Could use some psu help
  • junktv
    • Nov 2010
    • 3065
    Re: Could use some psu help
    Thanks, momaka. I really do appreciate yall helping me.
    I found a link on these with a mod. Seemed reasonable so ground a tiny bit to drill holes so i could move c36 (i think) the 2200uf 10v over on the trace away from the heatsink.
    https://www.badcaps.net/forum/showth...ec+ATX-250+12Z
    I am going to replace a bunch of mother board kzg caps that are blown with nichicon HM. I noticed my other motherboard is full of HM other than a couple sanyo and runs like a top. The board that needs fixed has a couple OST RLG and a RLX. Think HM will work there also? Sorry for tossing that in there.
      • 31303
      HM may be too low esr
      • junktv
        • Nov 2010
        • 3065
        For a p4sd-la motherboard? Ah i dunno i'll keep that in it's place and out of here. This thread already got moved. If it helps others and that mod works it will be another confirmation.
          • 31303
          my mistake, i thought you wanted to put them in a psu.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Yes.
            The P4SD series motherboards are generally well-designed. I've done a full poly-mod on the P4SD motherboards from HP DC5000 / D530 machines and it works great too.
            • junktv
              • Nov 2010
              • 3065
              I've been looking at caps for the power supplies and you guys have given too many options and all have a wide range of ripple and impedance. Atleast the jamicon tk seem like general caps that say high temp high reliability. I've read that adding too low of esr and impedance can be bad in power supply. All of the FR and i think FM, FK and fc are lower impedance than say PW. The nice part is some are smaller and closer to the dimensions of the TK that are in the bestec and jee in the ultra in some cases. Would these be low enough esr and impedance to cause a problem?
              • junktv
                • Nov 2010
                • 3065
                Am I too worried about esr and impedance on these power supplies? Hate to wake up fried like a piece of bacon.
                  • 31303
                  i have used FC and FK loads of times - no problem.
                  only done a couple with FR - being newer.
                  still no issues seen.
                  if it works when you power it up - it will stay working - no need to worry about later.
                  • junktv
                    • Nov 2010
                    • 3065
                    Good to hear on the FC because i had 2 2.2uf 50v from something else left over.
                    Just seen so much variation from the huge list you guys gave that i started reading more. Then ran by that impedance esr thing. I know they aren't all designed the same so figured i'd check for these 2 power supply's.
                    They both worked when i took them apart with the bestec having a 5vsb problem. The ultra will be on a motherboard and cpu I like.
                    Not sure how you guys look at data sheets, digikey list and spread sheet for hours and hours.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #30
                      It *can* be bad, but it won't be catastrophic. Sorry, no explosions (that's only material for an 80's action movie ). All that very low ESR caps can do is cause some PSUs to output a bit more ripple ripple than with their stock caps (when they were still okay). Or at worst, you may get oscillations and the PSU won't start. But I know only one PSU manufacturer that makes such picky PSUs: Sirtech (especially the High Power platform based on h-bridge designs). Every other PSU I have worked on has had NO problems with very low ESR caps (sometimes even motherboard grade caps when I felt like experimenting).
                      For the Ultra PSU, I don't know as I haven't worked on one before and don't know who made it.
                      But for the Bestec, pretty much anything in that list I put above will be fine. In fact, I even used a few Nichicon HN and HZ in a Bestec ATX-300 12Z when I ran out of caps. That aside, I also have a recapped Bestec ATX-250-12Z Rev-D2R, which I did with a wide mix of cap brands and series (basically whatever I had on hand). In particular, I used 6.3V 2200 uF Panasonic FM for the 3.3V rail, 10V 2200 uF Chemicon KY for the 5V rail, and one 16V 2200 uF Panasonic FC + one 16V 1500 uF Panasonic FL or the 12V rail. Don't remember what I used for the other rails. That said, here is a cap diagram I did based on my recapped Bestec PSU:
                      https://www.badcaps.net/forum/attach...1&d=1471119216
                      That big cap at the top is the 16V 2200 uF Panasonic FC, which is 12.5 mm in diamater. I managed to fit it in, despite the board being marked only for a 10 mm cap. If I remember correctly, though, I did have to remove the self-loading circuit on the -12V rail for that cap to fit (the self-loading circuit on the -12V rail consists of a transistor, a large resistor, and several smaller SMD resistors and a zener... but you only need to remove the transistor and large resistor, or you can move them someplace else in the PSU with long wires).
                      For caps under 100 uF, I usually don't even worry if they are low ESR or not. I just make sure they are rated for 105°C. (Of course, I do try to get low-ESR caps even for the small ones, since it's usually cheaper and they can handle more ripple current.)
                      • junktv
                        • Nov 2010
                        • 3065
                        Thanks for the info on why. I know from reading reviews high ripple is bad. How I understand it, it's like distortion in speakers. So low impedance is low esr or only those that say low esr?
                        Looks like the ultra is made by wintech since UL is E178768.
                        Seen that pic and the thread but some of the caps mentioned i think were ZL which i don't see on the list at digikey. What do you think about moving the c36 2200uf 10v up the rail and away from the heat sink mod? https://www.badcaps.net/forum/showth...ec+ATX-250+12Z
                        HZ is one i picked for the motherboard the bestec runs. It's in the asus section with a pic of the list and what goes where and notes. www.badcaps.net/forum/showthread.php?t=57191
                        Thanks for explaining more.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          Ripple and noise simply indicates the instability/ small deviation in a DC voltage (i.e. a 5V line can become 5.01V one instant and then 4.99V the next, and so on.). The higher the ripple/noise, the bigger the deviations will be from the DC voltage.
                          In computers, this matters, because they communicate with 1s and 0s. In the physical circuit of a computer, this is represented by a presence of a voltage (1) and lack of voltage (0). When you have too much ripple/noise, however, the voltage to the chip can become unstable enough that the chip sends out a 0 instead of a 1 (perhaps due to a drop in line voltage) or send a 1 instead of a 0, if a spike from the ripple/noise voltage goes too high.
                          Anyways, that said, low ESR caps won't cause excessive ripple/noise in most PSUs. They *may* just cause a tad bit more noise than when the PSU had the original caps (before they failed). So you need not worry about the cap impedance/ESR that much. I have seen (and sometimes even used) just about every capacitor in that list above in various power supplies.
                          At relatively high circuit frequencies (typically in the tens to hundreds of KHz range), the impedance value of a capacitor becomes nearly equal to the ESR value. So for all practical purposes, we can say that ESR = impedance at high frequency. Hence why you see people here sometimes use the terms interchangeably.
                          I have no experience with Wintech PSUs. But it's not Sirtech, so I don't think you'll have any problems. If you really want to play it safe, use these caps and series:
                          Panasonic FC
                          Chemicon KY, LXZ, LXV, LXY
                          Nichicon PW, PS, PM, PJ, HE
                          Rubycon YXJ, YXG
                          Most of these are from the "oldschool" low ESR era. So they are pretty safe for PSU use.
                          ZL is a straight equivalent to Chemicon KZE and Nichicon HD
                          It's a good trick to keep that capacitor cool. But even if you don't move your new cap in that spot, the PSU should still last a long time. The main problem behind that cap cooking is because Bestec used crappy caps. And the conductive brown glue. In fact, I think you should more about removing the conductive brown glue first. It's a PITA on some of these older Bestec power supplies. (However, still worth the effort, IMO, as Bestec PSUs are designed well otherwise and will handle the state power on their label with no problem).
                          Alright I'll have a look in there in a bit.
                          HZ is fine, as should be HN and HM.
                          • junktv
                            • Nov 2010
                            • 3065
                            Huge thanks. Ill get the rest of my list together this weekend and with any luck with know if it works or sparks next weekend.
                            • PeteS in CA
                              • Aug 2005
                              • 3586
                              • USA, Unsure of Planet
                              #34
                              Given the age of the PSU, I'd go with Nichicon PW, Panasonic FC, or United Chemicon LXZ. They should be available from Digikey or another distie. As "plan B", Nichicon PA (no 50V parts in this series) or HE, Panasonic FM, Rubycon ZL, or UCC KY or KZE are lower impedance, but not too extreme, and all are 5000-10000 hour series (similar to PW, FC, and LXZ). I don't have anything against Rubycon, but I don't know if they have a series that is equivalent impedance to the PW, et al.
                              PeteS in CA
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                #35
                                YXJ series. According to Digikey/Rubycon, YXJ is the updated version of YXF.
                                (See this: http://www.digikey.com/en/product-hi...ies-capacitors)
                                So YXJ is equivalent to Panasonic FC and Nichicon PW/PJ/PS/PM, more or less.
                                I keep trying to update the above list I made, but new series do come out now and then. Looking through my datasheets, I just noticed that Nichicon (U)PA seems like another choice. According to Nichicon PA spec sheet, PA is a slightly lower impedance version of PW.
                                  • 31303
                                  i use YXJ for 1uf and 2.2uf because Panasonic dont make caps now below 4.7uf
                                  • junktv
                                    • Nov 2010
                                    • 3065
                                    Looks like the 0.1uf 63v 5ma ripple 105c are impossible to find replacements for so thinking leave them.
                                    Has 4ma ripple but 85c.
                                    https://www.digikey.com/product-deta...8-1-ND/5728705
                                    Higher temp but 1.3ma ripple.
                                    https://www.digikey.com/product-deta...2-1-ND/5728905
                                    For the rest of the smaller ones PW seems to work.
                                    Looks like KYB are the closest to the 10x25mm 2200uf 16v I can find. Is a zls and zlq that might work but being z are low esr I think. The ZLQ is closer to current size.
                                    http://www.digikey.com/product-searc...0&pageSize=500
                                    Still trying to decide on the 2200uf 10v 10x20mm. Size is much taller on most which might be an issue as the wires would have to go up over them then come down to exit the case. YXJ looks like a good match at 10x22mm.
                                    Since there is no way of knowing what series the jee are in the ultra and some do say low esr i'm thinking FR's for it on the larger sizes.
                                      • 31303
                                      .1uf 63v - maybe use a film cap like polyester or polypropylene
                                      • junktv
                                        • Nov 2010
                                        • 3065
                                        Well I changed it up a little on the power supplies. Does this look like it will work? Wondering if the UCC KY's will be low ESR enough for the 2 2200uf 10v jee's on the ultra.
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          • Bulgaria
                                          #40
                                          The JEE may say low ESR on them, but they are probably barely better than general purpose caps. Regardless, Chemicon KY would be fine. I never had a PSU reject those.
                                          Also, for caps under 1 uF, you can easily find polyester/polypropylene/metal film cap replacements. Here are two suggestions for the 0.1 uF and 0.22 uF caps:
                                          http://www.digikey.com/product-detai...863-ND/2571298
                                          http://www.digikey.com/product-detai...686-ND/3724604
                                          • cap__
                                            Can I replace 15uf capacitor with 22uf?
                                            by cap__
                                            "If I wanted to replace an old 15uF/400V capacitor with a new one,
                                            I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                                            11-29-2023, 11:16 AM
                                          • Cory Marqusee
                                            MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
                                            by Cory Marqusee
                                            Hi Everyone,
                                            I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
                                            How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
                                            I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an...
                                            09-15-2022, 02:03 PM
                                          • ajdrenter
                                            Picking caps for Antec SU-380
                                            by ajdrenter
                                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                            https://www.badcaps.net/forum/showthread.php?t=14159
                                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                            05-13-2023, 10:40 AM
                                          • iMic
                                            Vintage AT Power Supplies - Selecting Capacitors
                                            by iMic
                                            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                            02-19-2023, 06:45 PM
                                          • Rugon
                                            Question about DR-8460BTX
                                            by Rugon
                                            Hi. I found this psu a DEER DR-8460BTX and I know it's a very low end power supply but I want recap it, obviously without spending too much because probably the capacitor cost more than PSU 🤣. inside of the PSU Inside the power supply has them all Yang chun caps:
                                            X2 200V 680uf
                                            X3 50V 2.2 uf LE
                                            X1 50V 22uf LE
                                            X2 50V 1uf LE
                                            X1 10V 1000uf LE
                                            X1 50V 47uf LE
                                            X1 50V 10uf LE
                                            X2 10V 2200uf LE
                                            X1 16V 2200uf
                                            X1 16V 470uf LE
                                            I had 2 questions about changing the capacitors though ... Does LE stand for low ERS?
                                            Can...
                                            11-06-2022, 12:55 PM
