PSU worth replacing caps?
  • mikay786
    • Aug 2014
    • 765
    Re: PSU worth replacing caps?
    It has only been a few days, international postage usually a week at least.
      • 31068
      post across the EU usually is a few days actually.
      • mikay786
        • Aug 2014
        • 765
        Turned up today, just going to fit them now.
        Sent Friday, received Thursday so just shy of a week. Thank Behemot.
        • CapSwapper
          • Feb 2014
          • 69
          Originally posted by c_hegge
          The pop and smoke was probably just one of the caps exploding, not a transistor. Otherwise, the thing probably wouldn't still run.
          It looks like you just like having fun disagreeing with people and I could care less. It makes you look rather silly. You do your thing and I'll do mine. If you want to keep putting band aids on cheap junk psu's then that's your business. I've been in electronics longer than you've been born
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            He wasn't being rude about it, or trying to start anything. Failing caps doesn't mean the power supply was poorly designed. Cheap caps will fail in almost every scenario. The thing that takes the brunt when capacitors fail in the power supply is the attached hardware, not so much the power supply itself.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4972
              • New Zealand
              #66
              If other parts in the supply were stressed and end up blowing later, so what? Replace them too, that's what this forum and repair is about... even if it's not economically sensible, chances are you'll learn something from it or remind yourself of something you forgot. Not everyone has years of experience and repairing even a junk PSU is likely still an educationally worthwhile thing for many people.
              I agree though that it's maybe not worth the hassle or cost if the PSU is really cheap, but if you can't afford a better one it might make sense to spend a little time to improve a cheap one and use it as long as you are aware of its limitations.
              It depends how cheap you're talking of course. Some really are awful, and I wouldn't bother with them either (even brand new), but some budget PSUs aren't too bad, they use tried-and-true designs and seem to be fairly reliable provided they aren't overloaded and the capacitors aren't junk.
              -David VanHorn
              • Behemot
                • 4845
                • CZ
                #67
                Mister, if you can't even tell half decent power supply (and this one is somewhat better than that), than it is good I never got anything from your "electronics" and I hope I never will.
                As Dr. House says, you have to deserve to be arrogant. So far you showed nothing but calling every PSU in every thread you posted in a PoS. So I suggest slowing down with that
                • c_hegge
                  • Sep 2009
                  • 5219
                  My point exactly. This is an excellent quality PSU, which was let down solely by the caps - not a piece of junk from the ground up. I DON'T ever recap cheap junk PSUs. (in fact, there are probably quite a few PSUs which I would deem not worth fixing when most others here would fix them)
                  • Stefan Payne
                    • 1267
                    I woudn't count Topower that much to the 'quality manufacturers'. They are somewhat OKish, sometimes, but not really that great....
                    Even compared to others from that time (Enhance, Delta and so on)...
                    Well, the Dark Power P6 (non pro) I tested on the chroma was somewhat OK but had JenPo caps...
                    The P4 and P5 were worse as they used those Fthings...
                    • everell
                      • Jan 2009
                      • 1514
                      I think I have found another person who voted for Obama!
                      By the way, the Bestec ATX-250 12E (mobo killer) is a great power supply after recap and 5vsb mod (DM311 mod). I am running on one right now.
                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                      • ep9es
                        • Jul 2015
                        • 24
                        • Spain
                        #71
                        How it has been the replacement?
                        • mikay786
                          • Aug 2014
                          • 765
                          Ive only tested it on a PSU tester so far and it seems to be ok. its got a bit of coil whine / buzz in standbye mode but I don't know if that's how its always been.
                          I'm gonna huck it up to an old sli GTX 470 system which is very power hungry and let it run 6-12 on loads maybe running heaven or something.
                          Will report back
                          • ep9es
                            • Jul 2015
                            • 24
                            • Spain
                            #73
                            Will report back
                            New capacitors perhaps need a little glue to hold them up to the plate and do not vibrate.
                            The point is that any glue is not suitable for components, it may affect chemically to the plate.
                            I planned to use hot glue but only if it is suitable for this use.
                            If someone could tell me if I can use this glue, I would appreciate it.
                            • mikay786
                              • Aug 2014
                              • 765
                              I don't think hot glue is suitable, I've used some RTV silicone on this to separate capacitors from coils as that's how it was before.
                              • ep9es
                                • Jul 2015
                                • 24
                                • Spain
                                #75
                                Thanks for RTV silicone.
                                I will search it.
                                • mikay786
                                  • Aug 2014
                                  • 765
                                  this is the one I used, non corrosive is what you need from what I read. Might not be ideal so hopefully someone else will chirp in
                                  http://www.circuitspecialists.eu/mg-...rtv-silicones/
                                    • 31068
                                    i use UHU or Bostik all-purpose adhesive on pcb's
                                    it dries like plastic and is not acidic or conductive.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #78
                                      I've been thiking about ordinary bathroom silicone, anybody tried?
                                        • 31068
                                        carefull with that, it comes in 3 types.
                                        acid base, alkaline base, and neutral base.
                                        obviously you want the last one!
                                        • ep9es
                                          • Jul 2015
                                          • 24
                                          • Spain
                                          #80
                                          THANKS mikay786, stj and Behemot
                                          • Noodneek
                                            Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                            by Noodneek
                                            My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                            I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                            08-30-2024, 12:52 PM
                                          • kotel studios
                                            TAGAN TG380-U01 PSU - 5v shorted after replacing caps
                                            by kotel studios
                                            Hi
                                            Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
                                            Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
                                            02-14-2025, 10:10 AM
                                          • bulkchart32
                                            are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
                                            by bulkchart32
                                            nichicon
                                            1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
                                            are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
                                            05-14-2025, 02:12 PM
                                          • Delicieuxz
                                            Replacing caps in an old speaker system. Should I use a higher value here?
                                            by Delicieuxz
                                            I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
                                            https://youtu.be/1LRIzePlma0?t=273
                                            I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
                                            Would 680uF be good value to try in place of the 470uF originals?
                                            06-25-2023, 08:27 PM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
