Ultimate PSU Overkill
Re: Ultimate PSU Overkill
That's what happens when they let kids use calculators in school.
Can use a PC but can't handle 3x26=? without help.
.Mann-Made Global Warming.
- Dr Seuss
Heh.
If you choose all the high end stuff like extreme Qxxxx cpu (they're over 125W), full load of ram, and 2 or 3 150W plus video cards like 8800's or so. And bunch of hard drives, then you will be easily touching above 600W range even more.
More efficient if one is using 220VAC instead of 115VAC.
Cheers, WizardComment
Wow that's insane! Modular connectors how advanced.
I have them on my Antec Smart Power and didn't blow 400 bucks on it either!
Geez look at that plug what are you powering an air conditioner?
Wow a 20 Amp recepticle plug they are as mystical as unicorns!!! That's not actually a thing to hype up.
Especially when the average user purchasing the product has probably never seen one.
My service panel is crowded enough with extra circuits I've added. Trying to find a space on the neutral buss bar is harder than solving a Rubix cube.
No way I would ever run a dedicated line to my computer.
What's next mini fusion reactor PSUs?
Last edited by Krankshaft; 09-29-2008, 04:07 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
- Dr Seuss
Originally posted by PCBONEZLaptops with gas engines.
Listen to that baby purr!
It's so worth the hearing loss!
Last edited by Krankshaft; 09-29-2008, 09:21 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Awesome. I'd get one of those just for the shock factor.
"Yep, I run 220 to this thing. Dedicated circuit. This computer draws that much power!"
Or, I could go jump start my car...A man convinced against his will is of the same opinion still.Comment
He doesn't know what 26 multiplied by 3 is equal to: this really worries me
BTW some claims are unclear if not lies at all:
- nVidia states the maximum power draw for the GTX280 as 236 W, roughly 20 A at 12 V: the 26 A at 12 V requirement is nowhere present on nVidia site, I suspect he's referring to an heavily overclocked model from EVGA;
- modular cabling isn't a novelty anymore and, moreover, I don't understand why the 24-pin ATX cable is modular too;
- the psu has 6 6-pin connectors and only 2 8-pin ones: without adapters it can power only two high end graphic cards, if you want a 3- or 4-way SLI or Crossfire you'll need adapters;
- PSU's max power would be an exaggeration even on a gamer's dream machine with 4 way SLI, overclocked quad core, 6 hdds in raid 6 and water cooling: maybe some overclocking contest concurrent may require this monster to push cpus at 7 GHz on liquid nitrogen, but most gamers, overclockers and Average Joe don't ...
ZandraxLast edited by zandrax; 09-29-2008, 11:25 AM.Have an happy life.Comment
I want to see their faces when the probably cheap Chinese or Taiwanese caps inside that thing blow up like firecrackers and overvoltage takes out all of their HDDs, SLI graphics cards, and reduces their mobo and CPU to a lump of smoking plastic.
I can dream.
I haven't seen pics of what's under the hood on this supply but I guess anyone stupid enough to buy it is not smart enough to open it.
Look on the bright side though that PSU could probably supply the 1.21 gigawatts needed to get back to 1985.
Last edited by Krankshaft; 09-30-2008, 12:39 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Originally posted by i4004most interesting thing:
somebody will actually buy this...piece of crap...
hehe...
Originally posted by KrankshaftI haven't seen pics of what's under the hood on this supply but I guess anyone stupid enough to buy it is not smart enough to open it.
Originally posted by KrankshaftLook on the bright side though that PSU could probably supply the 1.21 gigawatts needed to get back to 1985.
ZandraxHave an happy life.Comment
Holy shit!
The thing draws more power than the PSU in my Silicon Graphics Onyx workstation, and that thing gives off more heat than a nuclear reactor!
Still, I bet you we will get a few cheap people who will just swap the receptical on the wall or use a different power cord and proceed to burn their house down.Find Nedry!
Check the Vending machines!!
1600W: this means that in case I bought such a monster, when I switch it on I have to check if something is already on (dishwasher, washing machine, TV) otherwise I will cause a blackout...
I'm happy to have a PC that probably consume only 150~200W because I already paid a lot for power.
Ok... if you have a 1600W running maybe you can save some money for warming up your flat in winter... but in summer I want to see you sit near it without air conditioning
Gianni"In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
H. J. BrownComment
Originally posted by zandraxLet ask Jonny if he can test one of those?
Originally posted by i4004somebody will actually buy this...piece of crap...Last edited by Oklahoma Wolf; 10-01-2008, 08:35 AM.Comment
So the [T] did a review. I'd like to know how long until those Teapo's that they love so much over there crap out. I just cannot see giving a gold award to something with Teapo's.
And in case anyone didn't catch it before, I was being sarcastic in my other post...A man convinced against his will is of the same opinion still.Comment
I have yet to see a computer SMPS fail with bad Teapos. Not saying it doesn't happen, but I won't knock them for being used in PSU's because of failing on mainboards.
Actually, I even have a 4 year old FSP 530W that has nothing but Teapo in it, and was run 24/7 for most of that time. I recently threw it on the SunMoon and scoped the outputs... it's still holding ripple and noise well within spec. I've had to replace the fan bearings on it twice, but the caps are all fine.Comment
Originally posted by Oklahoma WolfI have yet to see a computer SMPS fail with bad Teapos.
Teapo's might not be absolute garbage like Fuhjyyu, but they're sitll nowhere near the likes of Rubycon or Panasonic.A man convinced against his will is of the same opinion still.Comment
Originally posted by acstechI have, several times actually. Just because you haven't seen it, doesn't mean it doesn't happen.Last edited by Oklahoma Wolf; 10-01-2008, 12:35 PM.Comment
This specification for the ASUS ROG GX501VI-Ultimate-01 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GX501VI-Ultimate-01 boardview and GX501VI-Ultimate-01 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:46 AM
by GuestHello all!
Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it.... -
I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
Apologies if this is the wrong subcategory....-
by higuysHi everyone, I posted this over in AVSForum and someone mentioned I should try posting here. Does anyone have Sunfire Ultimate Receiver Firmware update 3.22? Sunfire only has version 3.20 on their website, I was told by one of the few people that worked on these units 3.22 is the latest version but his computer just stopped working. I've emailed Sunfire several times and they won't respond or update the version on the site. Any help is much appreciated!
I'm desperately trying to get my CH341A to work, but it seems that all my attempts have failed. Despite everything, I want to check that it works, the aim being to read at least one chip and “screenshot” the configuration for me to use as a reference.
Here are the steps (software part):
- I'm running Windows 11 Pro 64-bit (10.0 build 26100)
- Drivers are installed (no error messages) and there are no problems in the Device Manager.
- Set the language to English (to avoid the CH341A's basic software bug)
- Does not work on AsProgrammer...3 Photos - Loading...
