Determining a faulty capacitor
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Im working with one of these amps: no power. Turns out a faulty transistor and blown fuse. Replaced both but still no power. On further testing, red circle is damages. How to know what to replace with? Yellow oval is the transistor ive replaced. Transistor was a NDF04N60ZGOS-ND.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
    Re: Determining a faulty capacitor
    So that C105 snubber cap shorted out too beside the MOSFET?
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      So where is the brown wire connected to one the board?
        BTW, that big MOX resistor for the Source pin of the MOSFET is still showing <1 Ohm?
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          Yes. On MM is show up as DISC or DESC, not sure but it's gone.
          It's just for the fuse. Original fuse was a 2a. Now Im temp using a 1amp.
          That resistor is fine to be honest. I think it's showing 3K, Im not at work to confirm. But Im pretty sure it's ok.
            I do not understand what you mean, Disc. Bottom line is the cap shows resistance reading or not. So what resistance do you get on the cap?
            • speedypro
              • Feb 2013
              • 561
              • United Kingdom
              I'll let you know when I'm at work later.
                That power MOX resistor if I am correct, it should be connected to the Source pin of the MOSFET, when the MOSFET shorted out it will also cause the resistor to go open citrcuit. It should be very low resistance of less than 1 Ohm.
                • speedypro
                  • Feb 2013
                  • 561
                  • United Kingdom
                  Yea it was burnt. I part of the outer part was blown off. I'll confirm in 5hrs time.
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    No resistance for cap. Resistor has about 16Meg Ohms (tested in circuit).
                    • CapLeaker
                      Leaking Member
                      • 8146
                      that resistor is FUBAR
                      • speedypro
                        • Feb 2013
                        • 561
                        • United Kingdom
                        LOL! Ok so what about that cap?
                          • 31012
                          probably fine.
                          • Prolog
                            RTX 3080 FE Identifying capacitor
                            by Prolog
                            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                            I hope these photos make it clear which component I am referring to:
                            (yes, the soldering is a bit botched from removing the blown one, I know)
                            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                            12-01-2024, 08:27 PM
                          • nev1001
                            What zener diode might fix the sound on Maestro Mayhem gaming chair?
                            by nev1001
                            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                            I think an issue could be a zener diode (or capacitor) which has shorted out.
                            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                            04-17-2025, 05:09 PM
                          • repair-it
                            Need help determining capacitor value 10C
                            by repair-it
                            Not sure what the value is for these caps labeled 10c. I know the WJ is 16v....
                            05-29-2025, 05:01 PM
                          • chth96
                            If I replace with inferior capacitor, Is it No harm to other IC components at all?
                            by chth96
                            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                            I know that these capacitor will not last as long as nichicon capacitor...
                            12-22-2023, 04:34 AM
                          • chth96
                            How can I test non-polarized capacitor?
                            by chth96
                            I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                            I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                            And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                            I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                            06-02-2024, 07:31 PM
