Tripp Lite Omni 900LAN battery replacement
  • Logistics
    • Apr 2007
    • 721
    For about a week, I had been noticing this thing in a pile of trash dumped on the side of the road. Finally, I put it in my van and headed to the shop.
    Someone had taken the cover loose, but left the screws in a baggy inside. It got rained on, but I let it dry out, and fired it up. It has a small, quiet hum when you turn it on, one you can more feel, slightly than hear, but power gets to the battery. Problem is the battery. I took it out and put it on an actual battery charger (a roll-around shop charger) on 2-amp trickle, all day and it got up to about 8V, but even putting the multi-meter across the leads made it lose about 0.1V per second so I concluded the battery needs to be replaced.
    Please, suggest some good replacement SLA batteries, and perhaps a source? It currently has a Panasonic LCL 12V24P.
    • 31246
    Re: Tripp Lite Omni 900LAN battery replacement
    price / lifespan - choose one!
    if you want long life, panasonic, yuasa etc.
    • Logistics
      • Apr 2007
      • 721
      Do these also act as a form of line conditioner?
        • 31246
        unlikely.
        they probably just kick in if the power fails.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          http://www.walmart.com/ip/EverStart-...ttery/20531539
          about 4x runtime.
          of course you need heavy cables
            I am sure it has common mode and differential mode line filters, surge protection outputs, plus AVR (Automatic Voltage Regulator function) using transformer tap switch for buck and boost to keep the AC output within 120V (the capture range is probably from 100V~125V range) and will kick in UPS mode when it is above or below the capture range or lost incoming AC input.
            Do you have user manual?
            • Logistics
              • Apr 2007
              • 721
              I'm curious, now how clean the power is while in UPS mode. Perhaps, I could use this to power audio equipment when I want a cleaner than normal signal quality. Any thoughts?
                Do you know if this UPS has true sine wave output or step sine wave, I cannot find the exact info for this exact model 'Tripp Lite Omni 900LAN'
                If it is step sine wave, then forget it.
                Are you trying to use it like PS Audio power regen?
                • Behemot
                  • 4845
                  • CZ
                  Yuasa SLA are no way close to Yuasa auto/motobateries in quality. Panasonic is clearly best there.
                  • Logistics
                    • Apr 2007
                    • 721
                    I don't know, but I wouldn't be surprised if it's just a step or square wave, which I've read is not what you want for audio.
                    I haven't really given much thought as to what to use it for other than my computer, although in all the years of my life I don't think there's been but one time when I was using my computer (to play an online game) when the power went out, but then I typically shut down all the equipment I hold dear and either unplug them or switch off their respective power-strips during bad storms. That one time the power went out was years ago when the 25-year-old transformer that handles our block, which was scheduled to be replaced years ago, began having trouble handling the load of all the air-conditioners in the area and was randomly tripping.
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • mferna14
                      MacBook Air A2681 battery problem after Screen Replacement
                      by mferna14
                      Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                      12-06-2024, 08:10 PM
                    • dhenion
                      Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                      by dhenion
                      I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                      The original board was:
                      ASUS X510UNR REV 3.0 A
                      The replacement board is:
                      ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                      It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                      01-30-2024, 01:45 PM
                    • mkdj
                      by mkdj
                      Mark and model: ASUS X571
                      Tests already made:
                      - I have removed...
                      07-14-2025, 09:16 AM
                    • NConstantinou
                      LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                      by NConstantinou
                      Dear all,
                      i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                      the laptop DOES NOT POWER ON..
                      with it old battery it does power on.
                      i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                      when i shutdown the laptop does not power on.
                      does anyone have any solution!
                      when is not power on the usb c voltage tester shows 5v 1.3A
                      when i disconnect battery and power on and then connect battery the tester...
                      12-10-2024, 04:52 AM
