PSU got negative output!! help
  • Brian C
    • Dec 2006
    • 156
    Re: PSU got negative output!! help
    The problem of his power supply is the Power Good (PG) signal line (Grey color). It reads low instead of 5V. All other outputs are fine. Perhaps due to the supervisory IC or comparator problem...
    • Krankshaft
      • Jan 2007
      • 2328
      He he funny on 2 out of the 3 pics that extra port is cut out .
      Thats why I don't use cheap multimeters.
      Any meter I own must have autoscale at a minimum.
      Aw Brain you beat me to the diagnosis .
      Indeed the mobo won't attempt to power up the supply if the power good generator doesn't send out its 5 volts.
      If all of the PSUs outputs are within range then replace the power good IC if you want to fix it.
      Sometimes these ICs malfunction and prevent the PSU from coming on when connected to a mobo.
      I have had wall wart switchers with dead PWM controllers after checking the FETs and output rectifiers for shorts I replaced the PWM IC and the PSU came back to life.
      So ICs can die without being brought under by another component in the circuit.
      • jdimpas
        • May 2008
        • 39
        Hello guys! thanks for dropping some comments, well the powersupply just blow up when i plug it again in the AC.. hahaha.. dammn powersupply.. made in china products!!.
        • i4004
          • Oct 2006
          • 2029
          i like happy-ends...
          • Krankshaft
            • Jan 2007
            • 2328
            Good bye and good riddance .
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              the psu in the pic is something i would crush for hand exercise.
              at least you got a fireworks show without losing a board or worse.
              • jdimpas
                • May 2008
                • 39
                #27
                yes, a bit fireworks! boomm.. haha.. well anyway thanks guys!
                • FrancescoV
                  Onkyo HT-R390 no sound output, video output ok
                  by FrancescoV
                  Good morning everyone,
                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                  The firmware reported is the following:
                  M:1.00/11107BLP
                  D:?.??/????????
                  O:1.00/11107AL
                  The DSP firmware given the question marks seems corrupt.
                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                  05-11-2025, 02:59 AM
                • madan1
                  DALI SUB E-12F class D, fluctuating power rail
                  by madan1
                  Good day everyone.
                  I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                  The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                  The normal value of the positive and negative power rails is +/- 43V.
                  The positive rail stays...
                  10-15-2025, 10:33 AM
                • u666sa
                  HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                  by u666sa
                  Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                  Platform: ipa32 la-m024p rev 1b
                  Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                  I found a short on the other side:
                  10-04-2025, 05:03 PM
                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                  I bought this from an eBay seller but unfortunately they only had one
                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                  I bought three of from them to also make battery packs with this output power limit in mind
                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                  04-23-2025, 05:50 AM
                • MisterAIL
                  PS5 digital / No Power / No Beep / Good power supply
                  by MisterAIL
                  Brought a non functionnal PS5. Apparently only a bad PSU...
                  No beep, nothing.
                  After some tests i found this :
                  - PSU is fine (12 volts stable)
                  - 12 volts line is shorted
                  - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                  - By the way, nothing change. No signal, no power, no beep.
                  Mesuring all rails with my workbench psu (12 volts input)
                  - 0.00 amp drawing
                  - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                  03-12-2024, 03:24 PM
