12V rail is not on ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: 12V rail is not on ?
    Measuring with ohm...SBL1040
    Forward bias = 1K1
    Reverse bias = OL
    Diode in the middle
    Forward = 6M1 and reverse = 4M5
    with diode on DMM
    SBL1040 = 0.17V
    Diode in the middle = 0.45V...
    Any idea from those information, I suspect my diode in the middle is opened ( faulty ) but how come I can get 0.45 V ??
    • bianchi77
      • Jun 2016
      • 1121
      D14 is the diode with 2 pins and kathode connected together
      • bianchi77
        • Jun 2016
        • 1121
        Can I replace D14 with SBL4030 ?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8168
          Originally posted by bianchi77
          Which link ?
          your post #13. Hit the reply button and it is there, then it disappears.
          http://i129.photobucket.com/albums/p231/picture_77/IMG_20160721_181745_zpsckctjrrx.jpg"
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8168
            What is written on D14?
            • bianchi77
              • Jun 2016
              • 1121
              • bianchi77
                • Jun 2016
                • 1121
                I can't read what is written on D14...
                I want to change it with SBL3040....possible right ?
                • bianchi77
                  • Jun 2016
                  • 1121
                  http://www.aliexpress.com/item/Silic...08.0.60.XG0ffQD14 = FR302 diode...
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8168
                    I think you are getting a bit ahead of yourself. The FR302 is an axial diode and only handles 3A. The SBL 3040 is 40V and 30A.
                    The D14 is on the 3.3V rail? You should be putting up some pictures, so we can actually see something.
                    • bianchi77
                      • Jun 2016
                      • 1121
                      from datashieet I see FR302 Voltage drop = 1.2V I got only 0.4V,
                      I suspect it's faulty
                      • bianchi77
                        • Jun 2016
                        • 1121
                        and for SBL1040, it's 0.55V from datasheet, and I got only 0.1V...
                        The three rectifiers are faulty I reckon, any comments ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          D14 on 12V rail..
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Schematic :
                            http://www.elsys.biz/download/files/...0Y-B200ATX.pdf
                            • bianchi77
                              • Jun 2016
                              • 1121
                              3.3V, -12V and +12V
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8168
                                All I get is 404 error.
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  https://cdn.badcaps-static.com/pdfs/...83951b6882.pdf
                                  Try that?
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    I Hvn t checked C22 C23 C27 C32
                                      • 31032
                                      if you see a diode with a 0.1v voltdrop - put a new battery in your meter.
                                      a low battery messes with the readings before the meter notices it's low.
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        The forward voltage drops in the datasheets are those associated with the diode's rated current. Your multimeter probably outputs only 1mA on the diode range and even less on the resistance ranges. You should be using the higher resistance ranges to confirm whether a short exists.
                                        See the attached I-V characteristics and notice the forward voltage at 0.01 A (= 10mA). Your meter readings should be less than this.
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          The resistance I measured 6M5 and open line...
                                          • Victor Moreira Silva
                                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                            by Victor Moreira Silva
                                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                            Well, my decice specs are the following:
                                            Model: Acer Nitro 5 AN517-54-55T5
                                            CPU: Intel Core i5-11400H
                                            GPU: NVIDIA GeForce GTX 1650
                                            Motherboard: GH51G LA-L181P Rev:1c
                                            The symptom:
                                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                            05-26-2025, 10:49 AM
                                          • grimacelord
                                            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                            by grimacelord
                                            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                            10-24-2024, 12:31 PM
                                          • nagkiller
                                            Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                            by nagkiller
                                            Hello everyone!
                                            This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                            After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                            Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                            The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                            I would like some...
                                            05-10-2025, 09:19 AM
                                          • joshAU
                                            Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                            by joshAU
                                            Hi all.
                                            This notebook was showing no signs of life.
                                            I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                            However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                            If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                            I tried replacing the MOSFET with a new one, but again no voltage on the...
                                            05-29-2024, 12:33 AM
                                          • techrepairheide
                                            Gaming laptop Clevo NH79EP with short on 5VS-rail
                                            by techrepairheide
                                            first of all I want to apologize for my bad English, but I try to give my best.
                                            Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
                                            For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
                                            10-13-2024, 02:49 PM
