SATA /PATA external supply ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Anyone knows about this SATA/PATA external supply ?
    I suspect 4N60 FET burn....
    Fuse blown, I've change it, is it possible if the small transistor frequency generator broken as well ?
    Photo :
    cheers
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: SATA /PATA external supply ?
    Those things don't fix.... They are dangerous when working, and would need a complete redesign to be fixed. However, they do make for a great learning experience because they are so simple. Look for bad solder, they are known for it. We need to see the bottom of the board. The switcher does look cooked, as well as the resistor in-between the cap and the MOSFET.
    But for the sake of your self, your computers, and your data, don't use it once you've fixed it. You're better off with an older computer PSU.
    Follow the white rabbit.
    • zx8401
      Phantom Fiddler
      • Aug 2013
      • 49
      Here is a diagram that might help.
      • bianchi77
        • Jun 2016
        • 1121
        the switcher is a pair of 9014 and 9015, FET 4N60, are they all burned ?
        Yea, I want to fix it but not for HDD, I'll use it for something else...
        @zx8401....tx for the schematic
        • bianchi77
          • Jun 2016
          • 1121
          ok, I'll show you guys, the bottom one, it's terrible PCB...I need to fix it....
          What's the value in circuit between E (emitter) and C (collector) of 9014 and 9015 when I test with multimeter ?
          FET is definitly burned....
          • bianchi77
            • Jun 2016
            • 1121
            How do you reckon ?
            Are they the broken ones ?
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              lose the "earth" symbols for the returns in the primary side
              those do not connect to the EGC, but to the floating common of the input cap
              doesn't matter anyway, cheep stuff is a latent hazard- see how there's no EGC bond to the secondary common? when that cheep, poorly insulated transformer shorts between windings, [i]you or your computer (and ext. HDD) become the return path
              http://www.businessinsider.com/a-gen...-for-10-2013-8
              https://www.youtube.com/watch?v=wi-b9k-0KfE
              the above are power supplies just as much as the ones for the ext. HDD adapters- you better believe that same pertains to all of them
              OP, I'd smash that shock hazard (or worse, your line voltage is 240V to gnd) you have now... not even worth it- the only reason you have it is because it's something that "sneaked in" or was "dumped."
              Goontron, as long as this cheep shit exists, we're gonna have "these kind" of posts...
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • bianchi77
                • Jun 2016
                • 1121
                What is EGC??
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  What about those psus that only has a 2-prong plug, the low wattage units still can get UL listed without any problems, or are people proposing every SMPS require a 3-prong plug?
                  • Electronic Handyman
                    • Apr 2016
                    • 58
                    Check those 1N4007 there are 4 of those they usually go along with the fuse and mosfet but from your pic the resistor by the cap looks burned too.
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      There's a big difference between properly insulated two-wire SMPSes and the fake ones, that either have no EGC or have a "third wire" but don't connect it to secondary common. Leaving your computer/phone/whatever floating; should there be a fault from pri-sec, that "low voltage" device floats at line voltage...
                      As myself and others have repeatedly brought this up and clarified it ad nauseum, this will be the last time for me.
                      I'm done with this- anyone fooling themselves into thinking "it won't happen to me' really need to understand the principles at play; look into the fake iphone charger incident for starters, then put it all together and realize how that EGC protects you by providing "an effective fault-clearing path."
                      EOL it...
                        • 31246
                        just go to some used electrical markets / boot fairs and look for an old external scsi-case or external scsi / parallel-port cd drive.
                        they had very high quality 5v/12v psu's in the back of them.
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Which resistor?
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Can I do like this to fix the ground ?
                            but it looks like there's no ground on the transformer....so
                            can I put ground to negative side ?
                            • bianchi77
                              • Jun 2016
                              • 1121
                              Can I connect negative side to ground straight away ? for safety,
                              without connecting to transformer ?
                              • bianchi77
                                • Jun 2016
                                • 1121
                                see photo please,
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  do you guys have the schematic for this one ?
                                  it's using FET 4N60
                                  • zx8401
                                    Phantom Fiddler
                                    • Aug 2013
                                    • 49
                                    Here is another schematic, this basic 12v and 5v supply is copyed by many.
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Thanks for the schematic,
                                      it's working now...but I don't have 0.22 ohm /1W....
                                      temporaly I change to 22 ohm / 2W.....It gives me a lower DC voltage output...
                                      I'll change to to the proper one later on....waiting another month
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        I put 0.15 ohm /5W on R1 and it gives me a short (bulb turns on very bright)
                                        now I use 22 ohm /2W....it's working normally (no short ) but output only 1.1V and 2.1V
                                        My rectifier diode forward voltage are only 0.1V.....I reckon, they're all broken...
                                        Any suggestions ?
