Could use some psu help
  • junktv
    • Nov 2010
    • 3065
    Re: Could use some psu help
    Well wouldn't you know i screwed up. I know surprise. I added a cap to that spreadsheet but forgot to put it in the cart.
    So I had a 13mm high PW 470uf 10v picked out for the ultra PSU and forgot but did order a FR 470uf 16v that was to replace a OST on the motherboard. I have a brand new ZL 470uf 25v , a MCZ 470uf 16v and a KZE 470uf 35v although it is big and 5mm lead space. I also have lightly used 470uf 16v rifeking.
    What would you guys do?
    Btw this one said low esr also but didn't see it till I pulled it.
      • 31020
      Fr
      • junktv
        • Nov 2010
        • 3065
        Then what for the board?
          • 31020
          no idea.
          but as for the psu, the ZL is probably too big,
          the MCZ is way too low esr.
          also obsolete so i dont know where you found it.
          the KZE is too big,
          rifeking - never heard of them!
            • 31020
            ah - what series is it?
            http://www.paullinebarger.net/DS/Rifeking/
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #46
              Well, from what I can see, the 16V 470 uF Panasonic FR is to replace the 16V 470 uF OST RLG cap by the AGP slot on your motherboard - is that correct? If so, then you can just leave that OST RLG cap on the board, since it only filters 12V to the AGP slot and it isn't that important, even if it failed.
              So then you can put the FR in the Ultra PSU and be done with it. And if bad really comes to worse and that OST RLG cap bulges on the motherboard, then you can swap it for the Rifeking or something better.
              Don't worry, everyone makes mistakes. I myself always forget to buy something when I make these orders or occasionally don't buy the right parts.
              • junktv
                • Nov 2010
                • 3065
                Correct the FR is for the OST RLG near AGP. The board and bestec are more import to get done fast so may hold off on the ultra for now unless the ZL will work since it fits. Maybe I can find one although no luck locally. Also found 15 little 100uf 10v teapo caps on my 939 board so that may be another project i'd have to order parts for. It's also what the Ultra will power.
                I'm shocked I didn't miss more honestly.
                stj, The ZL actually fits the PSU although it is a 10mm. The MCZ and ZL's I got years ago. The rifeking has no markings for series it's like a brownish grey and came off a video card.
                  • 31020
                  you could use the ZL then.
                  • junktv
                    • Nov 2010
                    • 3065
                    Well i noticed something when i pulled these. Why would a cap be wrapped?
                    It's c45 has a question mark.
                      • 31020
                      FSP do that, i suspect it may be for thermal protection to make it last longer.
                      if not, i'm open to other ideas!
                      • junktv
                        • Nov 2010
                        • 3065
                        Seems holding in heat would make it worse. Although the 5vsb on these seem to like heat but that may have been due to the exploded or bad caps. All the solder joints looked ok.
                        Seems they wanted airflow as the caps were all raised off the board aswell.
                        Btw that is a pre clean up pic.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #52
                          Could also be electrical isolation. The case on most modern electrolytic caps is not directly connected to negative, but usually there is good conduction path between negative lead and case... so that could be one reason, especially if the cap is in an area in very close proximity to bare jumpers or "live" heatsinks.
                          That said, if you really want to keep things original, you can cut the sleeve, remove it, and fit it on the new cap,
                          Yes, personally I don't see how the sleeve helps to protect a cap from heat. If anything, I think you are right - it will probably hold more heat in.
                          • cap__
                            Can I replace 15uf capacitor with 22uf?
                            by cap__
                            "If I wanted to replace an old 15uF/400V capacitor with a new one,
                            I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                            11-29-2023, 11:16 AM
                          • Cory Marqusee
                            MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
                            by Cory Marqusee
                            Hi Everyone,
                            I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
                            How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
                            I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an...
                            09-15-2022, 02:03 PM
                          • ajdrenter
                            Picking caps for Antec SU-380
                            by ajdrenter
                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                            https://www.badcaps.net/forum/showthread.php?t=14159
                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                            05-13-2023, 10:40 AM
                          • iMic
                            Vintage AT Power Supplies - Selecting Capacitors
                            by iMic
                            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                            02-19-2023, 06:45 PM
                          • Rugon
                            Question about DR-8460BTX
                            by Rugon
                            Hi. I found this psu a DEER DR-8460BTX and I know it's a very low end power supply but I want recap it, obviously without spending too much because probably the capacitor cost more than PSU 🤣. inside of the PSU Inside the power supply has them all Yang chun caps:
                            X2 200V 680uf
                            X3 50V 2.2 uf LE
                            X1 50V 22uf LE
                            X2 50V 1uf LE
                            X1 10V 1000uf LE
                            X1 50V 47uf LE
                            X1 50V 10uf LE
                            X2 10V 2200uf LE
                            X1 16V 2200uf
                            X1 16V 470uf LE
                            I had 2 questions about changing the capacitors though ... Does LE stand for low ERS?
                            Can...
                            11-06-2022, 12:55 PM
