Panasonic EE
  • frogz81
    • Oct 2012
    • 31
    • Indonesia
    Panasonic EE
    i want to ask if Panasonic EE can be used to recapping PSU?
    I have 1000uf/18v, i can't find any data sheet.
    thanks
  • frogz81
    • Oct 2012
    • 31
    • Indonesia
    Re: Panasonic EE
    i want also ask about SUNCON N.E and NCC KMQ can be use to recapping PSU?
    i can't find any data sheet for suncon N.E
    Thx
      • 31029
      Re: Panasonic EE
      suncon's are out, only 85' general purpose caps
      datasheets.
      • frogz81
        • Oct 2012
        • 31
        • Indonesia
        Re: Panasonic EE
        Does it mean, i can use Panasonic EE & NCC KMQ for recapping PSU? (secondary side of PSU)
        and suncon's are out because General purpose caps?
        the panasonic EE's data sheets apply for high voltage (160 V .DC to 450 V .DC)
          • 31029
          Re: Panasonic EE
          those EE are either custom made for a client, or fake.
          what type of psu are you fixing and what original caps did it use.
          • frogz81
            • Oct 2012
            • 31
            • Indonesia
            Re: Panasonic EE
            Corsair CX 600
            +12V : Capxon KF 3300uf/16v and Capxon KF 2200uf/16v
            +5V : Capxon GF 2200/10v and Capxon GF 2200/10v
            +3.3V : Capxon GF 2200/10v and Capxon GF 2200/10v
            +5Vsb : Capxon GF 2200/10v and Capxon GF 1000uf/10v
            - 12V : Capxon GF 1000uf/16v and Capxon GF 100uf/16v
            my plan will change :
            * 2200/10v with SUNCON NE 2200/6.3V
            * 1000uf/16v with PANASONIC EE 1000uf/18V
            * 1000uf/10V with RUBYCON YXG 1000uf/10V
            • mikey5791
              • 521
              • Malaysia
              Re: Panasonic EE
              Never heard of SUNCON NE, but not advise to use Suncon since it is rated at 85C for general purpose use. and also not too good to replace 2200/10v with a lower voltage rating cap. try to use a same voltage rating of 10v or higher.
              • Behemot
                • 4845
                • CZ
                Re: Panasonic EE
                That's not series name, if there is nothing else, than it does not have the name printed on. N.E. probably means something like negative electrode. But as has been said, they are 85°C so they are not good here.
                I have new 2200/16 and 3300/16 D10 as well as other caps on stock dirty cheap, can supply ya.
                • Stefan Payne
                  • 1267
                  Re: Panasonic EE
                  Originally posted by frogz81
                  Corsair CX 600
                  Those caps are low ESR ones, the CapXon GF with rather low ESR as well.
                  Please check the datasheets of the originally used capacitors and compare those to the ones you already have...
                  But I'd suggest that you buy some low ESR capacitors that are equivalent to the original ones!
                  Not those ultra low ESR ones, standard low impedance types like Teapo SJ or Nippon Chemicon KZE or equivalent.
                    • 31029
                    Re: Panasonic EE
                    data
                    • frogz81
                      • Oct 2012
                      • 31
                      • Indonesia
                      Re: Panasonic EE
                      Finally i'm use mix cap Rubycon ZL, ZLH, Nichicon HD and Panasonic FJ for this PSU
                      Thank for your help.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Re: Panasonic EE
                        In the Linux world, "EE" in a log is horrible news.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • Andre Gilbert
                          by Andre Gilbert
                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                          11-20-2024, 08:52 PM
                        • AquaMan Ua
                          by AquaMan Ua
                          05-17-2025, 09:40 AM
                        • stecos
                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                          by stecos
                          Hi everyone!
                          For my passion for technology I'm now collecting several...
                          11-28-2022, 11:39 AM
                        • aa10aa10
                          Panasonic Toughbook CF-33 mk1 BIOS repair
                          by aa10aa10
                          Good day,
                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                          01-21-2025, 06:13 AM
                        • Mnawar27
                          Panasonic CF-H2AU24EF3 bios locked
                          by Mnawar27
                          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                          I need help to remove it,
                          thankyou all.
                          SN; 2FKCA26876...
                          11-16-2024, 08:00 AM
