FSP FSP250-50GUB PSU arcing noise, system won't POST.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    I'm working on an FSP250-50GUB FlexATX\1U style PSU from a DVR.
    I don't know the history, only that it had seen rain, and I don't know for how long. I dried it out before powering it up and it seemed OK. But while the voltages seemed to be in spec, the system did not boot.
    With another, standard ATX PSU, the system worked fine.
    The capacitors were all OST, except a Rubycon, which looked like it may have been corroded\leaking. I replaced the lot.
    However, testing it soon revealed another problem. An intermittent arcing noise from the primary side. I haven't managed to track down the exact component, but it seems to come from the PFC section.
    I have checked the PSU in darkness and have been unable to see any spark or such.
    Waving my scope probe over the PSU shows bursts of random noise across what are otherwise clean switching waveforms. My current theory is that the arcing component is dumping noise into the power supply so much so that it is propagating to the outputs, and I guess that the output voltages are so noisy that the system won't run.
    I was going to try running the PSU without PFC, but the PWM and PFC controller are integrated into the same IC. Of course.
    Does anyone have an idea of how to track down the source of the noise and fault? Visually everything seems fine, so far.
    -David VanHorn
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    Re: FSP FSP250-50GUB PSU arcing noise, system won't POST.
    The photos...
    -David VanHorn
    • jazzie366
      • May 2016
      • 304
      Well if the voltages were fine, you replaced the caps and then you have a new problem. Either you fixed something and the problem was caused by you touching something, or the problem was there, just not as apparent.
      First thing I would check would be the places you put your soldering iron near, around all the leads of the caps. Check to make sure nothing got moved or undone by the radiating heat.
      The other thing is if water has permeated this PSU, especially rain, this makes me believe it could have left dirt and debris behind causing this. Rain is filled with tons of contaminates. I had rain get into a distributor cap on my car, the marking left behind caused the spark to jump from multiple places at a time, instead of being insulated from jumping to multiple places.
      Basically, clean the shit out of this thing, and see what happens.
      Another thing could be the chips arcing to one another. If that thermal compound goes conductive, or the insulating/thermally conductive pad or plastic behind it gets damaged from water or even age, it may have this problem as well.
      Popcorn.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5086
        • New Zealand
        I don't know if the arcing problem was originally there, but the PSU wouldn't run the system before I replaced the capacitors anyhow.
        The noise is quite faint and I tested the PSU originally in the case and wouldn't have heard it if it had already been present.
        I did clean the solder-side of the board already at least, thinking it may have been the issue, but it did not solve the problem.
        The joints all look great. It's rather strange.
        The three MOSFETs are plastic packages so should be no problem, the PFC Diode is not insulated but the cathode\tab is connected to heatsink anyway through the PCB, so the whole thing is meant to be live. But perhaps current is leaking from the heatsink to somewhere else.
        -David VanHorn
        • Behemot
          • 4845
          • CZ
          These things like clicking noises etc. are usually PFC problem, especially the coil. I had one such Enermax unit though and even replacing the coil did not help so who knows what was bad…I can imagine some of the film capacitors may have internal arcing though, it would make sense. They are important part of the circuitry, in newer designs they actually move the power to the transformer through them and thay can rarely fail in such manner.
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            check out d11 d10 .looks like someone has messed with them .
            • Agent24
              I see dead caps
              • Oct 2007
              • 5086
              • New Zealand
              I remember that, which is why I'm suspicious about it being the PFC coil, also considering it has no signs of physical damage. I'll have a look at the capacitors. Hmm...
              Wrong thread? Or did I miss something?
              -David VanHorn
              • Behemot
                • 4845
                • CZ
                I guess you can only try replacing components one by one, if you have the time…
                • Longbow
                  • Jun 2011
                  • 623
                  This is not a troubleshooting technique. Besides, you will certainly ruin more things than you fix.
                  You have to decide if the noise is arcing, or a rather normal sound from the switching section when it becomes intermittent.
                  I agree someone has been replacing parts. Going directly to those areas first is a good idea (check the insulator on the back of the TO-220). Incorrect parts substitution will cause the supply to behave this way.
                  One approach is to look at the board in the dark - you might see the arcing that way. One more way that is easy is to use a piece of rubber tubing and listen to various spots on the board. I'll bet you can isolate the part very easily that way. But noise by itself does not mean something is arcing.
                  Is it plugged in?
                  • Behemot
                    • 4845
                    • CZ
                    Good luck with that.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5086
                      • New Zealand
                      I can't be sure it's 'arcing' but I can be sure I have never heard such a sound from a normally operating PSU or other equipment before.
                      I have tried running it in the dark and could see nothing.
                      Nothing has been replaced except the capacitors. The solder joints were factory with no signs of rework. I do not believe the transistors\diode are anything but original. There is no insulator. The heatsink is tied to the 'B+' rail anyway.
                      I tried a cardboard tube and it sounded like it was coming from everywhere. But I could try a rubber tube...
                      -David VanHorn
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        You have a Samyoung filtering capacitor for the APFC.
                        Not saying that this is the cause of the problem, but I feel that it certainly is worth mentioning . (Especially after seeing enough APFC circuits hosed by bad caps.)
                          AM radio is a good electrical arc detector.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5086
                            • New Zealand
                            I did check capacity and ESR earlier, and found no problem.
                            But maybe it is breaking down under full voltage somehow? Or high leakage under full voltage? Hmmm...
                            -David VanHorn
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              brown glue corrosion on input choke.
                              look for more elsewhere.esp pfc.
                              and these are known for pfc overshoot due to glue.
                              cap will arc internally till it explodes.
                              fixed quite a few of these in industrial stuff.
                              the big cap will literally explode.so watch your face/eyes!
                              • Behemot
                                • 4845
                                • CZ
                                I see silicone in there but maybe my glasses are too weak?
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5086
                                  • New Zealand
                                  I can't see any brown glue, but you're right, the input choke does seem to have been slightly damaged. I am not sure by what, though.
                                  PFC voltage is only 390v while the capacitor is rated 450v, so unless there are big spikes? Maybe the capacitor is just failing by itself. Will replace it and see.
                                  Be fun to get a x100 probe and have a look at it too...
                                  -David VanHorn
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Can get them quite cheap from fleebay. Some people express concern about the resistor insulation voltage quality, so far both me and my scope survived…
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Well, I don't know if this is related or not, but just saw a PSU at work today with a vented primary cap. It was a Taiwanese brand, so I am not surprised. Will try to take my camera next week and snap a few photos (and maybe even try to fix it, even though we are not allowed to mess with recycle stuff).
                                      • Behemot
                                        • 4845
                                        • CZ
                                        That's not surprising especially if it's C(r)apXon.
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • disorder
                                          BN44-00482B makes some arcing noise
                                          by disorder
                                          hello guys,
                                          need some advice here, for a BN44-00482B samsung power board
                                          the tv works normaly but we can here a noise comming from the power board.
                                          this noise is not permanent, seems like some arcs, but there is no arcs really.
                                          this noise comes from the bottom left of the board near the AC connector.
                                          and most likely from tha capacitor just after the rectifier, it is marked : 2W 474K sic 610S on it, a plastic capacitor 450V/474nF.
                                          if i press on it, the noise change, sometimes more higher and sometimes disappears. if i stop...
                                          10-22-2020, 05:35 PM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
