Antec NEO HE550 Caps replacement
  • Bogey
    • Mar 2015
    • 16
    • Finland
    I have some 6 years old Antec NEO HE 550 PSU and one capacitor has bloated.
    It is OST 2200uF 6.3V.
    I'm going to replace all caps.
    Here is list of capacitors.
    Antec NEO HE550 Google Spreadsheet
    Most are OST, but there is few Jen Pans (JP) and one Teapo.
    I found datasheets for OST RLX and RLS and Teapo, but for some capacitors I could not find values.
    For JP I could not find datasheet.
    Would Panasonic FM or FR be good replacement for OST caps? Also 68uF 25V I could not find any replacement. Can I have different Voltage / Capacity instead?
    How about JP and Teapo, FM or FR good choice?
    References:
    RLS Datasheet
    RLX Datasheet
    Teapo datasheet
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Antec NEO HE550 Caps replacement
    References:
    RLS Datasheet
    RLX Datasheet
    Teapo datasheet
    Fm and Fr will work fine, just be sure that you replace evey cap in the psu including the smaller ones as they are all probably internally failing and could cause the psu to fail shortly after.
    • Bogey
      • Mar 2015
      • 16
      • Finland
      Ok thanks. Which one is preferred FM or FR?
      And how about that large one, 400v 390uF. Does that need to be replaced.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Wha brand is it, and fm and fr are both great caps ?
        • E8200
          • Dec 2013
          • 16
          • Estonia
          Just replaced all Antec EA-380 Ost caps with Panasonic FM, FR and FC.
          Read: https://www.badcaps.net/forum/showthread.php?t=44580
          RLS 1000uf, 16v to EEUFR1C102L
          RLS 1000uf, 10v to EEUFM1A102L
          RLX 3300uf, 10v to EEUFM1A332
          RLX 2200uf, 16v to EEUFM1C222
          RLX 2200uf, 10v to EEUFR1A222L
          RLP 1000uf, 10v to EEUFC1A102L
          RLS 220uf, 16v to EEUFR1C221
          RLS 22uf, 50v to EEUFR1H220
          RLS 47uf, 50v to EEUFR1H470
          • Behemot
            • 4845
            • CZ
            Oh man, this is grandpa Looks like some kind of modular version of the Seasonic Super Tornado.
            According to Hardware Secrets, there is NCC SMQ input cap. I would leave it there. But for 550W unit, I would myself use 3300uF caps. I can provide you with NCC KYA 3300/6,3 and Samxon RS 3300/16, both D10.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Talking of your samxon rs I will be buying some with in the next 2 weeks
              • c_hegge
                • Sep 2009
                • 5219
                Their electrical specs are actually quite similar. FR are often physically a bit smaller for the same capacitance and voltage, so they are sometimes all that fits, but if an FM fits, it will be fine
                If you need to, you could replace the 68uF 25V cap with a 68uF 50V if its any easier. Panny FC and Nichicon PW are also good options for those small caps.
                by the way, where do you plan to buy your caps from? I'm pretty sure element14 and RS components will ship to Finland from the UK.
                • Behemot
                  • 4845
                  • CZ
                  I ship worldwide using airmail, which is often far cheaper than courier services of these big reseller corporations…
                  • c_hegge
                    • Sep 2009
                    • 5219
                    That is true, but I don't think you have everything he needs, though. There are a number of 2200uF 6.3V caps in there, which I haven't seen on your website. I really wouldn't recommend changing the capacitance and electrical properties of the caps too much in these Seasonic Super Silencer platform based PSUs, as they have much more picky feedback loops than some.
                    • Behemot
                      • 4845
                      • CZ
                      Yes because I only use 3300uF caps. Why using 2200 when I have 3300 in the same package, maybe 5mm taller? Makes no reason to source extra 1000 pieces I will really "need" in 1 case of 20. And than I can still use KZN 1500 D8 with probably the same ESR as KYA/KYB in 2200 D10.
                      • Bogey
                        • Mar 2015
                        • 16
                        • Finland
                        The large one is Nippon Chemi-Con smq 85°C
                        E8200, yes thank you, that was very good for initial research.
                        FR having bit longer life time and it is cheaper so I'll get those.
                        At least Elfa has good stock, but I'll compare other shops as well.
                        For OST RLS 68uF 25V, would Panasonic FM 35V be OK replacement?
                        Code:
                        68uF 25V		Volts	Cap	Dia	Length	Ripple 	Impedance	Part
                        OST RLS		25	68	5	11	250	0.13
                        Panasonic FM	35	68	6.3	11.2	455	0.13		EEUFM1V680
                        For OST RLS 220uF 16V I could not find Panasonic or Nichicon. Any of these will be suitable?
                        Code:
                        220uF 16V	Volts	Cap	Dia	Length	Ripple 	Impedance	Endurance	Part
                        OST RLS		16	220	6.3	11	405	0.13		2000
                        Rubycon		16	220	6.3	11	540	0.094				6ZLH220MT16.3X11
                        Panasonic FM	25	220	8	11.5	950	0.056		3000		EEUFM1E221
                        NIC Components	16	220	8	11.5	560	0.16				NRSZ221M16V8X11.5
                        Jamicon		16	220	8	14	400	0.18				WGR221M1CF14VU
                        • Behemot
                          • 4845
                          • CZ
                          I have new and shiny Rubycons YXJ 220/25 in only D6,3 mm!
                          • Bogey
                            • Mar 2015
                            • 16
                            • Finland
                            You have some webshop?
                            Would 3300uF handle higher loads then better? The bloated one was 6.3v 2200uF. So maybe I'll consider to replace with 3300uF. About impedance should that be about the same? Better to be lower or higher? How about ripple?
                            • Behemot
                              • 4845
                              • CZ
                              I have a stock overview in english.
                              KYA 3300/6,3 has impedance of 42 miliohm, ripple 1650 mA. Could be somewhat lower (ripple current higher), I will order KYB next time, but those OST RLX are too low for my taste, those are basically ultra-low ESR caps (motherboard grade) with only 2000 hours life and who knows if they ever even had such low ESR as the datasheet says. Not sure why Seasonic used them in power supply. Maybe there was nothing better at that time…anyway, I use only these caps all the time and everything works fine so far.
                              If that RLX datasheet is to be believed, than I can offer KZN 3300/16 D10x40 mm with 18 mΩ and 3,6 A, they will be fine there (other supplies may oscillate with such low ESR, but if this one really was designed for MB grade caps, than it will surely be OK). Lifetime of 10000 hours@105 °C.
                              • Bogey
                                • Mar 2015
                                • 16
                                • Finland
                                Ok, I'm checking. For these I could not find replacement:
                                OST RLX 3300uF 10V
                                OST RLS 68uF 25V
                                Jen Pan ce-tur 1000uF 6.3V
                                • Behemot
                                  • 4845
                                  • CZ
                                  You don't need 10V caps, for lower voltages use 6,3 V and for +-12 V use 16V caps. Instead of that CEC, use KZN 1500/6,3.
                                  Where exactly is that 68uF cap? I usually replace that with either 47, or 100uF cap, depending on what it does. It is very uncommon value.
                                  EDIT: From Pentium4's thread there's a photo, which cap that is? If the bigger one, it does not matter, it is there to filter Vcc voltage for the stand-by rail PWM controller.
                                  • Bogey
                                    • Mar 2015
                                    • 16
                                    • Finland
                                    EDIT: From Pentium4's thread there's a photo, which cap that is? if the bigger one, it odes not matter, it is there to filter Vcc voltage for the stand-by rail PWM controller.
                                    [/IMG]
                                    That is OST RLS 68uF 25V
                                    • Behemot
                                      • 4845
                                      • CZ
                                      Yeah than you can use KZM 47/35 or LXZ 100/35, both will be fine.
                                      • Bogey
                                        • Mar 2015
                                        • 16
                                        • Finland
                                        That
                                        OST RLX 3300uF 10V
                                        is found in same picture in lower right corner. What should use for that?
                                        Please check my doc if these would be ok replacement:
                                        Yellow ones are the original, green ones replacement.
                                        • rewease
                                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                          by rewease
                                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                          09-17-2023, 12:53 AM
                                        • HectoPascal
                                          Replacement caps ok? (smoothing caps, PSU heating controller)
                                          by HectoPascal
                                          Hallo,
                                          i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
                                          SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
                                          SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
                                          I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
                                          Nichicon should be 'VY' series (linked).
                                          I couldn't find anything about Samwha...
                                          09-06-2023, 08:30 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • Techboxcomputer
                                          XBOX One S caps value and replacement
                                          by Techboxcomputer
                                          Hi -
                                          I saw there was another post similar to this, but I do not believe he was referring to the same caps I am seeking.
                                          These caps are in the “B” section of the board and the board is marked C9C11, C9C4, C988. The caps appear to be aluminum sheathed and are marked “FP 95 CD 271 16” The Digikey tech's best guess was Nichicon 16v 271 uf but I don't want a guess and solder in the wrong cap. Do any of you know exactly the value of these caps and a good replacement for them?...
                                          12-21-2022, 08:35 AM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
