Antec EA-380 Bad capacitor replacement
  • E8200
    • Dec 2013
    • 16
    • Estonia
    Ok, my Antec EA-380 needs a fix. Symptoms were, that after power loss computer did not start and motherboard (Asus P5W DH Deluxe) led was blinking only (should stay on after PSU connected). After many tries I was able to start PC when I did connect ATX connector after turning PSU on from back first. When PC started it did not show any more symptoms bu after switching off PSU all problem repeated. And new motherboard GigaByte Z97X-UD3H-BK did not start at all, only fans moved slightly and off again.
    After opening PSU did find one bulged cap (Ost RLX 1000uf, 10v in the picture 1). Question is, can Ost RLX, and maybe others marked in pictures with green (Ost RLX, RLP, RLS) be replaced with Panasonic FM series and 2 1000uF, 10v RLX with Panasonic FR (2200uF, 10v FM not available at moment). Did a little homework and Panasonic FM and FR seems to have similar features, comparison is in picture Caps List. Or is there any other better options?
    Parts to replace, is it ok?
    Ost RLX, 3300uF,10v, Ripple 2780, Imp. 0,014
    to
    Panasonic FM, 3300uF,10v, Ripple 3190, Imp. 0,015, EEUFM1A332
    Ost RLX, 2200uF, 10v, Ripple 2500, Imp. 0,015
    to
    Panasonic FR, 2200uF, 10v,Ripple 2470, Imp. 0,018, EEUFR1A222L
    Ost RLS, 1000uF, 10v, Ripple 1250, Imp. 0,041 and
    Ost RLP, 1000uF, 10v, Ripple 995, Imp 0,074
    to
    Panasonic FM, 1000uF, 10v, Ripple 1560, Imp 0,030, EEUFM1A102L
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Antec EA-380 Bad capacitor replacement
    Well done!
    Your list looks fine to me, the replacements for the RLP's might be stretching it, but otherwise looks good!
    But don't forget the small capacitors, those are most likely the reason why you PSU is having problem turning on, and it can go "boom" if they become too poor!
    • E8200
      • Dec 2013
      • 16
      • Estonia
      Thanks, first thought was to replace all, small ones too, so I will do full recap.
      Small ones are all Ost RLS, so FM should be fine there too, only thing was, that thre's no 220uF, 16V FM, is 330uF,16V ok? Is there any other suggestions to replace RLP? Maybe NCC KY?
      RLP Ripple 995, Imp. 0.074
      NCC KY Ripple 1050, Imp. 0.069
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ky will work fine, that will be one solid psu when you have recapped it
        • E8200
          • Dec 2013
          • 16
          • Estonia
          Well, it served me 7 years almost non-stop 24/7 in use. I have nothing better to do at the moment so I give it a try. I think it deserves it.
          • E8200
            • Dec 2013
            • 16
            • Estonia
            Caps out, now shopping.
              • 31050
              if you need any caps that are tall and thin, check out panasonic FK series.
              • delaware74b
                • Apr 2009
                • 628
                Another tip on this power supply: remove ALL the yellow glue. It gets conductive when it turns brown from heat and it lets out all the magical smoke.
                Stupidity should be a crime, especially for drivers. I have NO patience for them.
                • seanc
                  • Nov 2008
                  • 1319
                  I quite like these PSUs, I've got a few I've recapped here and there. Once the caps are replaced they seem to be nice and reliable.
                  I once predicted one of those EA-380 was about to fail as it was in a quiet room and I could hear it hissing depending on what the PC was trying to do (load). A couple of weeks later, the PC was giving a BSOD on boot. Swapped the PSU and it was fine.
                  Caps showed no visible signs of failure, I must have recapped it and put it in something anyway.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    This. That 3300uF 6.3V cap on the 5vSB rail will be a problem, in that a 12.5mm Fappny FM won't fit easily. You can get a 3300uF 6.3V Panny FK, which will fit. It's electrical specifications aren't as good as those of RLX but it will still be more than adequate for this application.
                    Panny FR and FM, or even FC should be fine everywhere else.
                    • E8200
                      • Dec 2013
                      • 16
                      • Estonia
                      Oh, I know, but already ordered 3300 FM and after changing once a car tyre with desktop vice and levers, I think I can make it fit there. There's always a bigger hammer lying around.
                      List goes:
                      Cap, alu elect, 1000uf, 16v, can,EEUFR1C102L
                      Cap, alu elec, 1000uf, 10v, rad,EEUFM1A102L
                      Cap, alu elec, 3300uf, 10v, rad,EEUFM1A332
                      Cap, alu elec, 2200uf, 16v, rad,EEUFM1C222
                      Cap, alu elec, 2200uf, 10v, rad,EEUFR1A222L
                      Cap, alu elec, 1000uf, 10v, rad,EEUFC1A102L
                      Cap, alu elec, 220uf, 16v, rad,EEUFR1C221
                      Cap, alu elec, 22uf, 50v, rad,EEUFR1H220
                      Cap, alu elec, 47uf, 50v, rad,EEUFR1H470
                      D-Day is tomorrow.
                      Is there any point to replace Nippon Chemi-Con SMQ 220uF/400V/1.49A primary cap also?
                        • 31050
                        i dont think you ever need to change he primary's if they are made by NCCor Rubycon.
                        • Behemot
                          • 4845
                          • CZ
                          Seems like Seasonic S12-II OEM design to me.
                          • E8200
                            • Dec 2013
                            • 16
                            • Estonia
                            Funny thing, replaced my broken Antec with Seasonic S12 II-Bronze 430W. Would open it up and look inside but it's under warranty for 2 years.
                            • Behemot
                              • 4845
                              • CZ
                              Yes, it is Seasonic for sure. They were fine for a long time, now it seems that OSTs and other crap in them are beginning to fail around me, after aprox. 6-7 years of use. Gonna drive my caps sales, great
                              • E8200
                                • Dec 2013
                                • 16
                                • Estonia
                                Well, mine has all around Panasonic (FM, FR and FC) inside now, plus original NCC primary. BTW, this 12,5mm 3300uF/10V FM fitted in just fine, no room to spare but it is there. (first pic.)
                                Tested voltages
                                +3.3V is 3.2V
                                +5V is 4.9V
                                +12V is 12.1V
                                -12V is 11.4V
                                +5VSB is 5.0V
                                3.3V, -12V and 5V little bit low?
                                But everything works and this blinking MB led and no-start issues are gone, P5W DH Deluxe powers up like it should, first time, every time.
                                Work is done, thanks to everyone for help. Another badcap to goodcap story.
                                • Behemot
                                  • 4845
                                  • CZ
                                  Yeah this topology counts with a few 12,5mm caps. But most others do not, especially Fortrons BlueStorm II / Epsilon / Everest, they even have 8mm caps. If you'll need some 3300/6,3 V or 3300/16 V caps in future, as well as 1500/6,3 D8 and 1000/16 D8, let me know.
                                  Those voltages are with multimeter, or some BIOS-like reading?
                                  • E8200
                                    • Dec 2013
                                    • 16
                                    • Estonia
                                    Measured with cheapo multimeter, don't know how accurate this thing is.
                                    • Andre Gilbert
                                      by Andre Gilbert
                                      11-20-2024, 08:52 PM
                                    • chth96
                                      Is it no harm to replace with capacitor without ripple current rating?
                                      by chth96
                                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                      Rubycon YK DataSheet (b...
                                      04-19-2024, 05:19 AM
                                    • AquaMan Ua
                                      Problem with PANASONIC CF53 laptop after changing BIOS settings
                                      by AquaMan Ua
                                      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                      05-17-2025, 09:40 AM
                                    • Y. Signal
                                      Recapping Mean Well MWP-606
                                      by Y. Signal
                                      Hello, I have this arcade power supply that I'd like to recap for maximum reliability and lifetime since I have found some Capxon and Jamicon capacitors:
                                      • Capxon GL 10x25 1000uf 16V Ripple: 1180 Impedance: 0.05ohm // Chemi-con KY 1000uf 16V Ripple: 1400 Impedance: 0.046ohm
                                      • Capxon GL 10x12.5 470uf 16V Ripple: 722 Impedance: 0.095ohm
                                      • Capxon GS 10x15 22uf 50V 85ºC Ripple: 100
                                      • Capxon KM 47uf 50V Ripple: 125
                                      • Jamicon TK 1uf 50V Ripple: 12
                                      • Jamicon TK 4.7uf 50V Ripple: 36
                                      I have another PSU (same model) that uses Chemi-con KY instead of Capxon GL, and since Panasonic FC are very...
                                      03-03-2019, 07:44 AM
                                    • Antonynl
                                      What are typical ripple voltages on a laptop motherboard?
                                      by Antonynl
                                      I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                                      So I have two questions:
                                      1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                                      2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                                      Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                                      12-09-2022, 06:51 AM
