Fan siezed, PFC burnt in CFT-620-A12S
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Hi!
    I got this psu that seemed to be a quick fix at first. Turned out that the fan bearing got stuck and all the caps plus the PFC boost coil got boiled. The guts come from Sirtec. It's an old build, but looks decent enough. Looks far better than any gutless unit today...
    The main trafo and secondary torroids, pi coils seem good, but the active pfc is way too damaged for safe operation.
    Does anyone might have info about the core material? Looks like it was green/black originaly.
    I have a lot of spares or I can just wind one, that matches the diameters and windings and inductance. Might just build in one and see if it fits to the specs...
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Fan siezed, PFC burnt in CFT-620-A12S
    Does the coil have 0 ohms across the two legs ? If so its good lol its only a filter.
      a) that's not just a filter, it's an active PFC inductor
      b) no...just no...an inductor is more than just zero ohms between a pair of legs
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Whoops my bad guess I got mixed up again lol
        • pdavid
          • Jan 2011
          • 279
          • Hungary
          Coil measures 0.3, 0.4 ohms. The enamel is burned off some areas and it could get shorted. The toroid core is beyond repair too. I got plenty if spare coils suitable for APFC boosting, some new some from similar apfc topology psus.
            • 31247
            why not download a datasheet for the pfc controller?
            most have example circuits with component details.
            • pdavid
              • Jan 2011
              • 279
              • Hungary
              It's just a cm6800 in the primary. I guess any 400-600uH coil, with thick enough wire, will do for this max wattage.
              • electomech-fixer
                First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                by electomech-fixer
                I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                09-15-2025, 01:42 AM
              • dicky96
                Zotac GTX 260 burnt component - can anyone identify?
                by dicky96
                Hi guys
                This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                The good phase...
                12-01-2021, 01:02 PM
              • swimllamaswim
                Precision 5550 LA-J191P No Power, Burnt ISL9538
                by swimllamaswim
                I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                Here are the voltages measured at that chip:
                To note, DCIN at Pin 17 is low,...
                09-21-2025, 12:26 PM
              • mferna14
                Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                by mferna14
                Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                06-25-2025, 11:26 AM
              • Dobrowol
                Dell Latitude 3520 help with bios build/repair
                by Dobrowol
                Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                Steps i done and results:
                I exported a clean bios from update file via pfs extract.
                1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                Result: Dead
                2. Build clean bios with no changes in ME, new PMC, PCH
                Result: Dead
                3. Build old bios with clean ME, new PMC, PCH
                Result: The same
                09-22-2023, 02:43 AM
