Fan siezed, PFC burnt in CFT-620-A12S
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Hi!
    I got this psu that seemed to be a quick fix at first. Turned out that the fan bearing got stuck and all the caps plus the PFC boost coil got boiled. The guts come from Sirtec. It's an old build, but looks decent enough. Looks far better than any gutless unit today...
    The main trafo and secondary torroids, pi coils seem good, but the active pfc is way too damaged for safe operation.
    Does anyone might have info about the core material? Looks like it was green/black originaly.
    I have a lot of spares or I can just wind one, that matches the diameters and windings and inductance. Might just build in one and see if it fits to the specs...
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Fan siezed, PFC burnt in CFT-620-A12S
    Does the coil have 0 ohms across the two legs ? If so its good lol its only a filter.
      a) that's not just a filter, it's an active PFC inductor
      b) no...just no...an inductor is more than just zero ohms between a pair of legs
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Whoops my bad guess I got mixed up again lol
        • pdavid
          • Jan 2011
          • 279
          • Hungary
          Coil measures 0.3, 0.4 ohms. The enamel is burned off some areas and it could get shorted. The toroid core is beyond repair too. I got plenty if spare coils suitable for APFC boosting, some new some from similar apfc topology psus.
            • 31047
            why not download a datasheet for the pfc controller?
            most have example circuits with component details.
            • pdavid
              • Jan 2011
              • 279
              • Hungary
              It's just a cm6800 in the primary. I guess any 400-600uH coil, with thick enough wire, will do for this max wattage.
              • dicky96
                Zotac GTX 260 burnt component - can anyone identify?
                by dicky96
                Hi guys
                This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                The good phase...
                12-01-2021, 01:02 PM
              • mferna14
                Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                by mferna14
                Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                06-25-2025, 11:26 AM
              • Dobrowol
                Dell Latitude 3520 help with bios build/repair
                by Dobrowol
                Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                Steps i done and results:
                I exported a clean bios from update file via pfs extract.
                1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                Result: Dead
                2. Build clean bios with no changes in ME, new PMC, PCH
                Result: Dead
                3. Build old bios with clean ME, new PMC, PCH
                Result: The same
                09-22-2023, 02:43 AM
              • nobbnobb1
                Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                by nobbnobb1
                I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                - 1x 3.14 A @ 250V main circuit fuse
                - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                11-16-2024, 09:56 PM
                ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                09-12-2024, 03:28 PM
