Ka-Boom!
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Ka-Boom!
    Has anyone seen this video? Can you identify that exploding power supply?
    http://www.corsair.com/cinema/movie.aspx?id=622747
    A man convinced against his will is of the same opinion still.
  • Newbie2
    • Sep 2005
    • 885
    Re: Ka-Boom!
    I'm guessing it's a Powmax power supply, judging by the dual-fan design (Powmax just slaps an 80mm case fan right on the back of their dual-fan power supplies) and how it sparks when it fails, along with how empty the power supply is. It could also be a cheap Codegen power supply.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Re: Ka-Boom!
      I've seen so many powmax's go boom. I had one personally. I was one of the lucky ones, it didn't take my motherboard with it!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Newbie2
        • Sep 2005
        • 885
        Re: Ka-Boom!
        Well Topcat... I remember when you said this back in 2003:
        Originally posted by Topcat
        I frequently recommend and use Powmax supplies!!
        If you don't remember, it's on this old thread: https://www.badcaps.net/forum/showthread.php?t=21
        My gaming PC:
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Re: Ka-Boom!
          Live and learn.......... If I were recommending them, it was obviously before I had any major problems with them.
          My PSU of choice today is Zippy (if you can afford them), and Antec actually makes a decent supply now, since they've stopped using the fukkyou (or however they're spelled) caps.
          Team : 49813
          Join in!!
          Team Stats
          • i4004
            • Oct 2006
            • 2029
            Re: Ka-Boom!
            all 3 cases were main switchers blowing...
            as if the control circuit doesn't really know how much can it push them...
            or they're just using too weak switchers...
            • Newbie2
              • Sep 2005
              • 885
              Re: Ka-Boom!
              Back then Powmax made decent (not bad) power supplies, but now they're the worst power supplies on the market.
              You have to admit your statement sounds funny now due to the current shoddy quality of Powmax power supplies.
              My gaming PC:
              • riotpack
                • Jul 2008
                • 27
                Re: Ka-Boom!
                maybe taking the lid off hindered air flow over the heatsinks? I've never seen PSUs do this under 75% load.
                Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
                • acstech
                  GrumpyModerator
                  • Jul 2007
                  • 1432
                  Re: Ka-Boom!
                  So, after some dust builds up and it's loaded to 75%? Or if it's run in the hot environment of a computer?
                  Remind me not to buy Powmax.
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    Re: Ka-Boom!
                    We had a group of powmax supplies go poof during an electrical fault one day. Voltage in the lab dropped due to a wiring issue or a faulty breaker. The supplies attempted to stay running at the ultimate cost. As the voltage dropped, they drew more and more amperage, until they, and the wiring, started smoking. They didn't stop until someone threw the main breaker at the subpanel and killed it.
                    Cracked one or 2 of them open (no pics unfortunately). Varying degrees of damage. Some of them toasted the FETs, some blew the main caps (messy!), some were just charred beyond recognition. Lost a few motherboards from this, as well (I'm guessing from the end when things started arcing around).
                    I still come across some of them in service... I just shudder and replace with a new supply
                    Ludicrous gibs!
                    • Newbie2
                      • Sep 2005
                      • 885
                      Re: Ka-Boom!
                      Powmax is no doubt the worst power supply manufacturer in history.
                      Their quality is worse than even DEER (this also applies to their L&C and Allied brands), which are good power supplies actually for older Pentium III and Celeron (up to Pentium III design) computers, after a good recap and fan replacement is done (the original fan is like 0 CFM).
                      Any Powmax power supply seen running should be immediately replaced before they kill computer components due to their garbage design.
                      Also, the 75% load number that Corsair used is based off the rated wattage on the power supply label. The rating of generic or cheap power supplies cannot be trusted at all, since for example DEER manufactures a batch of identical power supplies and simply puts 300W, 350W, 400W, 450W and whatever power supplies labels they have. Put them in cheap generic cases, and there you have people who don't know what a quality power supply is use those cheap power supplies powering budget computer builds or system builders who don't want to waste time and/or money buying a good power supply or wanting to reduce the cost of the computer system, thinking that their "450W" power supply will still have some power to spare for future upgrades.
                      My gaming PC:
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        Re: Ka-Boom!
                        In case anyone is still wondering, this is a sunpro, more specifically, a raidmax 450W psu. I have this exact same one. I would not expect it to put out 335W.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Re: Ka-Boom!
                          A Sun Pro would've been my second guess. I know Powmax loves that dual-fan design. But then again, my theory is that Sun Pro probably is Powmax.
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            Re: Ka-Boom!
                            http://www.hypermicro.com/itemdesc.asp?ic=PSAB001
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              Re: Ka-Boom!
                              I see they've updated the description of the AcBel.
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Re: Ka-Boom!
                                This is true. I sent a email to sunpro pretending to start a power supply company that would use their power supplies as a OEM. I got a price sheet, they sell the same "safety series" power supplies powmax does.
                                Their low end power supplies do not even have a mag amp for the 3.3v. Their high end power supplies come standard with "doual fan".
                                They have other options, like something they call green giant, which gives the power supply 3 fans. Or to thicken the case steel to .8mm, sata connectors, they even have passive and active pfc options, and temp controlled fans.
                                The most expensive option is the 500W w/ 3.3v magnify, 24pin, doual fan for $24.50 a unit.
                                (see attached price sheet)
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Re: Ka-Boom!
                                  clearly, they are scums. safety shouldnt cost extra. it should be default. they obviously dont value human life.
                                  sigpic
                                  (Insert witty quote here)
                                  • japlytic
                                    • Oct 2005
                                    • 2086
                                    Re: Ka-Boom!
                                    There is no mention for how long the power supply has been operating for. A thermal video would have been better too.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Re: Ka-Boom!
                                      They said that each one blew up within about 2 minutes.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        Re: Ka-Boom!
                                        Originally posted by Newbie2
                                        ...It could also be a cheap Codegen power supply.
                                        I've used a few Codegens in the past. They're not as good as the well respected brands (thermaltake, coolermaster, PC P & C, etc) but I've never seen that happen to them! The only problem I had with them was the conecters weren't very tight and it didn't take much to pull them out.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
