is a "Low ESR" and "High Ripple Current" type, and it is important to use a similar type and temperature rating.
    Also, many Fuhjyyu caps are non-standard sizes, such as a 4700uf/10v in a 10mm diameter can. If there is absolutely no way to fit a standard 12.5mm or 16mm 4700uf cap in there, it is common practice to go down in capacitance but never voltage. (example- substitute a Samxon 3300uf/10v RS available from Badcaps)
    Have Fun,
    Keri
    The More You Learn The Less You Know!
      And replace the saturn caps too.
      Also find a way to put PSU in new metal case to cool it. I have been finding that 60W 12V & 5A bricks are dying from overheating.
      Cheers, Wizard
        I got in touch with my local electronics store and they have the exact low ESR caps I'm looking for. They are the correct size as well with the 1000uf 16V being 10x16mm and 470uf 16V being 8x16mm. Only problem is that they are "Suntan" brand caps. I've never heard of this brand and it would be good if someone could tell me if "Suntan" brand caps are reliable or not.
        Thanks.
          Still no go. Get them what we are telling all along. Panasonic, Nichicon, Samxon etc, have to order.
          I just sent "test order" money to big pope of kinda big order for us of 1000uF and 2200uF samxon GC and GD in qty of 100 total.
          Cheers, Wizard
