12V rail is not on ?
    Re: 12V rail is not on ?
    Originally posted by bianchi77
    what Voltage will you see on the lamp that has open filament? = source voltage
    source---probe--open filament--probe--lamp x 9------ground
    voltage at open filament = source
    am I right ?
    Right, so what do think you should see when the diode does not conduct in reverse bias mode? If you do not see the same result then you know that DUT is letting the current flow when it should have block the current flow, and you can then check the leakage current of that DUT by measuring the Vdrops on the resistor that is connected in series with the DUT, and look up the spec of the diode.
    • bianchi77
      • Jun 2016
      • 1121
      ok, thanks for the information...keep learning....I love that
      • bianchi77
        • Jun 2016
        • 1121
        I've replaced SBL1040 with SBL2040 but I got no luck...
        V Standby is on but no voltage on secondary...could be my primary transistor is faulty ?
        Or my PWM chip is faulty ? chip = 2005 ....no response with PS_ON switch at all...
        • bianchi77
          • Jun 2016
          • 1121
          What happen if my PWM is not working ?
            So did you look up the spec sheet of the IC at least to get the pinout and to check the DCV of the IC PINS?
              PWM of what?Why don't you look up what the PWM is and what is it related to in the switching power supply?
              What did you check the the primary side?
              Did you recap the board?
              • bianchi77
                • Jun 2016
                • 1121
                Primary side ? check all the transistor and FET ?
                I got V SB....does it mean that my primary side is doing the job ? and there's no fuse blown...
                PWM is a pulse width modulation and it's the way switching power supply generating a voltage...depends on the width of the pulse...
                and that chip has two function over voltage / under voltage supervisor and PWM generator....will it break if there was short on the output ? because all / one of its input for protection sunk to the GND straight away , high current on it within few seconds...
                I saw a smoke from 5V rail for few seconds but when I checked the diode for it...it's normal....I don't understand....
                  Yeah, so the SB power supply is working BUT THE OTHER POWER SUPPLY IS NOT WORKING, you are not getting the 3.3V, -12V and +12V!
                    If you are looking at the power supply board right now, you cannot tell that you have more than one power supply on that power supply board, if you cannot then you are trying to fixing something that you do not understand of what you have in your hands.
                    Over 100 posts and you still do not understand how many power supplies are in your board?
                    "I got V SB....does it mean that my primary side is doing the job ?"
                    Look at post 10 diagrams.
                    https://cdn.badcaps-static.com/pdfs/...83951b6882.pdf
                    I keep telling you do not understand the basic of what you are working on so you go all over the place trying to fix something you do not understand.
                    As yourself what are in the primary side to make this power supply to produce all those Voltages.
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Ok, thanks for the diagram....doesn't matter for me if I need to learn over 100 posts....
                      I'll have a checked on 3 primary transistors and show you the photos later on....
                      Let's see what we get here...and go from there....
                      I have unsoldered the 3 primary secondary rectifyiers as well...so we can see the result as well...and tell me what you think ?
                        • 31028
                        you cant run it without the rectifiers, the controller monitors the output.
                          "primary secondary rectifyiers" What the heck is that? you have rectifiers in the Primary (HOT) side and rectifiers in the secondary (COLD) side.
                          Beside, the rectifiers for the SB power supply or the Other power supply?
                          • bianchi77
                            • Jun 2016
                            • 1121
                            sorry...mistype...secondary rectifier...
                            • bianchi77
                              • Jun 2016
                              • 1121
                              here's the test from primary transistors...how do you reckon ?
                              • bianchi77
                                • Jun 2016
                                • 1121
                                I'm going to test the secondary rectifier and show you the result...give me a moment...
                                I still think that my 2003 chip had died already since it becomes the overvoltage or undervoltage protector...and it was short either 12V or 5V rail....
                                  BTW, that diagram in post 10 is not from me, I do not even know if it is matched your board or not.
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    Here's the secondary rectifier result.....3.3V rail is not good result it's showing resistor result 28 ohm and 205K result...it was brand new before I tested it in circuit...
                                    Brand new from the tray 198 mV and 198 mV
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      How do you reckon from the test result ? talking about diagram, here's the pcb code :
                                      Y-B200 ATX Ver:2.6
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        I don't have 2003 chip to test with....
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          Just now, I saw two burned resistors....near to 3.3V rectifier....I'll show the pictures...hold on...I'll take picture of them...that's why I saw a smoke yesterday, and it was resistor burn smell yesterday, but haven't seen it yet until now...R33 and R34
                                          • Victor Moreira Silva
                                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                            by Victor Moreira Silva
                                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                            Well, my decice specs are the following:
                                            Model: Acer Nitro 5 AN517-54-55T5
                                            CPU: Intel Core i5-11400H
                                            GPU: NVIDIA GeForce GTX 1650
                                            Motherboard: GH51G LA-L181P Rev:1c
                                            The symptom:
                                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                            05-26-2025, 10:49 AM
                                          • grimacelord
                                            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                            by grimacelord
                                            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                            10-24-2024, 12:31 PM
                                          • nagkiller
                                            Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                            by nagkiller
                                            Hello everyone!
                                            This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                            After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                            Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                            The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                            I would like some...
                                            05-10-2025, 09:19 AM
                                          • joshAU
                                            Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                            by joshAU
                                            Hi all.
                                            This notebook was showing no signs of life.
                                            I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                            However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                            If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                            I tried replacing the MOSFET with a new one, but again no voltage on the...
                                            05-29-2024, 12:33 AM
                                          • techrepairheide
                                            Gaming laptop Clevo NH79EP with short on 5VS-rail
                                            by techrepairheide
                                            first of all I want to apologize for my bad English, but I try to give my best.
                                            Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
                                            For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
                                            10-13-2024, 02:49 PM
