Help replacing 4 diodes with rectifier and improving old AT PSU
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Help replacing 4 diodes with rectifier and improving old AT PSU
    Doesn't any SMPS create interference? Switchers are very noisy when operating, I would install the input filtering components.
    List the uF of the filtering caps used in this unit and we can compare their specs to a suitable series
    JPCE-TUR: https://cdn.badcaps-static.com/pdfs/...7336c19519.pdf
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Originally posted by Stefan Payne
      So if they used general purpose caps, you also should use general purpose caps...
      No. Entry level low esr caps such as FC, YXF would work fine in places where General purpose caps were used before.
      • Behemot
        • 4845
        • CZ
        Are you kidding me? Have you even looked in the datasheet? Yes, YXF would be suitable even though it is still superior than anything from that era. FC has about 2/3 the ESR of YXF. And FR is different league with ESR 1/3 of the YXF's.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          I think it's a terrible idea to use GP caps with a load life of 1000 / 2000 hours when you can use entry level low esr caps with 3000-10.000 hours. I never had any problem with the series I mentioned above. Smps are not picky with caps if you pay attention not to use motherboard grade capacitors.
            • 31283
            Originally posted by Behemot
            I would not stick such low-ESR caps as FR/FC into two decades old PSU, / Who knows what especially FR would do in there..
            i'm not just saying it, i'm doing it.
            the psu's work fine.
            now what i wouldnt do is use FR in "tray" style psu's that use parallel banks of 6 or more caps on the same rail.
            • Behemot
              • 4845
              • CZ
              #26
              Into old AT units? Really?
                • 31283
                into?
                you repair what your asked to repair.
                you know megatouch arcade quiz machines? well most of those are AT.
                • Behemot
                  • 4845
                  • CZ
                  #28
                  No idea what's that.
                    Originally posted by stj
                    that's nice, but it means nothing for internal equipment wiring.
                    there are other non-standard "standards" too i see a lot.
                    for example, building wiring.
                    red for switched live, yellow for unswitched.
                    very common when i see light fittings with integral battery backup.
                    Heck you can use any color you want when you do not really care about the standard or safety, then put on fake stickers and then hope that no one get hurt, and you better have lots of money for the law suit, but who cares, right?
                    "that's nice, but it means nothing for internal equipment wiring." So the internal wiring for the primary circuit from the IEC inlet to the AUX IEC oulet does not matter then right as far as the color code concern? Look at the so call UPS outlets that you that you say you have experience with, did they use just any color wires on the outlet and the inlet? "but it means nothing for internal equipment wiring." really?
                    May be you should learn from this statement and EXPAND your experiences:
                    "i work mostly in industrial equipment and if you think SONY, TDK, Delta etc dont use white & black you need to expand your horizons beyond shitty $10 pc supplies."
                      • 31283
                      • Quaddro
                        Tukang Kentu
                        • Nov 2010
                        • 141
                        • Indonesia
                        #31
                        mmm, i have a question..
                        all old atx 1 version is usually have a big amperage at 5v rails..but low at 12v rail.
                        for example, 5v rail use 3045, and 12v rail use 1645
                        if we switch off both of secondary rectifier (12v to 3045 and 5v to 1645), or use bigger rectifier at 12v rail, will it raise the amperage capability of 12v rail?
                          Not unless you also raise the transformer capacity.
                          • Quaddro
                            Tukang Kentu
                            • Nov 2010
                            • 141
                            • Indonesia
                            #33
                            owh..
                            thankyou for the information..
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #34
                              Usually the transformer can output more A than the rectifiers used. So, the output rectifiers are the bottleneck and updating them will update the output rail's power and make the psu run colder (that has to do with the forward voltage drop of the new rectifier. the lowest the better)
                              • mariushm
                                • May 2011
                                • 3799
                                #35
                                I don't agree with that goodpsusearch.
                                Here's my thoughts on this...
                                The power supply may be capable of more current on 12v than what those output rectifiers are capable of, but most of the time the systems that use such power supplies don't even use that much current.
                                The transformer inside the psu is still a limitation, so if in theory you could raise the current but it would be by a little amount.
                                Replacing the output rectifier with a higher current one may be a good idea (and make the psu capable of more current) for another reason, a bit sideways... if the new rectifiers could handle higher temperature.
                                See for example a typical 3045, look at page 5 in the datasheet: https://cdn.badcaps-static.com/pdfs/...61aa51f969.pdf
                                This particular rectifier's current capability is only true at up to 100C, if the temperature goes up the rectifier can do less current.
                                On cheap power supplies the rectifiers are mounted on lousy heatsinks that don't dissipate heat well, the rectifiers will be often very hot (i'd say close to 80-100c).
                                When you do something power intensive (playing a game for example), the standard cheap power supply could overheat its rectifiers so much that they'll cause resets (tripping protections) or even blow the rectifiers.
                                If you happen to choose a rectifier that can do more current at such temperatures, that could mean the power supply won't blow up when playing a heavy game for a long time.
                                  All you have to do is to use dummy load and draw the current up to the power supply then goes beyond that and see if it still maintain the 12V within the spec, The transformer has impedance which will limit the amount of current you can draw from the transformer.
                                  Lower Vf diode will help reduce the power dissipation on the Diode. All power supplies/power sources have output impedance, the lower the impedance the higher the current capability.
                                  • Quaddro
                                    Tukang Kentu
                                    • Nov 2010
                                    • 141
                                    • Indonesia
                                    #37
                                    well..very interesting discussion about it..
                                    With bigger secondary rectifier, we can squeeze transformer amperage capability.
                                    Can we use car/motorcycle halogen lamp as a dummy loader..?
                                    after read budm post , i test my psu.
                                    i have old enlight en8307 300w with 10A capacity at 12v rails (in the label).
                                    i've replace the 12A rectifier with 30A one.
                                    Load it with 2 halogen lamp @100w for 12v rail, and 1 halogen for 5 rail, since this psu is group regulated.
                                    voltage regulation still solid at 12,02v (idle 12.2v).
                                    but i'm too afraid to add more load (halogen)...
                                    explosion is scary.
                                    my question..
                                    1. If we use 2 pieces 100w halogen lamp as a load, can we assume we have 200w load for the psu?
                                    Since this is just lamp, with 100w number advertised..
                                    2. If the transformer already pushed to the the limit, what will happen?
                                    fail voltage regulation or simply burnt (or blow up) ?
                                    thanks for the response.
                                      • 31283
                                      halogen has a very low resisance when cold so the startup current will be huge.
                                      • Logistics
                                        • Apr 2007
                                        • 721
                                        I agree with many of the previous posters, that using low-impedance capacitors was not the way to go as you can change the way the circuit behaves, entirely. Also, I WOULD replace the primary capacitors, not because it's necessary, but simply as an upgrade I would use something like Panasonic TS-ED for very high ripple handling.
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          #40
                                          Yes, it will.
                                          But I doubt you would be able to pull the full 30A (half-bridge) or 20-24 A or so on forward-converter (or single-transistor forward, if you like) topologies. Most likely, you will be able to squeeze only a few more Amps.
                                          It is not just the transformer that is the limitation. The output toroid inductor also matters. On older PSUs or PSUs with a weak 12V rail, the winding on that toroid inductor for the 12V rail will also have thinner wire. This means you won't be able to pull as much current through it as you can from the 5V rail.
                                          That said, increasing the capacity of the output rectifiers is still a good idea, because then the rectifiers will have a lower forward voltage drop. This means less losses, better efficiency, and thus less heat in the power supply.
                                          Another thing worth mentioning is to pay attention to the power supply topology before changing the output rectifiers. For half-bridge topology, you should NOT use a rectifier on the 12V rail with a rating less than 60V.
                                          Are you sure the 12V rail uses a 1645 rectifier (i.e. 16A, 45V rectifier?)
                                          It is not needed.
                                          Good quality Japanese caps on the input will easily last 20+ years without problems.
                                          • Dvsr
                                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                            by Dvsr
                                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                            After replacing the caps I started testing out the speaker. It seemed...
                                            09-10-2025, 10:20 AM
                                          • _AcE_
                                            JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                            by _AcE_
                                            I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                            There's no physical damage...
                                            08-10-2025, 09:27 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                            by momaka
                                            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                            http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                            What mostly drew me into buying it is its 2x PCI-E power connectors...
                                            03-29-2022, 11:34 PM
                                            Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                                            by momaka
                                            This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                                            Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                                            Macron Power Technology Co. LTD.
                                            Let’s look at the PSU itself.
                                            The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                                            06-02-2021, 10:05 PM
