DC boost converter max power ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: DC boost converter max power ?
    I'll read later on...too many informations and making all more complicated
    • Khron
      • Sep 2006
      • 1350
      • Finland
      #122
      Originally posted by bianchi77
      Why are you asking ?
      I'm asking because some of your posts are difficult to understand / easy to misunderstand. And there's a possibility you haven't completely understood some of our (other people's) posts.
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • bianchi77
        • Jun 2016
        • 1121
        Yup I don't understand your post
        • bianchi77
          • Jun 2016
          • 1121
          Is it possible only using 1 FET and resistor voltage divider for making MC34063 doing the step up ? if more than that, what's the different with 555, I got 220V with RL = 6K now..
          my inductor is not perfect that's why the output is not good, a lot of flux loss
          I have 8 inductors in series for 380 uH value.
          • bianchi77
            • Jun 2016
            • 1121
            thanks for all the infos, this one is similar :
            http://radioactiveathome.org/en/hard...r-with-a-choke
            that's PNP transistor functioning as a follower for making FET switching faster
            • Khron
              • Sep 2006
              • 1350
              • Finland
              #126
              ... And how is that so different about the circuit in post #105?
              http://darkside.higashino.jp/resourc...se/chopper.gif
              Wow, another PNP driving a FET.
              The other two circuits, from post #49:
              https://www.birdandgua.net/bird/wp-c...05/image39.png
              http://www.mikrocontroller.net/attac..._180V_25mA.png
              The same basic topology. Coincidence?
              PS: You can't have feedback without a resistive divider from the output, so... I'm not really sure where your question comes from, or what it's about.
              You have at least THREE (now FOUR, with this last one you found) designs ready-made for you. What more do you want???
              • bianchi77
                • Jun 2016
                • 1121
                Those designs are basically has the same way with 555...
                currently I'm using 700uH hand made inductor but I can't increase voltage anymore, stack on 185V on 5K RL,
                I'm not sure, I will get a better result with those chips but I will give a try
                  http://www.learnabout-electronics.org/PSU/psu32.php
                  Read: Boost converter Operation/example.
                  You should get a generator to drive the MOSFET and vary the ON/OFF time to see the effect.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    How can I add TL 431 and optocoupler for feedback?
                    Inspiration :
                    http://u.dianyuan.com/bbs/u/68/2457951218099004.gif
                    but not sure if it's the right way modifying my voltage divider..
                    • bianchi77
                      • Jun 2016
                      • 1121
                      @budm, thanks for the book
                      • bianchi77
                        • Jun 2016
                        • 1121
                        can it be :
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          #132
                          Why exactly do you want / need opto feedback?
                          Compensating the TL431 is only gonna be one extra headache, which i don't think you really want, considering all the previous adventures...
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Okay, I only want to know how that coupler and TL431 work, is that the right circuit ? more or less ?
                            • bianchi77
                              • Jun 2016
                              • 1121
                              I got 207V , RL = 2K and f = 13.14 KHz, it's less efficient but it does the job..
                              and abit noisy with low frequency
                              • bianchi77
                                • Jun 2016
                                • 1121
                                It will relate with control system loop with feedback, bode plot ,pole, zero, aha so that's the way it works, return again to the math
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  I know that and I hate that headache, because it's good for learning and understanding but not earning at all..
                                  Had you done any opto and TL431 before ?
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    One question : does f pole equal to f switch ?
