ATX PSU input voltage range
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    the input range is pretty wide for power supplies and can operate as low as 90-ish volts on some. that is still too high for what i'm looking for. is it possible to modify one that can work off 48v? i have a dozen or so laying around in the 150-500w range. i'm thinking it could be done by re-winding the primary to half the turns, but will probably need resistors for the switching transistors changed also.
    or else i'm way off and it would need to be re-designed completely :/
    Re: ATX PSU input voltage range
    When you lower the input Voltage the input current will increase to maintain the output power (it is regulated power supply), so it is not that simple.
    For example (lets assume no conversion loss for easy calculation) you have regulated power supply that has regulated 10V output and 10A of current capability which will be 100W.
    So if the input is 100V then the input current will be 1A so the switching device has to be able to handle at least 1A, so if you drop the input to 50v then the input current will have to be increase to 2A so the switching device and the transformer winding will also have to be able to handle 2A.
    • jasonbay13
      • Jul 2014
      • 185
      • usa
      wouldnt that be as simple as the power supply delivering half its capacity due only to the primary transformer and switcher current? which would be acceptable for what use i have for it if it is possible and doesnt require more than resistors and transformer. though i plan on giving it ~50vdc so that would be a little less than half.
      or maybe even simpler would be a dc-dc voltage doubler, then it would be right in the operating range, but google searches come up nil for anything over a few watts or require special ics.
      • mariushm
        • May 2011
        • 3799
        No, most ATX power supplies can work with a wide range of input voltage like 80v AC - 230v AC which rectified means a DC waveform with peaks that go to at least about 110v DC and maximums up to around 330v DC.
        Modern ATX power supplies have Active PFC which basically boosts whatever the input voltage it receives to about 350-400c DC.
        Then there's transistors or mosfets which - controlled by a custom chip that receives feedback from the secondary side - turn on and off for various amounts of time (depending on how much current is used on the secondary side), sending a number of pulses through the transformer and that's how you get some DC voltage on the secondary side which then gets regulated into 12v, 5v and 3.3v
        If the current consumption on the output is higher, the number of pulses (turn on and off) per second is higher, with lower current you get fewer pulses.
        So basically you could try feeding 40-60v DC to such power supplies but my guess is the Active PFC circuit won't start or it would blow something up due to too high peak input currents
        There's no point trying when there's a HUGE selection of power supplies designed from the start to work with relatively low DC voltages at the input, see this page for example : http://www.digikey.com/product-searc...verters/590047
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8297
          Why not upping the 48V AC with a 1:2 step up transformer, then hook up the PSU to it? Then you end up with 96V AC.
          Maybe a voltage doubler circuit?
          • jasonbay13
            • Jul 2014
            • 185
            • usa
            only problem here is the 48v is dc from a battery.
            btw, took a look at those dc>dc converters to go from 48 to 12. like 100 usd for the cheapest one.
              48VDC! That is basically the same as feeding it with 34VAC.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8297
                at this point you can almost buy a 48V ATX PSU.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  AFAIK you can't feed a full range APFC PSU with DC voltage.
                  It only accepts AC input.
                  An old passive PFC or no PFC PSU will gladly do it though.
                  The DC just goes through the rectifier unmodified, well, I guess it would protect against reversed polarity
                  • Dannyx
                    Modifying SMPS input voltage range
                    by Dannyx
                    Good day folks. Long time no see. It's been a while since I've tinkered with any new projects, despite one thinking this would be the perfect time, with the pandemic and the quarantine, people tend to stay indoors....it's not my case anyway: I go to work like normal, but it's here where I'm bored out of my mind with nothing to do, so here's something.
                    A while back, I got myself this adjustable load kit form off Ali. I put it together and it works. It's powered by an AC or DC input and I've been running it off a 12v wall adapter on the bench. What good is such a device if it doesn't...
                    03-30-2020, 06:45 AM
                    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                    Narrow VDC applications where the system power source is
                    either the battery pack or the regulated output of the charger.
                    This makes the max voltage to the system equal to the max
                    battery voltage instead of the max adapter voltage. Operating
                    at lower system voltage can improve...
                    11-05-2024, 04:43 PM
                    LM358 LM358S-13 Datasheet
                    The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                    Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                    10-07-2024, 04:12 AM
                    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                    The bq24745 features dynamic power management...
                    10-23-2024, 02:50 AM
                  • ketone
                    SMPS - Can they all handle wide range of Input Voltage?
                    by ketone
                    Hello Forum - See I got this SMPS Module!....its sourced from a US device and I'm in Australia.
                    As we know Supply voltages in Australia 240v Versus 120V US.
                    The Model of the SMPS is EAX39561401 and is used in LG and JVC DVD/VCR Player/Recorders...same model is used in both Australia and US...but perhaps they have differences??
                    What's the chances I can use it in Australia - plugging it in to 240v instead of its origin country at 120v?
                    Is it expected that most SMPS in such devices would handle between 100-240V by default?
                    How can I...
                    12-17-2022, 02:40 AM
