Another Chinese junks
    http://www.edn.com/design/pc-board/4...mpaignId=27833
  • ddscentral
    • Mar 2008
    • 151
    • Lithuania, EU
    Re: Another Chinese junks
    The interesting thing in that article is not that these PSUs are junk, but that they are essentially repackaged used PSUs.
    It seems the Chinese have found a new way to make cheap power supplies.
    • japlytic
      • Oct 2005
      • 2086
      I see one (Delta) with Live/Neutral leads which have been cut with new leads going to an IEC connector...
      • CapLeaker
        Leaking Member
        • 7976
        oh my...
        • Behemot
          • 4845
          • CZ
          Those are the ones I already posted https://www.badcaps.net/forum/showthread.php?t=52332
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8663
            All those electronics people "recycle" ...where do they go... they all come right back to us and we pay more for it...
            • valente222
              help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
              by valente222
              Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
              05-12-2025, 03:42 PM
            • AJ847.63e
              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
              by AJ847.63e
              Hi Folks,
              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
              05-06-2025, 10:37 PM
            • NanoTesting
              Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
              by NanoTesting
              This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
              Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
              02-21-2025, 12:33 AM
            • Vincent_Leigh
              Chinese Mini PC Schematic
              by Vincent_Leigh
              For anyone in need of a sample schematic for those Mini PC from chinese origin.
              Enjoy.
              NB690
              SY8003
              NB687BGQ-Z
              MP86941C
              MP2961 AKA MPxxx2961
              NB692AGD-Z...
              09-19-2024, 11:55 PM
            • Bloopeta
              Car Headunit (Chinese?) No Sound / Audio
              by Bloopeta
              Just bought a car that has a stereo in, thats bluetooth etc, and powers on fine and all functions seem to work, BUT there is no audio/sound.
              I have tried another unit in the car that works fine, so know it definitely a problem with this unit.
              I know it just cheap rubbish, probably of chinese origin, but its really bugging me just throwing it away and replacing it 🙈🤣
              I know zero about things like this, ans its probably unfixable, or more trouble than its worth, but just wondered if there was anything to check, as what could lead to an easy-ish fix? Havnt opened...
              02-02-2024, 03:36 PM
