Ps4 smps
  • MOSFET606
    • 17
    Ps4 smps
    Ok, as the title suggests this the SMPS found from a PS4
    Here's a little run down
    I have 2 PS4s
    One system boots up, the other attempts to turn on and the quickly shuts down, SMPS ISSUE
    The good power supply keeps both systems on.
    Next
    I'v measured the voltages across both SMPS, by manually turning them on
    12 11.85 on both units
    5v ~4.7 on both units
    I can't seem to see what's the problem here with the bad supply...
    Current issues?
    • 31046
    Re: Ps4 smps
    attach some foto's
    • MOSFET606
      • 17
      Re: Ps4 smps
      It doesn't seem to be the typical SMPS, with a main Mosfet, it has several.
      I'v metered a bunch of components nada, everything looks fine
      I was hoping when I powered it on, it would show a low on one of the rails, but their identical pretty much and probably within specs.
      I looked into the optocouplers and found them on mouser or digi pretty much saying their low quality and not recommended way to go sony...
      Maybe its the feedback circuit, and PWM.
      Was wondering if anyone else has seen this on a SMPS giving out proper voltages, and why a system would reject it.
      I'm no Novice but here are the photos, nothing obviously blown...
      But i dont know SMPS that well, I have a good understanding
      Any suggestions on locations to meter while the power is on to find out whats wrong would be great... Going to check the PWM
        • 31046
        Re: Ps4 smps
        it looks like it has 2 psu's and a pfc circuit.
        the problem may be the pfc circuit.
        next time use jpg btw, then the images will show in your posts.
        what's on the bottom of the board?
        • MOSFET606
          • 17
          Re: Ps4 smps
          I'm not exactly sure whats on the bottom, except for the optocouplers for sure.
          IF your talking about the white thing sticking from under, that would be a pizza crumb...
          Are there 2 PFC circuits on the bottom of the board, one for High and Low side?
          • MOSFET606
            • 17
            Re: Ps4 smps
            I'll get the chips listed, the little one on the topside 8 pin guy, is power control chip...
            Thing i dont understand is that the voltage outputs are correct...
            • MOSFET606
              • 17
              Re: Ps4 smps
              Bottom Side
              4 little chips are DAS09, for signal conditioning
              One on the high side is DDA001AG Can't find much out about this chip... except its on EBAY
              Lower side is DNP012A having problems getting specs of this chip as well
              And on the top side, a DNP015
              Going to power everything back up and check their pins, atleast the ones i can get specs for and compare them with the good supply.
              • MOSFET606
                • 17
                Re: Ps4 smps
                Took voltage measurements all the chips measured the same
                  • 31046
                  Re: Ps4 smps
                  well i'm not seeing any foto's
                  i'm wondering if the pfc circuit is running - it boosts the incoming voltage.
                  • CapLeaker
                    Leaking Member
                    • 8179
                    Re: Ps4 smps
                    try swapping the power supplies around? Did you measure the PSU under load?
                    • MOSFET606
                      • 17
                      Re: Ps4 smps
                      -STJ -
                      All the photos so far are in my second my post.
                      I'm going to take measurements again, and do better documentation on it.
                      I think the PFC is running, i measured the same voltages on both the good and the bad.
                      -CapLeaker-
                      That's how i know one of the power supplies is bad, one PSU worked in both of the systems.
                      I haven't measured the PSU under load, and would rather not atleast within the PS4/ connected to the Mainboard. Was wondering about doing this but dont know what load/ ohm i should apply to it.
                        • 31046
                        Re: Ps4 smps
                        measure the voltage on the 2 big caps.
                        be carefull not to short the pins aganist that heatsink because it could be upto 400v
                        • dkneyle
                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                          by dkneyle
                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                          02-01-2022, 02:08 AM
                        • shamsudeen
                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                          by shamsudeen
                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                          07-19-2025, 07:14 AM
                        • abhishekkumar1902
                          Huntkey HK340-72FP SMPS shut on load above 2 amps
                          by abhishekkumar1902
                          I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                          I have checked the following:
                          1. All output caps are OK, and all output rails read correct voltages at no load
                          2. All output diodes are OK
                          3. NTC is ok
                          4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                          5. No short in main switching MOSFET
                          6. All other components...
                          12-18-2022, 09:52 AM
                        • madan1
                          Mackie Th15 SMPS low Vout
                          by madan1
                          I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                          It is basically a smps with amp and some dsp.
                          The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                          Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                          By the way, the ferrite core of L10 is broken,...
                          02-16-2025, 04:15 PM
                        • rewease
                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                          by rewease
                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                          09-17-2023, 12:53 AM
