Corsair HX850w blown internal fuse?
  • mikay786
    • Aug 2014
    • 765
    Got a corsair HX850w PSu that has a blown internal ceramic fuse
    Tested it by just doing a continuity test out of board and its dead.
    E.T12AH250V Pigtail (soldered to board) Anyone know where I can source in UK?
    Also given it has blown is just a case of replacing it or perhaps a sign of other issues?
    • 31163
    Re: Corsair HX850w blown internal fuse?
    you need to fix what killed it first.
    start by checking the rectifier & fets.
    • mikay786
      • Aug 2014
      • 765
      Can they be checked inboard?
      • Bungz
        • May 2013
        • 133
        These things have a 7 year warranty, prob not now you have messed with it mind lol
        • ep9es
          • Jul 2015
          • 24
          • Spain
          Originally posted by ep9es
          Well, I'm stupid
          I was using in the multimeter the continuity scale(200R) but not the diode scale (2KR).
          I desoldered the rectifier.
          If the pins are like this - ac1 ac2 + , and the multimeter cables are Red(R) and Black(B), the measures are:
          -(R) ac1(B) 0.55
          -(R) ac2(B) 0.55
          -(R) +(B) 1.241
          +(B) ac2(R) 0.544
          +(B) ac1(R) 0.544
          +(R) -(B) infinite
          ac1(R) ac2(B) infinite
          ac1(B) ac2(R) infinite
          Other combinations, also infinite.
          Then, Is it ok??
          I will wait your answer to solder it again into the board.
          You can try to check bridge rectifier soldered to the board.
          If wrong measures, then check it unsoldered.
          • mikay786
            • Aug 2014
            • 765
            2nd hand, bought a faulty PC and seller said PSU was dead.
            Weighed up the risks and took a chance as it has some decent parts in it, and given its a Corsair HX unit which are quality, there was a good chance it would have protected the other components when dying.
            Might as well tinker with it, learn and if it gets fixed great if not no loss.
              What is resistance between the two outer pads (no bridge rectifier in place) where the bridge was soldered to? Same question for the two inner pads.
              • mikay786
                • Aug 2014
                • 765
                http://uk.mouser.com/Circuit-Protect...c+fuse&FS=True
                is that the correct type of fuse? E.T12AH250V is what it says on the current fuse
                  • 31163
                  that's a match.
                  not good having 12A in a 6.3mm package though, they are only designed to go upto 6.3 originally.
                  • mikay786
                    • Aug 2014
                    • 765
                    Could you link me somewhere I can actually buy, struggling to find anywhere in stock.
                    Went to maplins and they only had 10a, cant see any on farnells either.
                      • 31163
                      i have not seen anywhere in the u.k. that sells 20mm fuses with wires on them - i looked a while back for some 6.3a ones for dell psu's
                      try ebay - the chinese probably have them.
                      • mikay786
                        • Aug 2014
                        • 765
                        Would using a 10a be suitable?
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          No Problem, you are in the UK so have 230v, the big rating of the fuse is only needed if you feed it 110v...
                            • 31163
                            does maplin sell 20mm ceramic fuses with wires on them???
                            • mikay786
                              • Aug 2014
                              • 765
                              No, they are useless. They didn't even know they exist.
                              I've just thought sod it and order 5 off eBay US for £15 delivered. Nothing in stock in the U.K. with reasonable postage. Even the 10a were hard to find. Mouser had them but wanted £12 shipping for the privilege.
                              So I'll have a few spare if anyone in the U.K. needs some.
                                • 31163
                                well at that price, dont go fitting them till you find what made the original blow!
                                • mariushm
                                  • May 2011
                                  • 3799
                                  Make sure you get a TIME DELAY fuse.
                                  The original fuse is 250v, 12A time delay. ATX power supplies can pull up to 30-40A for a few ms when they're plugged into the mains socket, so a regular fuse may blow.
                                  As you are on 230v, the current used regularly is smaller, so you'll probably be fine with a fuse rated for less current, worst that could happen would be fuse blowing up.
                                  Still, you should check the circuit before installing a new fuse.
                                  See cpc.farnell.com , they may have something, even if not with premade leads, you could bodge something there.
                                  • mikay786
                                    • Aug 2014
                                    • 765
                                    http://www.ebay.co.uk/itm/5x-T12A-25...item258978939c
                                    Ordered these
                                      • 31163
                                      soldering wires to 20mm fuses usually wont work btw, the heat makes the air/gas in the fuse expand and blow the cap off the end!
                                      you can guess how i found out!
                                      • Ricardo Q
                                        • Mar 2016
                                        • 12
                                        • Scotland
                                        Originally posted by mikay786
                                        So what happened Mikey? Did it work ok?
                                        Have the exact same issue with a CX750
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • iyas132
                                          Corsair RM 750 blown schottky diode near ES1DF
                                          by iyas132
                                          Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                                          Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                                          My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                                          Can anyone help me identify the component...
                                          12-30-2024, 01:34 AM
