BN44-00482B makes some arcing noise
  • disorder
    • Sep 2015
    • 156
    • france
    hello guys,
    need some advice here, for a BN44-00482B samsung power board
    the tv works normaly but we can here a noise comming from the power board.
    this noise is not permanent, seems like some arcs, but there is no arcs really.
    this noise comes from the bottom left of the board near the AC connector.
    and most likely from tha capacitor just after the rectifier, it is marked : 2W 474K sic 610S on it, a plastic capacitor 450V/474nF.
    if i press on it, the noise change, sometimes more higher and sometimes disappears. if i stop the presure, the noise is steady.
    the noise not change if i press filters at the same place.
    do you think this caps is near dead ?
    not so easy to find the same in the shop, i've got only 450V/684nF capacitor from other board (that they are after the rectifier too on the circuit)
    thank you guys :-)
  • nomoresonys
    • 12206
    • U.S.
    Re: BN44-00482B makes some arcing noise
    I'd try that replacement cap, see if it goes away.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Check the solder joints in that area. If you have an insulated rod then you could put pressure around that area to see if you can determine the exact spot. It may be something on the underside of the board.
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        try to resolder the inductor coils near that noisy thing. hope it solves the issue
        • disorder
          • Sep 2015
          • 156
          • france
          hello
          finally solve this. you're right : solder joints were bad, making some circles in thin. many of them
          so i resoldered all of this crappy ones, and now the TV don't cry anymore !!
          thanx guys !
          • nomoresonys
            • 12206
            • U.S.
            Glad to hear it, yep, solder joints should usually be checked first, easy to do and don't cost anything and can save a shitload of unnecessary further troubleshooting.
            • Duranitron
              • Jul 2014
              • 544
              • Philippines
              Good Job!
              • tony359
                by tony359
                11-28-2023, 05:18 AM
              • MegaZAC
                Onkyo TX-SR805 noise in one channel
                by MegaZAC
                Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                There's some logic behind it. As soon as I select an input I get only left...
                04-23-2025, 10:09 PM
              • courtcircuit
                Philips HTS8000 home cinema noise problem
                by courtcircuit
                Hello
                I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                Removed each of tyhe boards
                02-08-2025, 08:22 AM
              • karatzdi
                Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                by karatzdi
                I know some might say... just buy another one. Sell it as parts..!
                So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                Spent some time downloading the Service...
                06-11-2024, 08:38 AM
              • Biruslapio
                LG 50PB690 power supply terrible noise
                by Biruslapio
                I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
                As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
                I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
                07-13-2022, 12:46 PM
