Help needed Shuttle power supply
  • tckoo1411
    • Oct 2009
    • 24
    I am new here. currently I am trying to fix my shuttle power supply which went up in smoke the other day. Here's the model and some pictures:
    Brand : Shuttle
    Model : PC71I0005
    Can anyone tell me the rating of the burnt resistor? On top of that, the 5v standby power regulator was burnt and I couldn't identify the part number. Will upload the pictures once I get home. Anyone's help is much appreciated!!! Thanks.
  • tckoo1411
    • Oct 2009
    • 24
    Re: Help needed Shuttle power supply
    Brand : Shuttle
    Model : PC71I0005
    Can anyone tell me the rating of the burnt resistor? On top of that, the 5v standby power regulator was burnt and I couldn't identify the part number. Will upload the pictures once I get home. Anyone's help is much appreciated!!! Thanks..
    More picture
    • tckoo1411
      • Oct 2009
      • 24
      The PC was shutting down when there's a huge spark, after which the house circuit breaker was tripped.
      • tckoo1411
        • Oct 2009
        • 24
        Any advice? Thanks.
        • Quaddro
          Tukang Kentu
          • Nov 2010
          • 141
          • Indonesia
          well, fsp units.
          I don't know, but i do hate this platform..
          for me, it's rather hard to fix, because many components suffer leakage in full load rather than just fail..
          But, here is the schematic.
          i do hope you'll find the missing component.
            master hoarder
            • May 2008
            • 12164
            • Bulgaria
            Can you post top and bottom *overall* shots that show the whole PSU (and maybe point where the bad resistor is)? All I can see is that it is on the primary side (I think), possibly the snubber or current sense for APFC or main PS.
            • Gildasd
              • Jun 2016
              • Belgium
              I have the same supply, but the layout is different...
              One word of caution, the heavy filtering on the primary side can store quite a lot of energy.
              You must discharge where the 220/110V enters the board and then the main 450V cap (that is on a 16.5V rail on mine) with a 10k resistor wrapped in electrical tape.
                • 30944
                "huge spark" sounds like the mov shorted and exploded - i'v personally seen that happen.
                before you do anything else, get a small brush or a vac cleaner or compressed air and clear all that dust & fluff out
                • japlytic
                  • Oct 2005
                  • 2086
                  The IC which is blown is most likely to be a TNY26x series device (for the +5VSB section - a TNY265 handles 11W output and a TNY266 handles 15W output given this unit has active PFC and is of the open frame type and not an external adaptor) with the pins Drain (D), Source (S), Enable/Undervoltage (EN/UV), and Bypass (BP).
                  Also check capacitance of the 400/450V unit (after carefully discharging) - I've seen a surge damaged power supply which the 400/450V unit had barely any capacitance left in it.
